Mandatory Noise Reduction (NR) in Various Pentax Cameras
Started May 7, 2018 | Discussions
bclaff Veteran Member • Posts: 9,841
26
At PhotonsToPhotos I detect signal processing, usually Noise Reduction (NR), using 2D Fourier Transforms (2D FTs).
This mosaic illustrates the whole stop results for the K-1 II:
The first three stops are mostly random and indicate little or no signal processing; all other higher ISO settings show significant NR.
In viewing the Read Noise the NR causes a drop that looks like Dual Conversion Gain but is not:
Note that the down-triangle symbol indicates NR
You can use the interactive chart to see where other Pentax cameras start NR.
In general Pentax often starts NR at a much lower ISO setting than others.
Here's a comparison with a camera that does have Dual Conversion Gain and then later, at a much higher ISO setting, starts NR.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Pentax K-1 II
Iliah Borg Forum Pro • Posts: 27,296
Re: Mandatory Noise Reduction (NR) in Various Pentax Cameras
Hi Bill,
If you still have K-1 original shots, could you compare the level of banding (first 3 stops, vertical line on FTs) between K-1 and K-1 II?
LensBeginner
LensBeginner Contributing Member • Posts: 619
So the pictures go:
first row ISO100÷1'600
second row 3'200÷51'200
third row 102'400÷819'200
is that correct?
 LensBeginner's gear list:LensBeginner's gear list
Pentax K100D Super Pentax K-01 Pentax K-30 Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc DA 40mm F2.8 XS Lens +2 more
OP bclaff Veteran Member • Posts: 9,841
LensBeginner wrote:
So the pictures go:
is that correct?
Yes
LensBeginner
bclaff wrote:
Yes
TY.
Here you go:
K-1 is much cleaner (ISOs are in the same locates as the K-1 II image)
However, I wouldn't interpret the slight vertical line as banding; this could easily be a small gradient accentuated by the FT wrapping.
Regards
Here you go:
Thank you.
I checked, and small blurring along the vertical line removes it, not to mention the banding is quite visible on green channel for example. My impression is that banding on K-1 II may be more pronounced than on K-1, and that may have caused the need in noise reduction (or, a not very successful attempt to remove banding using optical black).
Iliah Borg wrote:
...If you still have K-1 original shots, could you compare the level of banding (first 3 stops, vertical line on FTs) between K-1 and K-1 II?
Here is something from the PhotonsToPhotos Sensor Heatmaps:
Lower "metrics" are better; zero would be perfect. Note that the table columns are sort-able.
Both the visual, and the numbers (highlighted), show an increase in row Fixed Pattern Noise (FPN).
It's unclear whether this measurable difference is photographically relevant.
Regards
Here is some preliminary Photographic Dynamic Range (PDR) information:
The K-1 II measurements are worthy of publishing on the site yet but this is substantially how it will look.
Prognathous Veteran Member • Posts: 9,311
Interesting results, thanks for posting.
Is this something Pentax can fix in firmware update?
 Prognathous's gear list:Prognathous's gear list
Sony a77 II Tamron 18-270mm F3.5-6.3 Di II PZD Tamron SP AF 60mm F2 Di II LD IF Macro Sony DT 16-50mm F2.8 SSM Olympus Stylus 1s +13 more
6
I would think so but I suspect they don't think of it as broken.
MightyMike Forum Pro • Posts: 40,357
So bottom line this for me, We all knew added mandatory NR was coming, how much worse is this than ordinary post processing NR? Where would we see negative effects other than ever so slightly weaker sharpness, contrast and resolution?
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
I don't have a good objective measure.
I can say that the 2D Fourier Transforms (2D FTs) show more pronounced processing that is usual.
I suspect this is very aggressive Noise Reduction (NR); that would imply more than usual destruction of detail.
To support my statement of more pronounced processing here are the 2D FTs for the Nikon D90:
D90 2D FTs whole stops starting at ISO 100
This more subtle loss of randomness with the white center and corners/edges is typical of the Noise Reduction (NR) I tend to see.
The Pentax 2D FTs are as extreme as I have seen.
brett nz
brett nz Contributing Member • Posts: 532
Thank you for posting :) NT
 brett nz's gear list:brett nz's gear list
Pentax K-1 Pentax smc FA 77mm 1.8 Limited Pentax smc FA 31mm F1.8 AL Limited Pentax FA 15-30mm F2.8 Pentax FA 70-200 F2.8 +1 more
Piotr Krochmal New Member • Posts: 1
Re: Thank you for posting :) NT
Thank you for testes. I hoped that AUnit working other way. I that case I spend my money on lenses Shame on you Pentax
barbakane
barbakane Forum Member • Posts: 97
All I know, which isn't much, is if I like a shot or not. I'm from the film days so noise, at least for me, goes with the territory, I ain't gonna overthink it. I do however applaud the dedication and effort needed to get to these results.
Ian Stuart Forsyth
Ian Stuart Forsyth Veteran Member • Posts: 3,643
Just out of curiosity have you done any testing on ether of KP or the K70 as to whether or not they use Dual Conversion Gain and would this explain some of the improvement to noise we see from both those cameras?
This may explain as to why Pentax has decided to use a heavy handed NR with the K1 and the dated sensor so that it would appear as to keep up with the maybe newer sensors found in the KP-K70. The release dates of the KP and K70 could hint to the performance gain seen is from DCG and not the new chip NR chip found in all 3 cameras.
I would find it odd if the Kp and k70 had DCG that pentax would implement any NR to those raw files and especially bellow iso 1600
The Camera is only a tool, photography is deciding how to use it.
The hardest part about capturing wildlife is not the photographing portion; it’s getting them to sign a model release
 Ian Stuart Forsyth's gear list:Ian Stuart Forsyth's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Pentax K-5 Pentax *ist DS Pentax K10D Pentax K20D +26 more
Lage New Member • Posts: 18
Bill, the K-1, and i assume the K-1 II, have menu options for setting noise reduction for long exposures and high ISO.
What was the settings during your tests?
BR,
Lage
LightBug Senior Member • Posts: 2,439
Noise reduction != loss of detail
Signal processing may have been done, but that does not mean it’s a bad thing.  Looking at DPR’s K-1ii review’s scene comparison, focusing on the fine text above center (since we know the review lens was not sharp across frame), I cannot spot any so called loss of detail in K-1ii claimed by DPR at any ISO when comparing against K-1.
 LightBug's gear list:LightBug's gear list
Pentax Q-S1 Sony a7R Pentax K-70 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 40mm F2.8 Limited +19 more
