Help for angle of view conversion
Started Apr 7, 2018 | Questions
Michael Perfect
OP Michael Perfect Regular Member • Posts: 182
Re: Help for angle of view conversion
Would you guys agree that using the Laowa 7.5mm + an even short tube in order to do macro, on a M4/3 camera, would most likely result in the point of focal being right at the edge of the lens, or maybe even inside it ?
Thanks!
 Michael Perfect's gear list:Michael Perfect's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF 100mm F2.8L Macro IS USM Venus Laowa 7.5mm F2 MFT +4 more
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Thanks!
I tried earlier today, prompted by your question.
The shortest tube I have is 10mm.  (I'm not sure it's possible to buy a shorter one.)
With that I was picking up the shape of the dust on the lens.  Yes, it was impossible to focus on anything.  The lens was too far from the sensor.
But.  What, exactly, are you trying to achieve?  The Laowa 7.5mm focusses as close as 12 cm (nominal).  The subject is only about 5-6cm in front of the lens for that.  Is that not close enough for you?
If not, another inexpensive way of occasionally getting closer would be to add some screw-in close up lenses.  People here will tell you that the quality will suffer, but I know a very accomplished natural history photographer who had no trouble getting his prints accepted into international exhibitions.  He used the cheapest close up lenses he could find.  (He was retired, and every piece of kit he bought had to pay for itself.  He had a very astute understanding of photographic value for money.)
Dutch
forestmoonstudio.co.uk
My DP Review gallery
Photography is about light, not light-proof boxes.
Michael Perfect
Re: Cheaper solution on 14-45
alcelc wrote:
However, I am afraid that the focal length of 7.5 f/2 be too short to use any usual 10mm or 16mm or longer extension tube.
Yes, it seems tests have proven this is correct !
I tried to put on a 16mm tube on 7-14 f/4, it can't focus at all throughout 7 to 14... I suppose a shorter 10mm tube might be OK around 14 (but mine was broken because of my curiosity on how it works, can't communicate with the camera again after disassembling and reassembling of it another day, looking for a replacement ).
Sorry to hear about your broken lens Curiosity is more important tho !
If you really wish to engage in macro shooting, why not consider a proper native M43 macro lens like Olympus 60 f/2.8 (the most recommended by members), Panasonic 30 f/2.8, Olympus 30 f/3.5 or the older Panasonic Leica 45 f/2.8 that all produce excellent IQ, fast and accurate AF, as well as the usual size advantage over using adapted MF lenses...
Well I am already engaged in macro shooting, I'm making this project mostly using a Canon 100mm with Smart Adapter on the GH4. I'm really looking for a wide angle lens, but the unique macro possibilities of the Laowa 15mm macro are really teasing me.
Judging from the min shooting distance of 12cm of Laowa 7.5, I suppose even if you can put on an extension tube the shooting distance could be virtually 0cm, basically not workable for a lot of macro/close shooting situation.
Right!
The Laowa 15 macro is better, but still costy (US$500 as per B&H?), relatively huge comparing to native M43 native lenses (410g and 83.8mm long having a filter thread of 77mm), not to mention the need of an adapter to convert it into a M43 mount for more weight and size (if you have keen interest on this lens, better check the compatibility since if using a EF mount option, the flange distance of this lens would be 44mm and so a 24.75mm adapter must be used to allow a proper focusing of this lens on the 19.25mm flange distance of M43 system. Not sure how the min shooting distance of 12cm of this lens would be affected. Might possibly affect the macro ability?
Wow, I did not think of that. They do sell the 15mm with an optional adapter for M4/3, so I was supposing they thought of that. Do you mean that the adapter should be one with optical parts as well ?
Just my 2 cents
Worth way more than 2 cents. Thanks a lot !
Michael Perfect
Thanks so much for taking the time !
The distance seems close enough, but the magnification would not be macro (from my understanding), you couldn't get a subject at 1:1 with this setup (I already have a real macro lens). For me the whole magic of the 15mm macro is that you can do real macroin a wide angle of view at the same time, with pretty big depth of field considering the situation. And at the same time have a cool wide angle lens.
That sounds interesting, does this photographer have any of his work online to check out ? But now we are loosing some of the wide field of view, right ?
Nice
Michael
Current work : MIKRO, the Aliens from Earth (self produced)
https://www.youtube.com/channel/UCC71RypUFAfLnXEVIzw-llA
Michael Perfect
Nice signature!
