M10 with adaptor and canon EF 75-300
Started May 11, 2018 | Discussions
Sruthika New Member • Posts: 9
A Photography trip yesterday with the below gear (M10 with EF 75-300)
Below are pictures captured using the gear.
Actual image and cropped image below
Actual image and cropped below
Canon EOS M10
Jozef M Senior Member • Posts: 2,197
Re: M10 with adaptor and canon EF 75-300
Are you happy with the IQ?
I would not, the photos are all out of focus, I should use a tripod and try again.
Jozef.
 Jozef M's gear list:Jozef M's gear list
Sigma DP3 Merrill Canon EOS 30D Panasonic Lumix DC-G9
jboyer
jboyer Senior Member • Posts: 1,373
Jozef.
I am not sure these are OOF. I can see some chromatic aberration (CA), along with a general softness of the pictures.
This is the equivalent of a 480mm - quite long to use without a tripod and at full overture. As Jozef suggested I would try a tripod AND shoot at f/8 to gain some sharpness and DOF. At max zoom, CA will be significant, no matter what.
You may also want to play with the Picture Style to increase the sharpness of the JPGs.
 jboyer's gear list:jboyer's gear list
Canon EOS M100 Canon EOS M50 Canon EOS RP Canon EF 50mm F1.8 II Canon EF 100-400mm f/4.5-5.6L IS USM +8 more
OP Sruthika New Member • Posts: 9
Jozef.
No I am not happy with IQ. I also would appreciate any suggestions to get better zoom quality with the same setup.
adventurer69
adventurer69 Senior Member • Posts: 1,938
That lens is not the exactly the sharpest at the long end , quality drops of quickly at anything longer the 135mm . I gave away my 75-300 a long time ago .
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
Thank you for the reply. Will be buying the 100-600 soon. Can I use the canon 100-600mm on the M10?
Jozef.
Thank you for the reply. Will try with tripod in the next few days with the settings suggested. Will post the new photos.
I also have another query. Should I change the camera body to something like a 660D? Will that improve the picture quality with the same lens?
noneoftheabove Regular Member • Posts: 100
I had that lens with a 40D and for similar results for wildlife photos, so I'd suggest it is the glass letting you down. I switched up to a Sigma 120-400 OS and it was substantially better.
The other suggestions about playing with aperture and using a tripod would also help overusing technique.
Before getting new glass I'd suggest really being certain what you want it for, as some kit is ok handheld, and you may want something faster for moving wildlife.
 noneoftheabove's gear list:noneoftheabove's gear list
Canon EOS M50 Canon EF 50mm F1.8 II Sigma 10-20mm F4-5.6 EX DC HSM Sigma 120-400mm F4.5-5.6 DG OS HSM Canon EF 24-105mm f/4L IS USM +3 more
adventurer69
you can try the EF-S 55-250mm .
R2D2 Forum Pro • Posts: 26,528
The first thing I'd suggest is to get out of Auto Mode.  That way you can select a single AF point and focus on exactly what you want.  Otherwise the focus will end up all over the place (as is evidenced in your samples).
It can also be very difficult to hold the camera steady when there is no viewfinder.  Even though most of your shutter speeds were pretty high, I think that camera shake was likely a factor too (esp without image stabilization).
Also, I'd test your lens at f/8 to see if sharpness improves.  There's always a battle between shutter speed and aperture!  See which one wins.
Lastly, I like the suggestion to check out the 55-250 IS STM.  You'll gain both sharpness and stabilization.  It's often found at a great discount at the Canon Refurb store.
Best of luck!
R2
P runar Regular Member • Posts: 361
i hawe mised focus many times on the m10 in 1-point AF and had more keppers in face+ Tracking,,,  vs my m[1] is best in 1-point-AF.  ,,  the m10 is mising focus more in 1p af
mabye it is diferent on som other lenses ?
 P runar's gear list:P runar's gear list
Canon EF-M 32mm F1.4 Canon EOS M Canon EOS M50 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM +4 more
Thank you for the reply. Will check out the lens today.
Best of luck!
R2
Thank you for the reply. I agree with you camera shake was a big factor as all my shots are hand held. Going in one hour to try the following :
1) Use a tripod to avoid camera shake
2) Use my iphone as a remote shutter via wifi to reduce camera shake also
3) Use manual mode
4) USe f/8 to see how the image improves
5) Will look for an EF-S 55-250 IS STM
Just a quick update after all of you helped me
The main issue was with focussing and I realised that I have to use touch focus with Single point AF to get good shots. Now I am getting better image quality. The below image is at 300mm zoom.
Errrrm...
