Canon Rebel 300D using a IR filter!!!
Started May 8, 2018 | Discussions
Deviantfotografer
Deviantfotografer Senior Member • Posts: 1,003
Hi everyone, thought I would share some pictures using IR Filter.....
I have looked mon the web and cant get an easy answer... What is the workflow for doing a IR image???? Can anyone help me??? Thanks and just bare in mind these are test shots, not very interesting images!!!
Jarrod M Campbell
Check out my BLOG @:::
www.jarrodcampbell.me
 Deviantfotografer's gear list:Deviantfotografer's gear list
Kodak EasyShare P880 Olympus FE-180 Olympus C-5060 Wide Zoom Sony Cyber-shot DSC-R1 Canon PowerShot SX130 IS +20 more
Canon EOS 300D (EOS Digital Rebel / EOS Kiss Digital)
mdmarqphoto Senior Member • Posts: 1,460
Re: Canon Rebel 300D using a IR filter!!!
It depends on what kind of IR images you want.  It's best to use a modified camera but it can be done with just a filter in some cases (non-moving subjects and on a tripod).  You'll want too set a custom white balance, often something green such as grass will work best.  Then in post you have the choice of converting to black & white or leaving it in color (depending on the filter, you may not really have color as an option).  If you leave it in color, the common practice is to swap the red and blue color channels and then adjust from there.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
