Photos from Shuttleworth Season-Premiere Airshow
Started May 11, 2018 | Discussions
Barry Pearson
Barry Pearson Veteran Member • Posts: 9,625
12
This airshow was on Sunday 6th May.
Shuttleworth Collection website
Shuttleworth Collection at Wikipedia
I'll soon post here about 10 photos of aircraft taken at the airshow. (I won't show photos of the visiting jet). Here was the running order:
I thought this scene was interesting, even though it is not an aircraft in flight:
This is my favourite photo from this airshow:
The next post in this thread will show about 10 photos of aircraft in flight.
Later I'll post photos of some of the ground vehicles of the Collection.
And I'll add some notes about technical matters such as camera settings and software used.
 Barry Pearson's gear list:Barry Pearson's gear list
Ricoh GR III Canon EOS R5 Canon EOS R7 Venus Laowa 12mm F2.8 Zero-D Canon RF 70-200mm F2.8L IS USM +28 more
Barry Pearson
OP Barry Pearson Veteran Member • Posts: 9,625
A few photos of aircraft in flight
7
I took about 2000 images of aircraft in flight. I'm struggling to reduce these to a manageable number.
I chose the ones below because they mainly show the tops of the aircraft and/or the pilot.
They are roughly in the running order identified in the original post of this thread.
DDoram
DDoram Forum Pro • Posts: 10,365
Re: A few photos of aircraft in flight
Hi Barry:
Nice to have you back.  Thanks for sharing your collection of excellent K1 photos; you are showing that the K1 can be used for sports.
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
Barry Pearson
Equipment, settings, and software
I used my K-1 with its battery grip. I used it hand-held all day.
(I also carry a Panasonic Lumix LX100 as a sort of "digital notepad". The running order  blackboard shown in the original post was taken with that camera).
For photos of the vehicles of the Shuttle Collection, I used the D FA* 24-70 f/2.8. (I'll post some of those photos in a day or two).
For photos of aircraft in flight, I used the D FA 150-450, which has been my normal "things in flight" lens for years.
DNG. (I mainly use Sandisk Extreme Pro, either 32Gb or 64Gb).
TAv. I care a lot about the shutter speed and aperture, but I hardly care at all about the ISO.
AF-C Spot. My K-1 is nearly always set to use just the centre AF-point.
"High-speed" (hm!) burst mode, typically used for about 4 shots at a time for aircraft in flight. (I don't used crop-mode, which would increase the burst rate).
All DNGs are imported into Lightroom CC. (I try to reject and delete most of them!)
All photos being posted in this thread have been processed in Photoshop CC. (The main reason was to mitigate panning issues at the slow shutter speeds used to get propeller-blur. I'll post more about this).
(I've probably omitted something important here!)
MightyMike Forum Pro • Posts: 41,691
Very nice Barry, Thanks for posting
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Barry Pearson
Panning problems and mitigation
In order to achieve propeller-blur, I try to use a shutter speed of 1/320 or less for such aircraft. That means I have to pan accurately.
(For gliders and jets I use much higher shutter speeds. For helicopters, somewhat slower).
This airshow was a bad day for panning! From when I arrived at 09:00, I was on my feet nearly all the time. It was hot with hardly any wind.
The air display started at 14:00. By the time the most interesting aircraft appeared hours later, I had been on my feet and active for more than 7 hours, and taken about 2000 images, hand-holding a heavy camera and lens.
I'm a weedy 71-year-old! By that time, I was mentally and physically zapped. My panning had gone down the pan!
(I'm ketogenic and metabolically flexible, so I didn't need to snack to keep up my energy. But I may have been a bit dehydrated).
The main reason for deleting photos since the airshow has been bad panning. Even some of the better photos were not up my past standard.
Therefore, for all photos of aircraft in flight in this thread, I've used Photoshop's Filter > Sharpen > Shake Reduction. It isn't magic, and sometimes it goes a bit weird, but it has probably doubled my "sharp enough to publish" rate.
It has sometimes even managed to squeeze out a tiny improvement in photos which I would have been happy with.
(I'm still learning how to fine-tune it, and how it relates to IBIS, etc. Also, I need to experiment with combinations of Lightroom's sharpening and this Photoshop feature).
AviPro
AviPro Senior Member • Posts: 1,254
Re: Panning problems and mitigation
Wonderful photos, very nice details and color. It is a treat to see all of this.
Thanks for all the details of how you photographed them, very good learning for me. Interesting that you mention you are not worried about ISO, nor the weight of k1+f2.8 lens, .. yes they all look great !!
 AviPro's gear list:AviPro's gear list
Pentax K-5 II Nikon Z5 Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +1 more
Barry Pearson
A couple more photos that I've tweeted
I've tweeted these photos to the Battle of Britain Memorial Flight (BBMF), the Shuttleworth Collection, and Lisa Harding who is a keen photographer and artist of the BBMF:
https://twitter.com/RAFBBMF
https://twitter.com/Shuttleworth_OW
https://twitter.com/SketchLisa
It is only fair that I show them here too!
My Twitter account is: https://twitter.com/BarryCPearson
philzucker
philzucker Forum Pro • Posts: 10,390
Thanks, Barry, for the detailed explanations (very helpful) and your fine pics!
Forgot about that one - thanks for the reminder, will have a look at it!
Phil
ozdean
ozdean Forum Pro • Posts: 28,665
Top stuff Barry!
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 70mm F2.4 AL Limited +14 more
Barry Pearson
A few photos of old vehicles in the Collection
(This will probably be the last set of photos I post to this thread. I have two more "aircraft in flight" events this weekend, 19th and 20th May, and I expect to start a new thread or two for those).
The Shuttleworth Collection isn't just about aircraft. It is also about cars, bikes, buses, military vehicles, agricultural equipment, etc. Like the aircraft, they are lovingly preserved and mostly in good working order. And ridden or driven by enthusiasts!
Here are just a few of them. These photos has no photographic merit. The vehicles at this time were on a path among the spectators, and extracting them in Photoshop would have been more trouble than it was worth.
I love events at the Shuttleworth Collection! I'll be there several more times this year.
Shivaess
Shivaess Contributing Member • Posts: 524
So the motion blur sharpening is pretty ridiculous... Thank you very much for the reminder!
 Shivaess's gear list:Shivaess's gear list
Pentax K-1 II Pentax FA 150-450mm F4.5-5.6 Pentax FA 15-30mm F2.8 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 +3 more
DAVID MANZE Veteran Member • Posts: 6,390
Nice series Barry.........what shocked me more than anything is the great weather you had............
.........in England?
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 85mm f/1.8D +17 more
Barry Pearson
I got sun-burned on the back of my right hand! It's currently peeling.
(I normally take care because I burn easily, but that is a region I forgot).
I have 2 events booked for this weekend: an evening shoot on Saturday and a Air-to-Air shoot on Sunday. The weather report is good for both days.
Dave's clichés
Brentliris Veteran Member • Posts: 4,196
Re: A few photos of old vehicles in the Collection
Lots to like here. Thanks for the great images and the good information.  I'll visit the Shuttleworth collection when they have similiar events in the future.
Brent
Reflections, understandings, discoveries and intimations..
 Brentliris's gear list:Brentliris's gear list
Pentax smc DA* 55mm F1.4 SDM Ricoh GXR Mount A12 Ricoh GXR S10 24-72mm F2.5-4.4 VC Pentax K100D Super Pentax KP +19 more
rmalbers Contributing Member • Posts: 529
Re: Photos from Shuttleworth Season-Premiere Airshow
FWIW: I was at an airplane museum this winter and there were several planes that were yellow in color, I found out they paint the planes that they used to train pilots in yellow.
Barry Pearson
Yes, that is common. If I see yellow, I typically think "pilot training".
It isn't universal. I'm not sure why. Perhaps when training beyond basic level they use colours that are more relevant to the extra experience being gained?
