Poll - get a 7-14mm for my G7, or upgrade to G85?
Started Apr 8, 2018 | Polls
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
Re: Poll - get a 7-14mm for my G7, or upgrade to G85?
inlawbiker wrote:
We have a g7 and g85. The g85’s better but it doesn’t take better pictures.
I think it does or at lease it enables me to take better pictures
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Albert Valentino Veteran Member • Posts: 9,770
Split the difference. Upgrade the camera and pickup a Used O 9-18 lens.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Re: Message is clear
Better to seek forgiveness than permission
Also, the value proposition is worth outlining.  Buy handbag today cost $200 and value tomorrow $20 to zero.  Buy a lens today at $600, value tomorrow $450 to $500.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
larsbc Forum Pro • Posts: 18,282
JosephScha wrote:
I have a G7. For about $800 I could get the Pana 7-14mm f/4, and old but good lens that would give me a wide angle range I don't have now. Or, for $900 I could update to a G85 - which was reviewed here as "the camera the G7 should have been" - much less shutter shock (although, I only have a few examples of shutter shock), in camera focus stacking (the G7 doens't have that), weather sealed.
I shoot raw with the G7 and probably would still shoot raw with a G85. I like the G7 just fine. ... I am conflicted. Opinions please?
IMO the main reason for switching to a G85 would be the IBIS feature.  If you don't feel a need for it, then get the 7-14.
rashid7
rashid7 Veteran Member • Posts: 7,011
+1
Keep it fun!
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Oh boy... When I see such posts comparing a new lens vs a new camera I always get fidgety. For me a new lens with a completely different FL range will most often than not outweigh a new camera, especially if the old one was already excellent for 95% of use cases.
I have the 7-14 and can vouch that it is a terrific lens if you don't care much about filters and are careful about flare situations.
I don't believe much in the shutter-shock issue which should apparently  plague my GX8 (never seen it in almost 2 years) and if it happens. it is with selective lenses. In-focus camera stacking is a nice gadget, but unless you are really in that sort of thing, that is all it really is, a gadget. As for weather sealing, my GX8 is the first weather sealed device I've used in 45 years of photography and I live in Canada; never had a problem yet. The only main reason I'd spring for the G85 would be to use dual IS with long telephotos such as the PL 100-400.
Bottom line, I'd suggest keeping the G7 and getting the lens...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
dylanphotolight Regular Member • Posts: 414
Get The Lens
dylan
http://www.dylan-garcia.co.uk
 dylanphotolight's gear list:dylanphotolight's gear list
Panasonic Leica D Summilux Asph 25mm F1.4 Olympus 25mm F1.2 Panasonic 12-35mm F2.8 II Panasonic 35-100mm F2.8 II
WhiteBeard
dylanphotolight wrote:
Get The Lens
dylan
Agreed. I might add I bought mine more than a year ago for 700$ Cdn so 800$ US for a used copy now seems a bit high. Patience...
Brisn5757 Veteran Member • Posts: 4,540
With ever upgrade model of a brand of cameras comes pros and cons.
I had to chose between the G85 and the G7 but chose the G7 as it is lighter and smaller. The battery last longer also. There was a bigger price different at the time.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
