Red focus confirmation light barely visible
Started Apr 16, 2018 | Discussions
CoffeeKing New Member • Posts: 3
Hi Guys
I lent my old 550D / T2i to a friend the other day and was showing him the ropes but the red focus confirmation light is barely visible (I think I can just about see it sometimes).
Most of the time its like its not lighting up at all, but it will beep confirm.
I havent got AI Servo etc turned on.
I have got the lens set on auto focus.
Ive totally reset the camera for him so there are no custom controls on it.
Any idea what else it could be? Is there some internal batter perhaps that makes it light up?
Thanks in advance.
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
IntriguePhotography Forum Member • Posts: 71
Re: Red focus confirmation light barely visible
If your body is like the Canon bodies I have, there is no built in AF assist light. This feature will only work if you were to attach an external speed light that included an AF assist light option.
Edit...
Disregard the above. Lol
i totally misunderstood. AFAIK there is no setting for what you are looking for. My SL1 has a similar issue. It is much more difficult to see than on my more modern bodies.
 IntriguePhotography's gear list:IntriguePhotography's gear list
Pentax K-30 Canon EOS 6D Canon EOS Rebel SL1 Nikon D750 Canon EF 50mm F1.4 USM +14 more
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
If the T2i is like my old XT/350D (maybe it is, maybe it isn't), the focus screen is supposed to have reflective dots at the AF points. If those reflective dots come off the screen, all you'll get is a weak red blur in the general area.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
WilbaW
WilbaW Forum Pro • Posts: 11,643
The focus confirmation light is green -
So you must be talking about the AF point activation indicator, which is red.
What is the green focus confirmation light doing in that scenario?
The date/time backup battery was dropped with the 450D. In any case the red flash of the AF point would be powered by the main battery.
They are harder to see in bright light - what's it like in dull light?
Check out the unofficial Rebel Talk FAQ. Sorry it's out of date, but DPReview still won't allow us to edit our articles.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
