C1 Eterna Film Simulation
Started May 2, 2018 | Discussions
jctay Regular Member • Posts: 143
C1 Eterna Film Simulation icc Profile
Sharing my X-H1 Eterna build for Raw conversion with CaptureOne, FujiXH1-jc1-Eterna-Beta1.icm. It can be downloaded here: link
To test it for other x-series models, just rename the above file accordingly. For example, rename it to FujiXE3-jc1-Eterna-Beta1.icm for X-E3
This profile is tested on C1 pro 11, current version. It is optimized for C1 standard film curve, so set Curve to AUTO (Under Tool Tabs/ Color /Base Characteristics).
Enjoy and share your converted images here.
 jctay's gear list:jctay's gear list
Sony RX100 IV Nikon D600 Leica T Fujifilm X-E3
Fujifilm X-H1
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 12,405
Re: C1 Eterna Film Simulation
In what folder to I store the profile (my memory is failing me here)?  I'm on a Mac.
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +13 more
RetiringGuy Regular Member • Posts: 477
Truman,
Assuming you are using Capture One on a Mac, put your profiles in ;-
~/Library/ColorSync/Profiles
i.e. Your in own Library NOT any of the system Libraries.
I don't use Windows these days so sorry if this doesn't help.
RG
BillCPA Regular Member • Posts: 360
Thank you for taking the time to create this profile and for sharing with us.  It definitely is a bit more 'muted' and my understanding is that it is a very useful when shooting video (which I don't do much of).
Bill
 BillCPA's gear list:BillCPA's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +6 more
Truman Prevatt
I loaded the profile and let me tell you I really like it.  The normal C1 H1 curve is somewhat harsh.  You icc is very good and it give much soother tonal gradations.  Good job!
Truman
OP jctay Regular Member • Posts: 143
Thanks all for the replies.
For windows, custom profiles are saved in C:\Users\Username\AppData\Local\CaptureOne\Color Profiles. Custom icc profiles can be copied directly to this folder, but aware that this is a hidden folder.
Alternatively, install or copy the custom profile to system icc folder, then import and save it to Color Profiles folder. This function is under: Tool Tabs/ Color /Base Characteristics /ICC Profile and when ICC Profile input box is clicked.
Bill
Thanks for your input.
I added contrasty by modifying the input tone curve.
Eterna-Plus, more pleasing tone for still image.
FujiXH1-jc1-Eterna-Plus-Beta1.icm < download >
Btw, i do not own a X-H1. Testing is carried out with sample raw from dpre. Soon I shall receive my X-E3
Steve Jump Regular Member • Posts: 165
Thanks for this - your efforts are very much appreciated, I think I shall be using this quite often - very pleasing tonality.
Was keen to try the higher contrast Sim, but the 'Plus' link seems to point to the original Eterna simulation file.
Kind Regards,
Steve
 Steve Jump's gear list:Steve Jump's gear list
Fujifilm X-T2 Fujifilm X30 Canon EOS 7D Fujifilm X-T20 Canon EF 50mm F1.8 II +9 more
In fact, the C1 generic icc profile for X-H1 has very good color re-production. A revised tone curve for portrait mode will certainly enhance its output.
Stay tuned
Kind Regards,
Steve
Below is the corrected link:
https://www.dropbox.com/s/y5ayl1rpogj0p26/FujiXH1-jc1-Eterna-Plus-Beta1.icm?dl=0
