Canon 300mm f2.8 and 600mm f4 image stabiliser problems?
Started Apr 13, 2018 | Discussions
tobesbass
tobesbass New Member • Posts: 2
HI,
I've recently been fortunate enough to get hold of a 600mm f4 ii and i'm worried about the image stabiliser.
The problem is the stabiliser rattles loudly when the lens is moved while a body is not attached. furthermore, when in use in mode 1, the IS makes a clunking noise. It's incredibly loud and sounds like metal scraping on metal (nothing like the noise my 100-400 makes). I had a similar problem with my 300mm f2.8 ii, on which the IS now doesn't work at all and needs repairing.
I was wondering if anyone else has any experience of this? I'm worried the problem is caused by a fault in my body?
 tobesbass's gear list:tobesbass's gear list
Canon EOS 7D Mark II Canon EF 300mm f/2.8L IS II USM Canon EF 600mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II
Ray Chen Veteran Member • Posts: 9,652
Re: Canon 300mm f2.8 and 600mm f4 image stabiliser problems?
You need to power down the body first before unmounting the lens. See my other thread:
https://www.dpreview.com/forums/post/61015992
The funny thing is, I've never encountered the same problem on my 400mm and 200mm.  Maybe the symptom only happens when the IS was engaged during the lens dismount?
 Ray Chen's gear list:Ray Chen's gear list
Canon EF 40mm f/2.8 STM
