7iii front focus conclusion.
Started Apr 25, 2018 | Discussions
ATLshooter Regular Member • Posts: 395
18
My a7riii came in. I tested it already. Wife walking towards me, no issues. Eye af? No issues.
Front focus issue? Doesn't have it. It focuses literally exactly where I tell it to.
So somehow, I literally did just get two faulty bodies.
 ATLshooter's gear list:ATLshooter's gear list
Sony a7R III Sony FE 55mm F1.8 Zeiss Batis 85mm F1.8
dkeller Senior Member • Posts: 1,742
Re: 7iii front focus conclusion.
I think it is obvious that you did.  I believe you should send me one of those worthless bodies as I need a nice looking paperweight.
As for your own problem, probably a return to a SLT or SLT camera would give you the  front/back focus issues that used to be so much fun playing with micro adjustments to remove.
 dkeller's gear list:dkeller's gear list
Sony a7 II Sony SLT-A68 Tamron 18-270mm F/3.5-6.3 Di II VC PZD Sony FE 28-70mm F3.5-5.6 OSS Sony FE 90mm F2.8 macro +4 more
OP ATLshooter Regular Member • Posts: 395
I just never truly believed that out all of the bodies out there, I got two in a row that were bad. But at this point there's no other conclusion.
The 7riii puts focus literally EXACTLY where I tell it to.
vett93
vett93 Veteran Member • Posts: 5,465
Good work! This was the first time that I heard about a bad Sony camera body.
Maybe you can post a photo of using A7RIII and include settings?
"Keep calm and take photos"
Photography enthusiast, from 12mm to 500mm
 vett93's gear list:vett93's gear list
Sony a9 Sony a7R III Sony a6500 Sony a7 IV
WalterJ1959 Regular Member • Posts: 431
So happy for you.  It was brave of you to get a new model before they had a chance to get all the bugs worked out.  Remember that all things happen for a reason and you were destine to have the A7RIII.
 WalterJ1959's gear list:WalterJ1959's gear list
Sony a7R III Sony FE 90mm F2.8 macro Zeiss Loxia 21mm F2.8 Sony FE 85mm F1.8 Sony FE 100-400mm F4.5-5.6 +4 more
The Lotus Eater
The Lotus Eater Regular Member • Posts: 415
I remember I got two A580s in a row with back focus issues, but it didn't have mirco adjust, so back they went.  That was a depressing few days.
 The Lotus Eater's gear list:The Lotus Eater's gear list
Sony Alpha DSLR-A700 Sony Alpha NEX-6 Sony a6300 Sony a7 III Sigma 30mm F2.8 EX DN +8 more
ClaytonTurner Junior Member • Posts: 30
Were the serial numbers were close?
just out of curiosity were the serial numbers relatively close or more random?
The Lotus Eater
What bugs?  His cameras were faulty.
Arizona Sunset
Arizona Sunset Veteran Member • Posts: 3,797
That's fate, and perseverance.  The A7R III is a mighty fine camera.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
Re: Were the serial numbers were close?
One was prefix 337 and one was 377.
vett93
What I meant to say was regarding Eye AF testing. Can you please do a close-up Eye AF using AFC and F1.8, and see if the nose is in focus instead?
5
Sure! Replicated the 7iii shots, and focus is right on the iris. Closer, same thing. Further away, same thing. It just grabs the eye correctly, like my 6500.
Roses Senior Member • Posts: 2,760
Did you send the bodies back?
As an aside, did you try doing the in-camera cleaning mode to try to reset the IBIS? Sometimes we've seen the IBIS get out of wack, and doing the cleaning resets it. But it could have been just two faulty units in a row.
 Roses's gear list:Roses's gear list
Sony a9 Sony a7R III Zeiss Batis 85mm F1.8 Sony FE 50mm F1.8 Sony FE 100mm F2.8 GM +2 more
jameszhan
jameszhan Contributing Member • Posts: 597
Good to hear you finally have a working body!!
I still wonder what was wrong with your two A7 III bodies. Is Sony going to take a look at them or no?
 jameszhan's gear list:jameszhan's gear list
Sony a7 III Sony FE 28mm F2 Tamron 17-28mm F2.8 Di III RXD
Just got finished packing up the second 7iii to ship back to adorama. I can't troubleshoot with it anymore.
Although I can't imagine with IBIS would cause front focus. Out of focus shots sure, but that wasn't my problem. The problem was that the camera consistently focused in front of where you told them to.
At this point I just hope everyone else has good experiences with their 7iii's! And I plan to try again in a couple months. Maybe mid summer I will pick up another 7iii after I know for a fact the first batches are sold out.
Not quite sure. They took down my serial #s so I'd guess they flagged them for review in the system, although I don't know that to be fact.
I am returning the cameras to where I got them for refunds, but I'm sure the cameras eventually get back to sony HQ. You'd think, at least.
vett93
Does the in-camera cleaning reset the IBIS? I have not read it elsewhere. Is this in the user manual? Thanks.
vett93
Thank you! That is sharp Eye AF indeed!
I have not used my A7RIII a lot yet. But I have on my A7RII and A6500. I also had A7II and A6000. With my copy of A7RIII, I have found the AF-C Eye-AF works the best with Face Detect off. With Face Detect on, it sometimes focuses at the nose.
If you can verify/reject that with your A7RIII, it would be very helpful. Since you have demonstrated a lot of good testings with your Sony gears. Your results will be trusted.
(unknown member) Veteran Member • Posts: 8,068
Indeed, you did
You did - and that's what people here were trying to explain to you like 200 posts ago...
Congrats to your A7riii. Fabulous camera!
This Could be the most happy person
So now she can put herSony camera  test shot modeling career on a temp hold. She looks very happy.
