Question about Olympus settings (MF, IBIS and focus peaking)
Started Apr 19, 2018 | Discussions
Doux Vide
Doux Vide Contributing Member • Posts: 922
Hi all,
I noticed something on my EP5:
When I am in MF mode.
If I turn the focus ring, the focus peaking turns on, and after a few seconds it's off again.
That's a little annoying so I set a fn button to toggle focus peaking. Ok, great, I can have focus peaking all time on now.
The issue is, when I half-press the shutter, focus peaking is turned off and IBIS is turned on (I can see its effect and I can hear it as well).
I'm not sure but as far as I remember the EM1 I had the same behaviour (it has been stolen last year that's why I use the EP5 that I have kept just in case as a spare), so I presume it's the normal behaviour of Olympus bodies.
Now I was thinking about buying an EM1.2, and I wanted to know if it has the same behaviour, and if yes, iif t's possible to change that (through options or custom buttons) in a way to have:
-focus peaking AND IBIS at the same time.
-focus peaking stays on when I half-press the shutter (focus peaking always on no matter what happens).
Thank you
Olympus E-M1 Olympus PEN E-P5
drj3 Forum Pro • Posts: 12,636
Re: Question about Olympus settings (MF, IBIS and focus peaking)
Doux Vide wrote:
Hi all,
Thank you
Normal focus peaking on the E-M1.2 (I don't have it assigned to a button), works when I half press of the shutter and manually focus, it stays on briefly (about 1-1.5 seconds) and then goes off.
If I turn the focus ring again keeping the half press, it comes back on and then goes off after the same 1-1.5 second delay.  It does not come on/off when I move the camera, I must at least slightly move the focus ring.
IBIS is not related to focus peaking, since I have that turned on with half press and peaking comes on to confirm focus as I move the focus ring.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Doux Vide
OP Doux Vide Contributing Member • Posts: 922
Thank you for you answer, it helped me understanding a thing:
When focus peaking is "normal" (default settings), then half-press on the shutter + touching the focus ring turns the focus peaking on (which is a good thing).
When focus peaking is on (by pressing a custom fn), then half-press on the shutter turns it off, and even if I turn the focus ring it won't come back.
Interesting. I think it's the intended behaviour of all Olympus cameras then... I have to find if it's possible to change that.
Panasonic cameras are different:
When in AF, focus peaking is turned on when you touch the focus ring (like Olympus)
When in MF, focus peaking remains on all the time.
I would have preferred Olympus to do the same...
