Canon 760D won't switch on.
Started May 16, 2018 | Discussions
Boxerboy1 New Member • Posts: 1
Just new to the forum had a quick look through but could not find my issue mentioned My 16 month old 760D has failed to switch on twice in the last 3 months battery working ok and charged. The first time I reported it to Canon service Uk but by the time they got back to me it was working. I didn't think it was worth sending to them if it was ok. It failed again on the second day of my holiday so I reported it and posted it to Canon. When thet received it the camera started straight away and tests show no problem. I even sent my battery and SD Card for them to check. At the moment they are going to send it back without doing anything. I have requested that they keep it and continue to test/use until it fails again. They are not happy to do this. Canon do not recognise this as an existing problem with the model. Does anybody out there have a similar issue which has or has not been reported to Canon? I am thinking I need to get a new camera as I cannot rely on this one to work.
Thanks in advance I have seen issues with other models where the SD card door may cause problems however Canon are not taking notice of information taken from forums.
Phil
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
John messenbird New Member • Posts: 1
Re: Canon 760D won't switch on.
I also now have the same problem with the exact same model. I'm pretty sure the sensors are fine regarding battery and card doors because when I close the door the red indicator light flashes. That also tells me the battery is ok.
I have a strong feeling that the rotary on/off/video switch is faulty. Any other help from people would be
