EF 28-135 Good enough for FF?
Started Apr 25, 2018 | Discussions
stringouve New Member • Posts: 12
Hi out there.
I am shooting with the EF-S 15-85 on an EOS 40D.
Time has come for me to upgrade my camera, and the obvious choice is the EOS80D. For a little more money I could go FF and by the EOS 6DII. I still have an old EF 28-135 form analog days and the question is, if the lens is good enough for a modern DSLR.
If I bought the 24-105 f4 on top of that, it would get too expansive (and also the teknological superiour A7iii from Sony with their 24-105 lens would be a more tempting option)
What is your recommandation: Get the 80D with my good modern standard zoom or go fullframe with the 6DII and the old lens?
My other gear is the Tamron 60mm 2,0, that I use for Macro and portrait and a speedlite 420EXII.
 stringouve's gear list:stringouve's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R Fujifilm 50-230mm II Fujifilm XF 80mm F2.8 Macro
Canon 6D Mark II Canon EF 28-135mm F3.5-5.6 IS USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EOS 40D Canon EOS 80D
Christoph Stephan
Christoph Stephan Veteran Member • Posts: 4,274
Re: EF 28-135 Good enough for FF?
stringouve wrote:
Hi out there.
In 35 mm terms, your 15-85mm IS is equivalent to a 24 - 136 mm lens - considerably wider. 4 mm is no small difference at the short end - so this another factor to consider.
For that reason I would go with the 80D. You could still use your 28-135mm as a 45 - 216 mm equivalent lens on that one, if you need a little longer.
 Christoph Stephan's gear list:Christoph Stephan's gear list
Canon EOS 20D Canon EOS 40D Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM Tamron AF 28-300mm F/3.5-6.3 XR Di VC LD Aspherical (IF) Macro
Macabron
Macabron Regular Member • Posts: 121
I would go for the full frame . Add a 50 mm f1.8 and that will give you a sharper (at f2.8 and above) image and a low light lens. After using your 28-135 for a while you can decide if you want to upgrade.
Everything I say is my profesional opinion, feel free to disregard it at your own risk.
ffabrici Senior Member • Posts: 1,353
I would go FF and use your current lenses . You van always upgrade the standad zoom at a later point in time.
The 80D is a great camera but it simply can’t beat the lowlight capabilities of a 6DII or a 6D for that matter.
canuck dave
canuck dave Veteran Member • Posts: 3,202
stringouve wrote:
Hi out there.
The 80D would certainly be a big step up from your 40D. But, the 6D/D2 would be an even bigger improvement. With your existing EF28-135 you would have a very good all-round flexible combo with a reasonable investment.
I use the 6D and it is an excellent DSLR.
Christoph Stephan
Tamron 60mm f2 Macro: crop only
I would suggest this only if low light photography and ultrashallow depth of field are really his preferences/priorities.
The major counterargument is that two lenses the OP already owns are for crop cameras only, and he indicated that he does not have/does not want to spend money on new lenses.
While the EF-S 15-85mm IS can somewhat replaced by the EF 28-135 IS (albeit with loss of the 24-28 mm equivalent focal length range), this is not the case for his Tamron 60mm f2. The Tamron 60mm f2 can be used on crop cameras only, (1).
For this reason, replacing the 40D with a 6dII only makes sense if the Tamron Macro sits in his drawer unused. However, the OP indicated that he uses it for portrait and macro. While the first use can be somewhat covered by the cheap 50mm f1.8 suggested above (not fully, as the equivalent focal length of the Tamron is ~100 mm) this is not the case with macro.
For this reason, if I where in his shoes, I would get the 80D - unless low light and shallow DOF are fundamentally important. Then he would either need to 1. sell the 2 crop lenses to contribute to funds for full frame lenses or 2. keep his 40D as a second body for use with the macro.
Christoph Stephan
Tamron 60mm f2
One main argument why I would choose the 80D over the 6DII in your case would be your Tamron 60mm f2 . It is crop only, you cannot use it on the 6DII. Since you have indicated that you do not want to spend money on new lenses this would tip the balance solidly in favour of the EOS 80D for me.
The 28-135mm would still be a nice small telephoto zoom on the 80D.
A way around it would be to keep the 40D as a second camera for use with Tamron 60mm Macro.
2Risky Forum Member • Posts: 60
To answer your original question, is it good enough, the answer is yes.  I still have mine although I don't use it anymore.  You should like it better than the efs 15-85 f3.5, at least slightly.  I was actually surprised with it's results.  You would also see a very definite benefit with the 6D.  However, as others have noted, not all your lenses are compatible with the 6D body.
Good luck with your decision.
 2Risky's gear list:2Risky's gear list
Canon EOS 6D Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sigma 50mm F1.4 DG HSM | A Canon 85mm F1.4L IS USM +6 more
diness Veteran Member • Posts: 3,758
Good enough is relative of course...   have you considered a used 24-105 version 1?   I think it’s the best deal out there for a standard zoom and is much better than the 28-135
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
OP stringouve New Member • Posts: 12
Thank you for all your answers.
I think, at the end it comes down to, what my heart tells me (and what my brain tries to tell me)
Do I want the best lowlight performance? Of course!
Do I really need it? Im not so shure. Somtimes good is good enough.
The same thing counts for a shallow depth of field.
It adds up. A more expansive camera. A not satisfying standart zoom, thats not a long time solution. Primes that need to be changed.
I will go with the more rational choice and by the 80D.
sssanti Contributing Member • Posts: 727
Upgrading to the 80D will be simpler and more economical for you.
On the other hand, if you really want a full frame camera, you can reduce the cost of upgrading by selling your crop lenses and camera, and buying either refurbished or used. Canon has occasional sales for refurbished cameras and lenses with a one-year warranty. Full frame lenses that are great values, especially used, are:
  • 17-40 f4
  • 50 f1.8 STM
  • 85 f1.8 or 100 f2
  • 100 f2.8 macro
  • 24-105 f4 (original version)
  • 70-300 f4-5.6 IS (especially the original version)
Full frame gives you a little more than one stop better low light noise with shallower depth of field and better sharpness from the same lenses, especially in the center area. The disadvantage is additional size and weight.
John Sheehy Forum Pro • Posts: 26,698
Unless the optical quality drops off very rapidly in the FF corners, a FF lens will always perform better on a FF sensor than on an APS-C sensor, AOTBE.
However, the lens now has a wider FOV, and much else can change (such as distance and DOF), so it is a different functional lens in many ways.
ed rader Veteran Member • Posts: 9,068
Short answer: no ...... nt
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
short243 Veteran Member • Posts: 4,343
Why not consider a 6D 1
Hi, Still FF and still a very good camera at a lower price. It would be a big upgrade from a 40D and last a very long time.
Rick Wilkinson
From Gobblers Knob ...... De Colores
https://www.dpreview.com/galleries/5700327128
If they can't kill you for it, it doesn't matter ....
Karen Schmidt
 short243's gear list:short243's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +1 more
Macro guy
Macro guy Veteran Member • Posts: 6,069
Re: Why not consider a 6D 1
+1
I would get the 6D 1 and a Tamron 28-75mm f2.8 if you're on a tight budget.  The Tamron can be had for around $300 new and about $200 used.  If you need an even longer reach than that, then consider adding the Canon 135mm f2.8 Soft Focus lens.  It's a very underrated lens and can be had for about $250 on the used market.
So, if you're willing to go that route, you'd be pretty much set with relatively fast, decent quality lenses.
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Canon EF 70-200mm F4L IS USM +4 more
Scott Milso Senior Member • Posts: 1,099
Probably the "smart" choice.
But, if it w were me and I could afford the 6dii that's exactly what I'd do.
