Olympus FL-600 flash on OMD E-M1 Mark II issue
Started Apr 23, 2018 | Discussions
adamkaty Junior Member • Posts: 38
Hoping someone might be able to help here.  When I place the FL-600 flash on my OMD E-M1 Mark II it will not fire.  The flash is in TTL mode and displays changes in focal length.  If I turn the camera RC mode on the flash will work that way.
If I remove the flash and place it on my Pen E-P5 for a picture it works with no issue and if I move it from there back onto the Mark II it will work perfectly on the Mark II until I turn the camera off then it goes back to not working when I turn it back on.  The shutter is not on silent.  The flash that comes with the Mark II works fine.  I don't even know if this is a flash issue or camera issue?
Olympus E-M1 Olympus PEN E-P5
tintifax Senior Member • Posts: 1,057
Re: Olympus FL-600 flash on OMD E-M1 Mark II issue
Electronic shutter
high speed sync activated?
some art-modes do. Not accept flash
somerimes my FL600 Gas contact--issues on both my EM 1 II and PenF, push it straight forward
flashmode?
serial shutter?
proMode?
Internal Flash Not activated in RC Mode?
with best regards from Vienna
Thomas T
 tintifax's gear list:tintifax's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +9 more
OP adamkaty Junior Member • Posts: 38
Camera mode - Auto or M
Flash mode - Fill
Single picture mode, no pro or multiple
Flash is pushed all the way on
Not sure what serial shutter means
flarsson Contributing Member • Posts: 510
I had a similar problem with the EM-1 mk. 2 and Olympus FL-50R flash as well as the mini-flash that came with the camera.
If you are using electronic shutter, the flash will not fire. If you change to the mechanical shutter it works fine.
E-3, E-5, 7-14/4, 14-54/2,8-3,5, 50-200/2,8-3,5 SWD, 35-100/2.0, 35, 9-18, 18-180, 70-300; PL 25/1,4; Sigma 105/2,8; Sigma 135-400; Sigma 50-500; Samyang 8FE/3,5; Samyang 500R/8; EC-14; EC-20; EX-25, FL-36R, FL-50R(2); HLD-4.
OM-D EM-5, EM-1 mk.1, EM-1 mk.2, MZD 12-40/2.8, MZD 12-50, MZD 45, MZD 75-300, Sigma 60/2.8; Tamron 14-150; MMF-3(2), HLD-6, HLD-7.
OM-2N, OM-10, OM-40, OMZ 28/2,8, OMZ 35/2,8, OMZ 50/1,4, OMZ 50/1,8 (2), OMZ 100/2,8, OMZ 135/3,5, Elicar 35/2,8 OM, Cosina 35-70 f/3,5-4,5 OM, Vivitar 70-150 f/3,5 OM, Vivitar 2x teleconverter OM, Olympus FM-1 OM/E-converter (2), OM/MFT-converter, T-32
 flarsson's gear list:flarsson's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 7-14mm F2.8 Pro
I found that tip in another thread on here but I am not using the electronic/silent shutter.  I am using the normal shutter and it does not fire.
Flash mode - Fill
when pressing the shutter is does not make a single "klick" it makes "klickklickklickklickklickklickklick...." and makes pictures as long as you pressed the shutter. In this mode flash is always off ... on every camera.
Thomas T
No, i'm on single image mode
Kszchopstix Contributing Member • Posts: 527
Try doing a setting reset on the em1 mkii. When quirky thing like this shows up a full reset does the trick.
 Kszchopstix's gear list:Kszchopstix's gear list
Panasonic LX100 II Olympus E-M1 II Pentax KP Pentax smc DA 15mm F4 ED AL Limited Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +12 more
