Upgrading from the 16-50 to the 18-55?
Started 8 months ago | Discussions
hoakin1981 Regular Member • Posts: 397
For sometime i have been considering selling my 16-50 OIS II in order to buy the 18-55.
This would be in order to have a better IQ (even though marginally) but most importantly to have a faster do-it-all (more or less) lens.
If i end up missing the 16mm wide angle FOV too much I could also buy the Samyang 12mm f2 later on.
A few things to keep in mind:
  • I also have the 23mm f2
  • Body is the X-E2
  • I shoot travel/cityscapes/architecture/some portraits
All comments much appreciated.
Fujifilm X-E2
Adoubeur
Adoubeur Junior Member • Posts: 49
Re: Upgrading from the 16-50 to the 18-55?
Hi,
I've been using both these lenses. There's no difference in IQ between both. To my opinion, the aperture difference is not big enough to justify changing.
I sold the 18-55 and kept the 16-50. Wy wife uses it more than me, and likes it better than the 18-55 because :
- it is smaller and lighter
- 16 mm at the wide end
- she finds the OIS better
 Adoubeur's gear list:Adoubeur's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +2 more
AndyH44 Contributing Member • Posts: 832
Same here.....found the 16-50 to be a bit sharper.  Didn't need the extra speed, the funky aperture ring, or the weight.
 AndyH44's gear list:AndyH44's gear list
Olympus TG-5 Fujifilm X-T1 Olympus OM-D E-M10 II Fujifilm X-T20
uniball Senior Member • Posts: 2,045
I had both, an early 18-55 and a Gen 1 16-50. Didn't like either and sold both. But I needed a mid-range zoom so I picked up another 18-55.
18-55, a bit more pop in the render versus a more sterile draw in the 16-50. Could be sample variation here as there appears to some with the 18-55. My first copy I'd rate as an average lens in many respects, my current copy is simply gorgeous in every respect. (Sorry, none of us like sample variation thoughts when buying a lens.)
I'd go with the 18-55 IF the below criteria match yours.
Lovely build and mechanical operation on the 18-55. The 16-50 feels like what it is, a typical budget plastic kit zoom.
The wide end of the 16-50 is not 16. It's either 17 or even closer to 18. Been a while and I forget. There's so much distortion at the wide end by the time lens corrections are done some of the "16" get's cropped away. So think 1mm at best, not 2.
My 18-55 rendered a bit more contrasty image. My copy of the 16-50 rendered an older more classic draw. Also quite nice. Both are quite competent in IQ.
The 18-55 is definitely heavier. Feels like a quality lens.
If you're buying used stay away from the early copies of the 18-55. There was a OIS problem that probably was a manufacturing issue as there were no fixes and no word from Fuji, it just went away. I had one of the early lenses and some of us were getting shake in images when there should not have been any no matter how bad our handholding.
sluggy_warrior Senior Member • Posts: 1,251
16mm is still not wide enough for me, I usually just take a few shots and throw them into Hugin See samples of panoram here, painless and super easy with Hugin:
https://www.flickr.com/photos/25213980@N06/
I don't have the 16-50, but very happy with 18-55, one hell of a lens, as sharp as the popular Nikon 35/f1.8G.
KwhyChang Veteran Member • Posts: 5,948
  • Body is the X-E2
I wouldn't do it. I bought both and they both have their place in my kit.
I've had more focus issues with the 18-55 than any other Fuji lens. Lately I often choose the 18-135 over the 18-55.
Dave
mcshan Veteran Member • Posts: 4,190
I have both and I don't see a big difference in IQ. If it is there it is marginal. The 16-50 is surprisingly good. If I didn't need the extra reach I wouldn't do it. I also prefer the smaller size.
In any case good luck and happy shooting.
 mcshan's gear list:mcshan's gear list
Canon PowerShot G1 X Sony RX100 Leica X Vario Sony RX1R Leica D-Lux (Typ 109) +7 more
Vic Chapman Forum Pro • Posts: 10,126
I'm glad it's not just me. I also gauged the 16-50 XC as narrower than 16mm at the wide end and by the time I'd removed distortion (obviously more visible with straight lines near the edges) I finished up with something narrower than 18mm FoV.
I tried two copies (actually to see if they were good for infrared - they aren't) and tested them side by side with my 18-55 and the XC lenses came up just a bit short on IQ but you'd need identical images to tell. They were close enough at middle apertures that I'd be happy using them if on a budget or for their compact size/weight - but not for the lack of aperture ring!
As it happens, my 18-55 see no use since I checked out the 16-55mm f2.8 XF lens a few years ago. IMO, the difference in IQ between 18-55 and 16-55 f2.8 is greater than between 16-50 XC and 18-55 XF. Speed and quietness of AF is probably best of all Fuji lenses.
If I had the 16-50XC as my std zoom I would keep it and buy a few primes or longer lenses rather than sell for the 18-55mm XF.
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +10 more
OP hoakin1981 Regular Member • Posts: 397
Thank you all very much for taking the time to reply.
Interesting...Perhaps i should consider buying the Samyang now in order to compliment the kit.
ktmei Contributing Member • Posts: 776
i sold the 16-50 for the 18-55 in hopes the lens would be a "better" upgrade. Since having the 18-55, its only made me question the weight and size. Sure having a stop of light is nice as well as an aperture ring, but then again, how often do I even shoot at 2.8?
i am still debating whether I should sell the 18-55 for the 16-50 and save some money.
 ktmei's gear list:ktmei's gear list
Ricoh GR II Fujifilm X-T1 Fujifilm 16-50mm F3.5-5.6 II
