Major issue with eye autofocus on A7iii?
Started Apr 12, 2018 | Discussions
OP ATLshooter Regular Member • Posts: 385
Re: Major issue with eye autofocus on A7iii?
Marky12 wrote:
ATLshooter wrote:
New body arrived. Serial prefix is 337.
Issue still exists, without me changing any settings in the camera. I literally turned the camera on, hit af-c, then used the pre-programmed eye af button.
Front focused on my wife's nose on the second picture I took.
This has to be a firmware issue....:-x
I have the same serial prefix and I don't experience this issue. I tested it with the 85 f/1.8. Only other lens I have is a samyang 35 f/2.8.
https://www.flickr.com/photos/22946100@N02/
You tested with the subject close enough so that their face fills the frame, and they were directly face on with you?
What aperture? Can you please post some pics where it nailed the eye consistently?
 ATLshooter's gear list:ATLshooter's gear list
Sony a7R III Sony FE 55mm F1.8 Zeiss Batis 85mm F1.8
For every one of these shots I had a medium spot AF centered on her face. She was literally barely moving at any speed towards me. Much slower than a normal adult walking.
Can you find a SINGLE picture where her face is in focus? A single one? I can't.
To say I'm disappointed is an understatement. I don't know what to do at this point. The af-c is unusable, on two separate bodies now.
Zoom up on her face and look how soft it is. How can the camera just be totally unable to get focus? I don't get it.
osv Veteran Member • Posts: 9,970
why medium spot?
the only face in the frame is hers, so the camera will easily find it, with face recognition turned on, using the standard wide area af setting.
with medium spot, you are cutting off most of the available af pixels.
dan
Horacecoker Senior Member • Posts: 2,455
I thought as much!
The thing is you have provided photos to prove your case but nobody who says their A7iii does not have this problem have posted photos to prove it doesn't!! In other words their 'good' cameras will be exactly the same in the same scenario as your bad copy. Another thing to consider is that there are a sight more folk that accept mediocrity than those that who will only accept perfection. In this case It's not even actual perfection you are looking for, all you are asking is for eye focus to work like it should do.
From what I've seen on the reviews folk are saying that eye focus is uncannily good because they can see the green box tracking the eye. The fact that the eye in question is not in focus is completely lost on them. Of course if these folk are stopping down to F4 or the subject is further away there is no problem because DOF takes care of it.
David
 Horacecoker's gear list:Horacecoker's gear list
Sony RX100 III Sony RX10 IV Sony a7R III Sony FE 55mm F1.8 Sony FE 28mm F2
I have to admit, I'm sort of transitioning from disappointment to anger.
As a last ditch effort I tried to just use face detect AF and run a burst.
The box was CLEARLY locked on the face, yet not a single picture had the face in focus. There are focused areas, they are either just severely front/back focused.
I can safely say without a doubt this camera has the worst autofocus I've ever used. Which is a huge disappointment since that was basically the only reason I bought it.
I am sad. I have been spoiled by mirrorless for the last 6 months or so. I was so, so excited about this camera. Not sure what to do at this point like I keep saying but I have to have a full frame working camera ASAP.
All of these pics are either front or back focused despite the camera having a lock on her face. She was moving towards me at a VERY slow pace, so motion blur isn't a problem. That is proven by the fact that the back/front focused areas are tack sharp.
The last picture is honestly pathetic. It's like the camera didn't even try.
osv wrote:
why medium spot?
I figured someone would say that, so I took test shots using face detect AF and they were the same.
Please see the post above this one for example pictures.
kaku Contributing Member • Posts: 681
Many thanks for posting photos. Without zooming in, these pictures appear to be in focus. So I wonder if it is a broader issue and people aren't noticing.
I thought perhaps this issue might just be isolated to a single, defective camera, but this is the third camera you tested. FStoppers had also written about it in their review about inaccurate Eye-AF.
And I've seen it in Jason Lanier's video where he zoomed into the eyes and it showed slight front focused.
Anyhow, initially it seemed like it may have been just attributed to the 55 lens, but I see here you're using the 85. That's not good.
If you look at the image at the actual size, you can clearly see that none of the face is in focus. And that's using face detect AF....It should at least be able to get the nose....the eyes....SOMETHING.
I get what you're saying though, at a glance when looking at a small pic it can seem in focus. So some people may never look beyond that. Problem is, I need the pictures to be sharp. Other cameras can do it, so I need my 7iii to do it or I need to make a change.
I've been playing around trying to improve my results. Playing with every AF setting this camera has. Nothing is working. Sadly.
Marky12
Marky12 Contributing Member • Posts: 750
I'll try to post some pics tonight. Have you tried the micro adjustment in the cam? Never used it but just throwing it out there
 Marky12's gear list:Marky12's gear list
Sony RX100 Sony a7 III Sony FE 55mm F1.8 Sony FE 85mm F1.8 Samyang AF 35mm F2.8 FE +2 more
Magnar W
Magnar W Senior Member • Posts: 4,063
Marky12 wrote:
I'll try to post some pics tonight. Have you tried the micro adjustment in the cam? Never used it but just throwing it out there.
No micro adjustment for native E mount lenses.
This option is for those using A-mount lenses with LAE4 adapter, which makes AF work like a DSLR - the adapter has a built-in AF module.
 Magnar W's gear list:Magnar W's gear list
Sony a7 Sony a7R III Sony FE 90mm F2.8 macro Zeiss Loxia 21mm F2.8 Zeiss Loxia 35 +2 more
You can't micro adjust with native sony lenses. The option isn't available.
It's a software issue. I'm about to post a video showing how the camera doesn't even pay attention to where you're asking it to focus. This issue is deeper than simply eye af not working.
Please excuse the off-the-cuff nature of this video but it's hard to record a video while shooting pictures.
This is extremely poor performance. The lock-on af really illustrates the issue since you can see where the camera chooses to focus.... OUTSIDE of where I tell it to.
The Lotus Eater
The Lotus Eater Regular Member • Posts: 415
I did a few Eye-AF test shots this evening with my A7III and 55/1.8.  Some closeups at f/1.8 and 2.8, a couple a little further away.  Used mainly AF-C, but AF-S seems to be just as accurate when the subject isn't moving obviously.
As far as I'm concerned, Eye-AF is working as it should - just as well as it does on my A6300.
f/1.8
f/2.8
f/1.8 - walking towards the camera
 The Lotus Eater's gear list:The Lotus Eater's gear list
Sony Alpha DSLR-A700 Sony Alpha NEX-6 Sony a6300 Sony a7 III Sigma 30mm F2.8 EX DN +8 more
f/1.8
f/2.8
Yep, those look great. Happy for you. I wish my 2 were working like that. I can only imagine I'd be taking pictures constantly.....and actually enjoying myself.
What are the first 3 numbers in your serial #?
citrate Regular Member • Posts: 111
The current algorithm of lock-on with flexible spot in Sony camera is not that smart enough.
In the case you showed in this video, I believe you can get much better results with AFC wide, zone or even AFC single spot ( you need to keep the spot on your subject).
There is another lock on function called "center lock-on", which can do a better job in pattern recognition.
slstr Senior Member • Posts: 1,022
These look really good, what batches are your A7III and you FE55 ?
 slstr's gear list:slstr's gear list
Sony a7S Sony a7 II Sony a7R II Sony a9 Sony E 30mm F3.5 Macro +12 more
The Lotus Eater
3775xxx
The Lotus Eater
A7III - 3375xxx
55/1.8 - 0189xxx
PWPhotography Senior Member • Posts: 7,681
Try to register faces that might help.
 PWPhotography's gear list:PWPhotography's gear list
Canon EOS-1D Mark III Sony a9 Sony a7R III Canon EF 15mm f/2.8 Fisheye Canon TS-E 17mm f/4L +15 more
I get even worse performance with spot AF. I'll show it.
