a9 battery life
Started May 15, 2018 | Discussions
JimKasson
JimKasson Forum Pro • Posts: 39,105
a9 battery life
18
I just completed a series of shots with the a9 over 3 days:
  • Electronic shutter (1/400 - 1/2500 seconds)
  • Continuous AF, medium spot
  • Continuous high drive speed (20 fps)
  • Sony 100-400 G lens
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
I made about 7500 exposures. The battery was fully charged at the beginning. At the end, it was down to 42%. I did not chimp.
Pretty impressive.
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Fujifilm GFX 100S Nikon Z9 +1 more
Sony a9
lattesweden
lattesweden Veteran Member • Posts: 5,261
Re: a9 battery life
Yes, I have a similar experience. It just keeps going.
The A9 also has zero resting consumption which I can't say about my A7RII that can consume the battery in some days even if its off through the power switch. And at times it hardly uses anything at all in off mode and the battery indicator is the same after a week as when I turned it off. This shifting consumption from time to time in off mode is somewhat strange. I know you made some measurements earlier, did you see this variations as well on the A7RII?
Anyway, back to the A9, according to the official numbers the A9 is not the best to preserve the battery of the generation 3 bodys. The A7III should do best of the new pack of bodys from my understanding.
When shooting events, compressed RAW+JPEG which is about a 52 MB combo on the A7RII and slightly under 30 MB on the A9. I often have zero battery left when my 32 GB card fills in the A7RII and the A9 battery lasts until I fill a 64 GB card. So I get about 3.5 times more images with the A9 than the A7RII on one battery.
Best regards
/Anders
42 Megapixels is the answer to life, the universe and everything.
You don't have to like my pictures, but it would help: http://www.lattermann.com/gallery
PSGimages
PSGimages Senior Member • Posts: 2,461
Re: a9 battery life
Wow, that's great.  Are there certain settings you think helped (besides avoiding chimping)?
 PSGimages's gear list:PSGimages's gear list
Sony a9 Sony a7R III Sony FE 55mm F1.8 Sony FE 70-200mm F2.8 GM OSS Sony FE 85mm F1.4 GM +10 more
K1000usr Regular Member • Posts: 475
Re: a9 battery life
Great news. I generally don't get anywhere such good results.
And looking forward to some of these photos in the weekly thread part-III, IV ...
Zefah Regular Member • Posts: 405
Re: a9 battery life
I've had similar experience for sure. I shot an indoor sporting event for my son's class over the course of 4 hours (camera being on most of the time) using the Zeiss 35mm F1.4 lens, so at 15 FPS and captured over 7,000 frames. It was almost constant shooting. I even bought a battery grip for the event, but I had around 18% battery life in my first battery remaining at the end of it. This is with both the EVF and LCD ad maximum brightness. Most shooting done through the LCD. IBIS on. Not much time spent reviewing images.
I was always super nervous with my A7R II, but the A9 has definitely removed my concerns about battery life.
 Zefah's gear list:Zefah's gear list
Sony a9 II Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 70-200mm F2.8 GM OSS Sony FE 85mm F1.8 +2 more
JimKasson
OP JimKasson Forum Pro • Posts: 39,105
Re: a9 battery life
Just the ones I noted.
Jim
tesilab
tesilab Veteran Member • Posts: 3,004
Long shelf life, too apparently I have yet to recharge a battery.
I have not been getting a lot of opportunities to shoot my A7III. (Supposedly a bit  better than A9 in terms of power consumption)
I was bummed when I picked up the camera on April 10th, and couldn't even try the camera due to the totally depleted battery. That evening I charged the battery, and thirty five days later, I still have plenty of power on my first charge.  (I'm still impressed though I haven't made thousands of shots yet). Not sure why I thought I needed two  whole spares.
 tesilab's gear list:tesilab's gear list
Sony RX1R II Panasonic Lumix DMC-GX8 Sony a7 III Panasonic Leica Summilux DG 25mm F1.4 Sony FE 85mm F1.8 +1 more
Curtis Khan
Curtis Khan Senior Member • Posts: 1,508
Re: a9 battery life
What's you a9's shutter count Jim?
CURTIS R. KHAN
"The needs of the many outweigh the needs of the few...or the one!"
 Curtis Khan's gear list:Curtis Khan's gear list
Sony RX100 III Sony a99 II Sony a7R III Sony 70-200mm F2.8 G Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +33 more
trainerKEN Senior Member • Posts: 1,583
Re: a9 battery life
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
Pretty impressive.
I had similar experience last month at the Toyota Long Beach Grand Prix (same setup)
 trainerKEN's gear list:trainerKEN's gear list
Fujifilm X100V Sony a9 II Sony a1 Canon TS-E 17mm f/4L Sony FE 85mm F1.4 GM +9 more
JimKasson
Re: a9 battery life
1695. It's been there for months.
Curtis Khan
Re: a9 battery life
Oh Right!! Electronic shutter!!
CURTIS R. KHAN
Re: a9 battery life
I'm around 200, only switched to mechanical shutter for a studio photoshoot, yet I've taken at least 6 to 7k pictures with the a9
RE Alpha
RE Alpha Contributing Member • Posts: 896
Re: a9 battery life
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
Pretty impressive.
Impressive numbers. I can't say that I have ever counted the number of 'clicks' but the A7riii and A9 have never worried me about running out of juice during important shoots (the A7rii did). This is a nice additional assurance that Sony got it right. Thanks Jim!!
 RE Alpha's gear list:RE Alpha's gear list
Sony a7R III Sony a1 Sony FE 24-70mm F4 OSS Sony FE 90mm F2.8 macro Sony FE 85mm F1.4 GM +8 more
Seeky Senior Member • Posts: 1,066
Re: a9 battery life
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
Pretty impressive.
Impressive indeed. If one would extrapolate to complete battery depletion you could shoot approx. 12000 shots under these conditions. I assume that the use of electronic shutter compared to mechanical shutter contributes significantly to these results?
I also guess that it requires a full time job to go through the images?
 Seeky's gear list:Seeky's gear list
Sony SLT-A57 Fujifilm X-T1 Sony a7 II Sony a7 III Sony DT 18-55mm F3.5-5.6 SAM +14 more
noggin2k1
noggin2k1 Senior Member • Posts: 2,816
Re: a9 battery life
2nd shooting this weekend - 2x A9's both with grips (4x FZ100's in total). There'll be zero concerns about the batteries lasting the day!
 noggin2k1's gear list:noggin2k1's gear list
Fujifilm X-E4 Canon EOS R3 Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L II USM Canon RF 50mm F1.2L USM +7 more
randomguy Contributing Member • Posts: 531
Re: a9 battery life
If I am shooting a lot of action at 20FPS, 10000+ shots per battery is common for me. I suspect battery life depends more on how long the camera is kept awake and less on how many shots I shoot during that time though. If one just holds down the shutter at 20FPS until battery wears out I wouldn't be surprised if it can shoot 100000 shots on 1 charge. Though I am not eager enough to wear out my memory card just to test it.
Best Regards,
Morten Smedsrud
https://www.flickr.com/photos/154088944@N03/
https://500px.com/msmedsru
PeterL6312
PeterL6312 Regular Member • Posts: 439
Re: a9 battery life
Very impressive, especially since it's quite a long lens to drive AF for
Probably time to remove the battery life as a con for mirrorless, at least within normal temperatures, might still be an issue in very low temps compared to DSLR though.
Thanks for sharing.
Kind Rgds, Peter
 PeterL6312's gear list:PeterL6312's gear list
Sony a9 Sony FE 70-200mm F2.8 GM OSS Sony 1.4x Teleconverter (2016) Sony FE 100-400mm F4.5-5.6 Sony FE 135mm F1.8 GM +5 more
EOSLenny Regular Member • Posts: 145
Re: a9 battery life
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
Pretty impressive.
Why do you switch IBIS and OSS on the lens off?
Is is not working? Would it drain the battery too much? Is the picture better without it?
The Davinator
The Davinator Forum Pro • Posts: 24,707
Re: a9 battery life
Would be interesting to see a shootout between the a9 and Nikon D5 and Canon 1DX2.  7500 has got to be a record on a single battery.
JimKasson
Re: a9 battery life
  • Sony 1.4x TC
  • OSS and IBIS off
  • EVF, standard
Pretty impressive.
Three cheers for Fast Raw Viewer !
