Canon SL2 LCD Quality
Started Apr 29, 2018 | Discussions
rick9814911 Regular Member • Posts: 130
Hi,
I just picked up a refurb SL2 from Canons site. I had a few other Canon cameras before. One of the first things I noticed was the LCD looked more pixelated than I’m used to from Canon. Even my T3i seemed less pixelated. When I review images or look at menus I can see pixels in the text, etc.
Is that normal? When I look up the specs it has the same resolution display as the other Canon cameras that I’ve had. Is there something wrong with my SL2? Seems like such a weird issue.
 rick9814911's gear list:rick9814911's gear list
Panasonic Lumix DMC-GX85 Canon EOS M50 Canon EOS RP Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G 25mm F1.7 ASPH +3 more
Olga Johnson Forum Pro • Posts: 24,360
Re: Canon SL2 LCD Quality
If it looks different then something is wrong. It shouldn’t be different. You may want to ask for an exchange.
ThrillaMozilla Veteran Member • Posts: 7,681
It has over 1 million pixels in a tiny screen.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
OP rick9814911 Regular Member • Posts: 130
I just emailed Canon support. Hopefully they’ll replace it. Such a strange issue. I can’t think of what could cause that. Maybe this one had a broken screen and they replaced it with a lesser quality one?
No idea but it’s noticeably worse than any other Canon camera I’ve owned, and I’ve had several. I’ll update when I hear back from Canon.
Thanks for the response!
I'm going to bet that there's nothing wrong with it. That doesn't sound like the kind of problem that would be a factory defect.  If you replace it or fix it, you are likely to find no change. If I were you, I would compare it with others in the store. Also try resetting the camera to factory defaults.
I was at Target today and looked at a T6i. The screen was way less pixelated. My SL2 should have the same pixel density as the T6i. I really can’t explain it, it’s a strange issue. I did try a factory reset as well, no change.
I’ll see what Canon says. But I would likely return the camera if they can’t fix it. I’m within my return period.
I see. I don't know, really. I looked at one, but didn't notice anything.  I would still compare it with another SL2, though.
KENTGA Veteran Member • Posts: 8,733
My wife uses SL-2 and I do sometimes and I have 80D and 5D4 and the lcd screens look about the same to me. Why don't you take your SL-2 to the store and compare the LCD's?
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
Kent
The closest store with an SL2 on display is a Best Buy about an hour from me. I will be stopping by this weekend though. I’ll update after that!
Otherwise the SL2 has been great. I am really OCD about this sort of thing unfortunately.
stratobill Senior Member • Posts: 2,081
rick9814911 wrote:
Kent
You should be, my SL2 screen looks about the same as my 6D, which means, great.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
Selene Senior Member • Posts: 1,308
Agree that you should be about this.  It sounds like it may be defective.
RedFox88 Forum Pro • Posts: 30,738
rick9814911 wrote:
Hi,
The first buyer probably returned it for the same reason and Canon didn't check over the camera  not unexpected  refurbished items are returned purchases
No, 1 million dots, not pixels  3 colors go into a pixel so it's 330,000 pixels
Yeah, you're right, but it's still plenty.
