No focus peaking with Rokinon 12mm f/2
stephen kronwith Regular Member • Posts: 132
Just got this Rokinon 12mm f/2 and despite what I've read in Amazon discussions about lens, I can't get focus peaking to work. This didn't surprise me as there are no electronic connections with camera but others say it should work. Am I missing something?  Thanks.
travelbug77 Junior Member • Posts: 44
Re: No focus peaking with Rokinon 12mm f/2
you need to map focus peaking to a button and toggle it on and off as needed.
Barty L
Barty L Senior Member • Posts: 1,308
Assign a button
You need to assign a button to peaking, then press it when you want it.
BartyL
www.facebook.com/barty.lobethal/photos_albums
OP stephen kronwith Regular Member • Posts: 132
Thanks all. That worked. I guess getting the magnified view to work also is asking too much?
MNE Senior Member • Posts: 1,270
I have magnification as a multi-function option and use a separate button for peaking. That way you don't waste two fn buttons just for manual focusing.
MNE - Not sure what you mean. Don't you have to use a button for multifunction? So you're still using two buttons for manual - one for peaking and one for multi. I've never used multifunction so maybe I'm misunderstanding.
Played around and figured it out. Thanks again.
Eric Nepean
Eric Nepean Veteran Member • Posts: 3,948
Next time do remember to mention which camera you are working with. In this case both Olympus cameras and Panny cameras have peaking and magnification features.
Cheers
Eric
You're right.  Thought I put it down but now I see I didn't. It was, BTW, the OMD EM! ii.
