K1 ll review is up and I think that..
Started May 7, 2018 | Discussions
robgendreau Veteran Member • Posts: 5,878
Re: K1 ll review is up and I think that..
Mark Ransom wrote:
Alex Sarbu wrote:
tassosDA wrote:
It doesn't look very good...
I agree.
I'm surprised that I can see a difference in detail even at ISO100 (in selected areas). They're using different lenses, but the D FA 50mm (on the K-1 II) should be sharper than the FA 77mm (on the K-1)?
The lightning (maybe that's because of the different camera to subject distance) is different, too. Not sure if it would influence the "grass" patches.
Where does it say which lens is used? I had trouble finding that information. Did they use a pre-production sample of the new F/1.4 or the old macro F/2.8?
Chris Mak noticed a similar shortcoming on the KP vs. K-3 over at PentaxForums.
It was in the EXIF, at least for the studio scene shots I downloaded.
“Art is not what you see, but what you make others see.”
— Edgar Degas
 robgendreau's gear list:robgendreau's gear list
Pentax K-1 II Pentax FA* 50mm F1.4 SDM AW
Alex Sarbu Forum Pro • Posts: 10,019
Mark Ransom wrote:
Alex Sarbu wrote:
I agree.
There's an 'i' label right after the Download links (in the image widget), you can hover the mouse over it. But not for the K-1 II - I downloaded the RAWs and had a look at the EXIF.
Yes, it's the old f/2.8 macro.
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +8 more
Alex Sarbu wrote:
I agree.
Alex
Hmm... there's some doubt that DPReview botched the test (it wouldn't be the first time). The cards appear to be slightly out of focus... naturally, the "grass" patches would have lower detail.
Alex
Greyser Veteran Member • Posts: 6,055
I supposed to upgrade ASAP. It looks like I better keep original K-1 for now.
 Greyser's gear list:Greyser's gear list
Nikon D500 Nikon D850 Sigma 500mm F4 Sport Nikon 500mm F5.6E PF
OpticsEngineer Veteran Member • Posts: 6,492
16
I am just wondering why DPR describes a Nikon D850 as "not a petite camera" but the smaller Pentax K1 II is called "large and obtrusive."
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +23 more
For the same reason it's Pentax' Pixel Shift that can be replicated by stacking, and not the Sony's
By the way:
https://camerasize.com/compare/#773,718
Alex
Ari Aikomus
Ari Aikomus Veteran Member • Posts: 9,345
...but a great opportunity to save some money!
Yep. A kind of big disappointment. What a pity...
On the other hand, we already have excellent K-1 original. No one is forced to "upgrade"...
Ari
- Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
Ari Aikomus
Yes, indeed. That was funny part. Nonsense from DPR
Ari
By the way:
Alex
- Ari Aikomus -
zakaria
zakaria Veteran Member • Posts: 4,585
The "BUT" review!!!
pentaxian .
 zakaria's gear list:zakaria's gear list
Nikon D750 Fujifilm X-H1 Pentax K-1 II
Alwina H Regular Member • Posts: 344
5
I'm disappointed. I was convinced that my next camera would be mirrorless but I have my Pentax lenses collection and so there was still some uncertainty. Just two days ago I noticed that the new K-1 mark II was 2000 EUR almost everywhere in Belgium, cheaper than the mark I a few weeks ago. And so I started talking about it at home ... "a bargain" and all the words you have for it.
And now I'm again convinced that it will be mirrorless! They can hardly release a new lens and it will be too expensive for me ... and they do years over a camera upgrade that isn't a clear improvement and about the only thing that they are firm about is that there is *no* mirrorless camera in the make. I still have a weak spot for Pentax but it's not easy to stay faithful!
A.
Dan Paris Contributing Member • Posts: 563
Continuation of my previous post.
Here is the result of my conversion with RT at 12,800 ISO (Mk II left Mk I right)
- MK ii files have to be pushed +0.7 ev to match exposure of Mk I (confirmed at other ISO values), otherwise same settings
- the difference in sharpness is rather small compared to DP comparison tool, don't you agree?
Dan
 Dan Paris's gear list:Dan Paris's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Ricoh GR II Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited +7 more
MightyMike Forum Pro • Posts: 39,148
5
I see more detail and contrast in the noisier image
Dan
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
KPM2 Contributing Member • Posts: 816
So what ?
5
Hello
- JPG are different...no wonder:
Oh and the advantage of DNG files is that you can use the embedded profile...but you must select it, else you get the Adobe Standard...as DPR did use:
I can not upload the big RAW files, but when I use the DPR RAW files with my Lightroom 3.7, with the embedded profile, with a PP for to get ca. the same WB and exposure on the center 'DP gray-card'...the K1 II looks really better than the K1
a 12800 example with no NR for luminance (forget your mobile for a moment, use your PC and download the original file...only than you see what you get .
The details are there in the K1 II files !
I am convinced for to make the update of my K1 to a K1 II...ok...not by the DP way of processing the files...but do to my own one
BTW: DPR did replaced the for pictures. That are still the same photos, but different printed ! So please do not wonder that they looks so different between the K1 and K1 II
best regards KPM2
baldeagle21b Contributing Member • Posts: 987
Re: So what ?
Well, of course there would be no point in equalizing camera menu settings or using the same lens when comparing, two cameras, would there? At least not at DPR.
I also seem to recall that on some recent models that Ricoh ships with strong noise reduction by default across the ISO range and that best result come from customizing the NR to reduct the NR at lower ISO's and gradually increase as ISO goes up.
 baldeagle21b's gear list:baldeagle21b's gear list
Pentax K20D Pentax K-01 Pentax Q7 Pentax K-3 Pentax K-1 II +9 more
BobORama
BobORama Senior Member • Posts: 2,658
12
Dan Paris wrote:
Also, as someone else noticed, the lenses are different and surprisingly the FA77 performs better than the Macro 50 in the corners (the leaves in the upper right corner are already mushy at ISO with the Mark II). So compare only in the center area.
The focal plane it tilted.  Here are the four corners.  It is worth noting that the compare-to images, including the K-1, show uniform levels of blur and CA.   So some of what is being seen is not a camera issue.   Mushy photos run through NR make for more mushy photos.  In per usual DPR style, the fact that they chose to (a) not notice this (b) dismiss it after I and others noticed it in the usual patronizing way speaks more to the DPR review staff than the camera.   Their attempt to apply "noise reduction" to "noisy" posters.
Now their assessment may very be correct, and built in NR is evil.   But this is analogous to having Vaseline on the lens and then saying "well, that is the way Pentax shipped it to us"
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Difference in contrast is probably gone by matching carefully the histograms (dark areas are darker on the Mark I picture).
About sharpness I agree with you that the Mark I looks better but (i) difference is smaller compared to DPR test and (ii) Mark II starts with almost one stop exposure disadvantage...
Dan
BobORama
9
At least they are honest...
Lyff Regular Member • Posts: 428
Re: So what ?
5
I did a small test with the iso 12800 raws in photoshop, between the K-1 and K-1 II, and for fun, the original K-1 with DXO Prime denoiser (at its minimal luminance setting to preserve maximum detail).
So I don't know if the K-1 II is misfocused or not, but the loss of detail is huge, even after sharpening (I used nik raw sharpener pro):
Final thoughts? Keep your K-1 and invest in a good raw denoiser.
 Lyff's gear list:Lyff's gear list
Sony RX100 IV Pentax K-3 II Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED +3 more
paulkienitz
paulkienitz Veteran Member • Posts: 5,320
johnami wrote:
It doesn't make sense. Why issue a mark 2 body with a poorer image quality?
Because spec comparison numbers sell cameras, I guess, and high ISO is a number that impresses people.
That logic makes a lot more sense in the lower tiers of the market, though.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
Nicols Contributing Member • Posts: 861
More contrast, yes, me too.
In what respects to detail, I would say, little difference to be seen. May be a little more on the mark II image.
Cheers - Klaus
 Nicols's gear list:Nicols's gear list
Pentax K10D Pentax K-5 Pentax K-3 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA* 300mm F4.0 ED (IF) SDM +16 more
