Panasonic 100-300mm II review
Started May 12, 2018 | User reviews
JosephScha Veteran Member • Posts: 7,249
9
This is one of those lenses you may not use often, but when 140mm won't do this lens gets called in to service. I used it at an airshow of historic airplanes, and was very impressed.
Is it the ultimate sharp, fastest to focus lens imaginable? Well, no. But it does focus quite quickly, all my shots were in very good focus. And, it's quite sharp. Not quite like the center of my Leica 25mm f/1.4 ... still, better than I expected at this price. Before this my "tele" was the original 45-200, I can tell this lens is sharper. I owe you an example or three ... From Sept 2017
Banking, so far away from me
Seriously brightened shadows, but if you look at the tail you can read "Pensecola" and you can see the spokes in the wheels and X strings between top and bottom wings.
And one more to show correct focus on the same plane coming at me for landing: this is not the sharpest shot. Could be the photographer's fault. When you view at 100% nothing is tack sharp, but it's good enough to print 8x10 for sure.
Conclusion: Glad I have this lens, for situations like this!
By the way, I have since learned that I should have stayed at base ISO, and maybe even with a slight ND filter, to have a shutter speed that would not freeze the propeller and so would show motion better.   Maybe next air show....
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Panasonic Lumix G Vario 100-300mm F4-5.6 II Power OIS
Telephoto zoom lens • Micro Four Thirds • H-FS100300
Announced: Jan 4, 2017
JosephScha's score
4.5
Average community score
4.3
scotttnz Regular Member • Posts: 179
Re: Panasonic 100-300mm II review
13
I’m a big fan of this lens, and I often wonder why it is generally not rated more highly. I am often amazed by how sharp, and punchy images are straight out of the camera, even at 300mm wide open. It has nice bokeh and the image stabilisation with a dual IS body is very impressive.
I have considered replacing my 100-300 with a 100-400, but for me that would be trading a lens that is not small, but small enough to always carry in my bag with a more specialised lens, that is big enough to only take with me when I’m going to shoot wild life etc. and I’m very happy with the results the 100-300 gives me.
 scotttnz's gear list:scotttnz's gear list
Panasonic Lumix DC-S1R Panasonic G95 Panasonic Lumix G 25mm F1.7 ASPH Panasonic S 24-105mm F4 Macro OIS Panasonic 14-140mm F3.5-5.6 II +7 more
phil from seattle
phil from seattle Veteran Member • Posts: 3,699
I'm a sucker for vintage airplane photography. Love yours.
You'll need 3-4 stops of ND filter to get into the 1/200 Sec range to get a good amount of motion blur on the props. You can get reasonable blur with a little faster shutter. Though, it depends on the aircraft, engine and power setting. I been practicing with planes and can get good shots with 1/125 Sec which gets some nice prop blur. Here's a landing Spitfire taken at 1/250 Sec. I really needed 3 stops of ND to get out of the diffraction zone though in this case it doesn't matter because of the heat waves.
 phil from seattle's gear list:phil from seattle's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
HRC2016 Veteran Member • Posts: 6,874
The 100-300 (and the Oly 75-300) are underrated, while the 100-400 is overrated. I recently had all three. I think many who praise the 100-400 so much just don't know how to use the smaller lenses as effectively. Bigger is not always better.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
(unknown member) Senior Member • Posts: 1,001
or the opposite...
Steveus Forum Member • Posts: 84
7
I'm an amateur, so the 100-300 is my first long zoom lens ever. Previously I had the 45-150. At first I wasn't pleased with the 100-300 but I quickly realized two things.
First, it's challenging to use without good technique and optimized settings, so you need to practice. Especially handheld for moving subjects. Second, it really needs direct sunlight to achieve maximum sharpness (low ISO, high shutter speed); even on a cloudy day you can start to get noise and blur.
Keep in mind that I'm generally talking about shooting at 300mm, moving subjects, handheld, and then cropping on top of all that. So I'm asking a lot from such an inexpensive lens. My conclusion is that it mostly delivers under ideal conditions.
Here is the ubiquitous (cropped) moon photo that I think makes a good test for long lenses:
This is about the best I could do with at 300mm with tripod, remote shutter, etc. YMMV.
EDIT: you know I just realized that if you were just in it for the max zoom, for about the same price as this lens, you could get a Nikon P900 and get better results more easily.
phil from seattle
JoostL wrote:
or the opposite...
LOL!!  Especially those on a jihad against a certain lens.
OP JosephScha Veteran Member • Posts: 7,249
I hope someone takes a picture of the moon with a P900 and posts it here.  I'm not at all sure it would be better.
js
Well there was a thread about this exact topic on this very forum a few days ago. But it's a mess:
https://www.dpreview.com/forums/thread/4280884
Unfortunately the thread got a lot of people's knickers in a bunch but looked at objectively I think it's pretty clear that the optics of a 2000mm equivalent zoom outweigh all the other factors in m43's favor at 600mm equivalent.  Given it's price point, the P900 is very good at one thing only: huge zoom.
It's hard to find apples-to-apples comparison between the P900 and the Panny 100-300ii lens, but I know for sure my Panny can't do this, in video mode:
https://www.youtube.com/watch?v=Clg7rQB6H2U
There are dozens more examples of the P900's zoom capabilities easily found online.  I'm not saying it's a better camera, but I am saying that it will do a better job zooming to 2000mm equivalent than taking a photo with the Panny100-300ii and cropping to 2000mm equivalent.
JoostL wrote:
or the opposite...
... because it makes so much sense  to spend twice as much and carry twice as much for the same results!
Barney1946 New Member • Posts: 7
The professional consensus is no faster than 1/300th for propeller aircraft in flight.
 Barney1946's gear list:Barney1946's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
Mzro Forum Member • Posts: 81
I've bought g9 and want to get into amateur wildlife/bird photography Unfortunately, I can't currently afford olympus 300mm pro or panasonic 100-400mm lens. Is this lens will be a good buy as a starter or should start saving for top-tier lenses?
 Mzro's gear list:Mzro's gear list
Olympus OM-D E-M10 II Panasonic Lumix DC-G9 Olympus OM-D E-M1X Panasonic Leica 200mm F2.8
Androole Senior Member • Posts: 1,455
Here's the moon shot in that thread from the P900:
https://3.img-dpreview.com/files/p/E~forums/56410076/eea02f8da8fe4e4287de16d3d3323906
I'm pretty confident that yours has just as much real detail. The P900 has more pixels, but when you zoom in its mostly mush, whereas your crop is decent at the pixel level.
 Androole's gear list:Androole's gear list
Olympus Stylus Tough TG-850 iHS Panasonic Lumix DMC-GX7 YI M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +2 more
Serguei Palto Senior Member • Posts: 1,015
7
Below is Moon taken with OMD EM10 and f=1000 mm telescope.
(unknown member) Senior Member • Posts: 3,290
I have had the original mega ois for many years and i understand the optics are the same as in the mark2 ( but obviously sealing and ois are uprated )
Because m43 is now not my main kit, I decided to keep it as a lighter weight system and sold my em1.1, oly pro 40-150 but have started to use the 100-300 again - I use longer focal lengths a lot and not just for action / wildlife.
I would agree that it is underrated and, for me, since I only print or view to A4 ish, then it does a really good job.
Reviewing some photos I took 3-4 years ago with it and my em5.1, and which i was not happy with at time, I realise that  most of the problems were down to bad technique eg unrealistic expectations of the early ibis or mega ois or shutter shake etc.
Just trying it again, I am really happy with it but might get the mark 2 and poss a em5.2 or a pan sometime.
Incidentally, i did have the 100-400 for a short time ( it had a bayonette failure and i decided not to replace it).  It is obviously sharper than the 100-300 thru most of their common range but the lower weight, size, cost and the resolution i actually need makes the use of the 100-300 the best choice for myself.
richard
richard
I also have the original 100-300. This lens is indeed underrated. The main reason is that proper technique and knowledge on the lens sweet spots are important. At the long end it is quite sensitive to the shutter-induced vibrations (E-shutter solves the problem). I have also found that the OIS can result in loosing the resolution, so I prefer using the IBIS of my OMD EM 10II.
grcolts Veteran Member • Posts: 3,914
Ditto for me too!
magnesus3 Contributing Member • Posts: 642
p900 lens is 4.3-350mm so technically it is also cropping to 2000mm equivalent. Given higher resolution sensor and very sharp lens (300mm f4 comes to mind) it should be doable to match it on m43 in the future, when denser sensors arrive.
Like your shots - the second especially.
Looking at the loads of pics posted on this forum, flickr etc etc, I conclude that it does a really good job at producing images with, and its a personal view, a resolution and rendering that are fine for what I want.  Certainly if you put it up against the 100-400 or even the Nikon 1 CX70-300 and start zooming then the differences are apparent but not relevant to me in my real world usage.
No problem in throwing it, with a few smaller m43 lenses, into a small bag to take out 'just in case'.  It is really compact.  Also the reason I got rid of the 40-150 pro - superb lens but just a bit too big and heavy for light kit and I ended up not using it:  taking a DSLR and a 100-400 out instead if I specifically needed that range.
I am still fiddling around with IBS/OIS settings as well as aperture to get the best out of it. Part of the reason for considering an em5.2 or maybe a em10.x is the better ibis on the later cameras. I might pop into my local camera shop and try the Mark 2 out with a modern Pan body to see what difference the dual IS makes.
richard
richard
I am Agree with you regarding Pana 100-400 and OLY 40-150. These two lenses are indeed very good, but not so compact as Pana 100-300. The only drawback of Pana 100-300 is that, at long end (f=300mm)  it is a bit soft at f/5.6.
A few years ago I had tryed Nikon 7100 with 70-300 mm. I spent a lot of time for testing and comparison the Pana and Nikon. The rsult - I was very disaapointed by both the Nikon lens and camera ( D7100). Below are two crops of the same object captured with the two lenses (the distance to the object is of about 100-120 m).
Pana 100-300 really shines in this comparisson despite, as I said, Pana at 300 and f/5.6 is not good enogh to my criteria.
In general m43 lenses are underrated, the peaple do not take into account that they are designed for much higher pixel density compared to those for FF systems.
image from Nikon D 7100 and 70-300 f4.5/5.6 lens
Image from OMD EM10(I) with Pana 100-300 (I)
