siberstorm27 wrote:
M43 with f1.7 and 3 axis IBIS versus canon apsc with f2. Which is better in low light? Looking for trouser pocketable camera that is better than a 1" compact. Specifically the e-pl9 vs m100. Both are under 40mm. Add pancake around 60-70mm. The Canon has a bigger sensor and more megapixels and I like to zoom into pictures. However, the e-pl9 has IBIS which helps with the smaller sensor and videos look much better with it. I also like olympus color more. It would've been easier if there was an e-pm3 or something. Not into the panasonic look.
I use both a DSLR APS-C system (Pentax K3, see my gear list for lenses) and M43 Panasonic (G7+GM1, +lenses).
Never used Canon APS-C DSLR but IMO the RAW IQ and handling should be very close to that of Pentax or Nikon, the main difference between APS-C DSLR brands being ergonomy, AF technology and handling, and IBIS vs OIS.
Cannot speak for mirrorless Canon, though I understand the concern about the smaller lens choice.
IMO, most still photographers should not care about the hype around features and IQ: all recent cameras I or my friends used have an excellent IQ at base ISO in good light. The high ISO/low light performance is quite impressive even in M43.
The main difference I noticed between my APS-C and M43 photography:
- APS-C delivers more details (which matters only for landscapes but also allows for more cropping for action scenes when needed.
- APS-C raw files allow 1 EV more dynamic range in difficult high contrast light which, again, matters mainly for landscapes, or to rescue screwed capture settings
- M43 AF in good light is OK but, save for high end models like Olympus OMD-EM1-mkII, APS-C DSLR PDAF is more efficient in low light or to lock focus on moving targets
- M43 is truly lighter and smaller at a comparable shooting envelope (identical f stop and comparable lenses) but needs more expensive bigger lenses to get the same subject isolation/bokeh as APS-C.
- Many M43 EVF are OLED, which are very nice, better than some entry level DSLR OVF.
Though I seldom shoot video, IMO, amateur videographers will benefit of better features in mirrorless systems, a DSLR is crippled in video.
Most IQ differences underlined in web tests and forums dont matter in real life and are only visible to pixel peepers.
As for me, what matters most is the camera handling (haptics, ergonomy, viewfinder, size and weight), the AF performance (depending your kind of photography), and the lens offering in your budget envelope.
Shooting JPEG, the default in-camera settings are also different, each brand has its own preferences, usually M43 are more heavily processed and sharpened than APS-C, but you can customize these settings to your taste.
You will need different boring trials but, once you have done it with your new camera, you can get very close rendering with different bodies from different brands, and never bother again.
About size, though M43 bodies can be very slim and light (I chose Panasonic GM5 for its tiny size with 12-32 kit zoom), dont expect it to be really pocketable, as you must account for the lens.
If pocketable size is your choice, you are stuck with fixed lens 1", with various offering, depending your priorities between aperture, focal range, size and ergonomy.
