Fixed wide angle recommendations?
Started May 11, 2018 | Questions
Seamus42 Forum Member • Posts: 70
I keep reading conflicting reviews, so I'll see if I can solicit some more! In my work life, I've got an annoying gap in the lens collection. I have a bag full of vintage primes for my non-work material, but for work I tend to use just three lenses: Oly 45 1.8, Oly 40-150, and Oly 14-42. It's quite clear which of these is the underperformer. I work in a college communications department, and I'm heavy on the portraiture and event coverage.
I'd love to get that 14-42 out of the mix, and replace it with a better wide angle. I'm doing this on my own dime, and right now I can't spend enough to get one of the nicer wide zooms. I've heard lots of different things about the Panasonic 14 2.5 and the Oly 17 2.8, which are both within my price range. That's making it tough to choose.
Any recommendations on those or other wide angles on the cheaper side?
 Seamus42's gear list:Seamus42's gear list
Olympus OM-D E-M10 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro +15 more
Panasonic Lumix G 14mm F2.5 II ASPH
jalywol
jalywol Forum Pro • Posts: 12,302
Re: Fixed wide angle recommendations?
5
If you want a prime, and not a zoom, the Panasonic 14mm is a nice lens. I really enjoyed mine when I had one.  The Oly 17mm f 2.8 is not particularly wide, and definitely the weaker of the two.
If you want a less expensive wider lens that will definitely outperform the Oly, consider the Panasonic 12-32mm f3.5-5.6.  It's quite a nice little zoom, and will give you much better output than the 14-42mm that you have.  No, it's not fast, so not the best choice for low light, but otherwise it's about the best budget wide in the line.
-J
phil from seattle
phil from seattle Veteran Member • Posts: 3,699
Well, it's too bad you can't spring for the 12-40Pro. Awesome lens but I will leave it at that.
A lot depends on what you are shooting. I would probably go for the wider of the 2 lenses. Though if it were me, I'd look closely at a 12mm lens. There are a bunch of 12mm manual focus lenses for very little money.
By the way, do you mean the Oly 17mm f/1.8? I don't see a 2.8 for sale at B&H? I have the 1.8 and like it a lot.
 phil from seattle's gear list:phil from seattle's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
OP Seamus42 Forum Member • Posts: 70
Thanks! How does the 12-32 compare to the 14?
I wouldn't mind a zoom at all-- I'm primarily interested in an upgrade in sharpness in the wide angle range that I can afford. The 14-42 just ain't cutting it when I look back at my images.
I would spring for that if I could justify it. That's what I'd really like to have!
Where I end up needing this is in covering indoors events, and also shots outdoors that, at least with wide angle, incorporate the lovely Vermont hills all around our campus. A 12 would do the trick too, I suppose, so if you have recommendations, I'd love to hear them. Thanks!
jalywol
Hard to say about how the 14mm and the 12-32mm compare, as I didn't own both of them at the same time. The 14mm did have some significant vignetting wide open, which was, I think, its only flaw.
I will say that the 12-32mm is really a nice lens, though, very good color, good sharpness, not heavy vignetting; a surprisingly good lens without being expensive. Let's just say that I never used the Oly 14-42mm when I had one, as I really disliked its output, and I use the 12-32mm all the time, and have never been disappointed in it. No, it's not the 12-35mm f2.8, which I also have, but it comes surprisingly close to that higher end lens in many situations.
One thing; that extra 2mm on the wide end doesn't sound like much on paper, but in real life situations, it's quite significant. I find I tend to shoot at 12mm fairly frequently, especially in urban situations or for architectural settings, and the 14mm is just not quite as versatile for these uses.
If you do want a wide prime, you may also want to look into the Samyang/Rokinon 12mm f2.0 .  It's a manual focus lens, but it gets good reviews and is a lot less expensive than any of the other 12mm options in M43.....
-J
homestar_kevin
homestar_kevin Junior Member • Posts: 31
I really like the 14mm.
I bought it a long time ago to use on the Black Magic Pocket camera and have just kept it around ever since.
It's recently had new life breathed into it by adding a sony wide angle converter (VCL-ECU1) to effectively make the 14mm a 10.5mm, which is great.
Chas2 Veteran Member • Posts: 3,715
Agreed
I used my 12-32 as if it were a small 12.  I rarely zoomed it. So I my little "prime" Trinity was 12 20 and 45 and it was quite satisfactory. Then I went to Europe and used it as an excuse to get a 12-35/2.8. I don't use the 12-32 much any more but if I didn't have the 12-35? Probably would use the 12-32 all the time
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
Lu1Wang
Lu1Wang Senior Member • Posts: 2,287
A good wide angle prime would costs almost as much as the Oly 12-40 Pro, and are normally not weather sealed, and a lot less versatile. 12-40 Pro can be bought used for very reasonable price, and it's one of the best lens in the system. Sharp at all ranges, useful function button, MF clutch and very short close focusing, a truly do it all lens.
 Lu1Wang's gear list:Lu1Wang's gear list
Olympus E-M5 II Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +9 more
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
I've owned or used both 17s, the 12-32 and the 14. Based on your description of use, the 12-32 is probaby your best option, with good range and IQ at what are now fair prices. I got mine when they were new and more costly ($300 us for a dekitted one) and it was worth it to get the 12mm wide end in a small package. The standard lens on my EPM2 for past 3 years. Not perfect but much better than the 14-42iir.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
tjuster1 Senior Member • Posts: 2,241
I own the 12-32mm and 14mm (for the second time), and have also had the 17mm f/2.8.
The 17mm f/2.8 is probably one of the worst lenses in the m43 lineup, its main virtue being its pancake size. But it's not particularly wide-angle, not particularly sharp, and not really exceptional at anything except being small.
Of all of these, I think I like the 14mm the best. I sold it once in a fit of downsizing (numbers, not lens size!) and then promptly bought another copy when I saw how much I missed it.
The 12-32mm is great, but it's a zoom lens and isn't as fast. And there's simply something I love about the images from the 14mm that keeps me coming back to it. It's also the tiniest darn thing you can mount on a m43 camera short of the Oly bodycap lenses (which are dreadful, in my estimation).
 tjuster1's gear list:tjuster1's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 III Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +6 more
This seems to come down to the Panasonic 14 or 12-32. Faster would be a nice thing, but at 2.5 versus 3.5 at the wide end, I can hang with either. So, all other pros/cons aside, which is sharper? I'll go peruse some images for sure.
I think the Oly 45 has ruined me! I love what I get with it, and it makes everything else seem a touch shabby in the IQ department.
rashid7
rashid7 Veteran Member • Posts: 7,011
i m a HUGE advocate of the samyang/rokikon fisheye!
Keep it fun!
So I'm pretty much down to the 14 or 12-32 anyway, but what of the Olympus 12-50? Just found a used one near me that's at quite a tempting price. I know little about it, though.
JakeJY Veteran Member • Posts: 5,442
I saw a listing for the 12-50mm for $99 also, which is quite a deal given the lens retails for $500 new. Much bigger lens than either though. It has a longer zoom range and EZ (useful for video). Also has a focus ring.
I presume you know this already, but I should mention the 12-32mm does not have a focus ring. There is no way to manual focus the 12-32mm on an Olympus body (newer Panasonic bodies can manual focus the 12-32mm using touch screen). Might not matter much though if you mainly use AF.
From the imaging resource test results, in terms of sharpness the 12-32mm beats the 12-50mm throughout the entire zoom range. 12-50mm also has extreme amounts of CA at 12mm. However, 12-50mm appears to still be sharper than 14-42 EZ.
https://www.imaging-resource.com/lenses/panasonic/12-32mm-f3.5-5.6-asph-mega-ois-lumix-g-vario/review/
https://www.imaging-resource.com/lenses/olympus/12-50mm-f3.5-6.3-ez-m.zuiko-digital-ed/review/
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Thanks for all the info. Very helpful!
I also had the 12-50mm, briefly. The previous post pretty much sums it up--it's HUGE (compared to the other two lenses you're considering), and it's a CA farm at wide apertures. If you lay it next to the 12-32mm you'd burst out laughing to see the difference in size:
As to the difference in sharpness between the 14mm and 12-32mm, I think it's pretty darn close. I wouldn't choose one over the other just for that reason. The 14mm has a slightly different character that I prefer, maybe due to the slight blurring you can get in the background on shots wide open.
Paulmorgan Veteran Member • Posts: 9,499
The type of work you are doing is not particularly difficult or challenging provided you can understand and use flash.
Personally I would stick with a zoom, Panasonic or Olympus would do , if on a real tight budget try the 12-50mm, those extra couple of mm`s at the wide end make a real difference, I`ve seen these going for as little as 100 bucks.
Try a little harder and even that 14-42 could be better than it already is.
Well, I largely agree with what you say regarding flash, but what happened to me today is indicative of just how little difference that makes at times. Today, I covered a graduation -- indoors, in a very dimly lit auditorium. I was one of two photographers. We compared notes, and we were both shooting at a minimum of 3200. And that was WITH flash. But because of the tight spacing, much of the shooting had to take place at a distance that made flash useless. And the ceiling was probably 40 feet up, so no bouncing could happen in that direction. It's usually not very challenging work, I agree (and didn't mean to claim otherwise), but this was quite hard.
The other photographer found a smart solution for part of the ceremony where every subject would be in exactly the same place -- she bounced at a weird angle on a nearby wall. But where I was? No dice.
And I can tell you I was aching for something other than my 14-42, which was giving me far less than what I needed in terms of ability to resolve faces at a distance. I am not entirely sure what trying harder might have looked like. I do believe equipment is only as good as the person behind the camera and their eye, but today was a perfect example of not having the tool that would have made for better results. That said, I got a few shots I like. Mostly, however, the ones that I got with a 45 1.8.
Like this one. It will get more PP attention, and yes, it has its demerits, but under the circumstances, I'll take it:
A common mistake I see a lot with bounce flash users is that when using a wide angle lens and bouncing they let the flash decide on the position of the head then try and bounce of a fairly high ceiling, a lot of flash units default to a position of about 50mm but for bouncing its often better to manually set the flash to it max telephoto setting for less wastage and more coverage and less of a need for high ISO`s.
For large groups indoors a single flash unit might not be enough anyway, you might be better off with several heads.
I try to avoid bouncing whenever I can, flash benders are good when not shooting larger groups, flash then becomes far more effective when shaped and controlled and it gives you a little more range.
