Help for angle of view conversion
Started Apr 7, 2018 | Questions
Michael Perfect
Michael Perfect Regular Member • Posts: 182
Hi,
Could someone please help confirming my calculation ?
Is the following correct ?
>>> On a GH-4 M43 camera, the obtained angle of view on the sensor will be smaller with this Laowa 15mm ( https://www.venuslens.net/product/laowa-15mm-f/ ) than on this Lumix 14-45mm ( https://www.bhphotovideo.com/c/product/657970-REG/Panasonic_H_FS014045_Lumix_G_Vario_14.html ) ?
That is surprising to me as the Laowa is a wide angle lens, and the Lumix isn't, but if I understand correctly, because of the sensor crop factor, I would actually get a 30mm with the Laowa lens, and a 28mm with the Lumix, is that really how this works ?
Thank you !
 Michael Perfect's gear list:Michael Perfect's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF 100mm F2.8L Macro IS USM Venus Laowa 7.5mm F2 MFT +4 more
Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Venus Laowa 15mm F4 Macro
JaKing
JaKing Veteran Member • Posts: 6,300
Re: Help for angle of view conversion
More or less, but ...
Lens FLs are nominal values.
WA and UWA lenses vary a lot in the angle of view for a given type and nominal FL.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
csiluk Senior Member • Posts: 1,508
6
Well, 14mm is slightly wider than 15mm.
Martin.au
Martin.au Forum Pro • Posts: 14,339
CapybaraFuture wrote:
Hi,
Thank you !
The field of view from the M4/3s camera would look like a 35mm format camera with a 28mm (lumix) and a 30mm (laowa).
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
JakeJY Veteran Member • Posts: 5,442
14mm is wider than 15mm if the specs are mostly correct (assuming no drastically fudging of numbers). However, there are caveats:
1) FL are typically obtained focused to infinity. If shooting macro, you tend to focus much closer which can change effective FL drastically.
2) It's possible to buy a lens with a smaller image circle, which will cause vignetting or a dark circle. Once you crop out those parts, the effective FOV can be much smaller. You see this with C-mount CCTV lenses that are sometimes available with bundled MFT adapter or with MFT mount.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Michael Perfect
OP Michael Perfect Regular Member • Posts: 182
Hi all,
First of all thank you very much for jumping in;
I am still trying to get my head around this.
From your feedback, I am understanding that if the values given by the manufacturers are accurate, I can conclude that I would have a slightly smaller angle of view with the wide angle Laowa 15mm than with the tiny vario 14-45mm Lumix kit lens. Can you please confirm super clearly that this is most likely true, just double checking to be sure I understand, sorry about that !
I have a follow up question then : it sounds a bit like a waste to buy such a nice lens like the Laowa 15mm macro WA , and not benefit from its full potential. So would using an adapter with optical parts in it, be a smart way to recover the full 15mm field of view (again, working on M43 GH-4 here) ? If yes, any model recommendations ?
Thanks a lot
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Hi all,
Thanks a lot
It might be smarter to get the Laowa 7.5mm (which would do a similar job on the GH-4 to a 15mm lens on a 35mm format sensored-camera).
Dutch
forestmoonstudio.co.uk
My DP Review gallery
Photography is about light, not light-proof boxes.
Martin.au
Hi all,
Yep. While there’s always some fuzz in focal length measurements, this is almost definitely the case.
Thanks a lot
What are you buying the lens for?
Michael Perfect
Right, I've been thinking that too, except that one doesn't have one of the key features I'm interested in, ability to focus at 1:1 macro as well as the 15mmdoes, resulting in a peculiar kind of perspective for macro. It's a very special lens, do you know it ?
Michael Perfect
Partly landscape photography, partly for its capability to focus at 1:1 macro as well, resulting in a very peculiar kind of perspective, as you can have your tiny subject within a much wider field of view as with a regular macro lens.
Dutch Newchurch
I wonder if an extension ring might get you there.
Dutch
Yes, I knew it was a macro as I'm sure many others here also knew that. But that's not what you asked about in the original post. You were just asking about the AOV between 14mm and 15mm. If macro capability is what you want, why ask about these 2 lenses? Your requirements are only delivered by one of the lenses.
Space the final frontier Senior Member • Posts: 1,229
Hi,
Thank you !
When you compare lenses on the same camera, crop factor is irrelevant. Crop factor only becomes relevant across sensor sizes.
 Space the final frontier's gear list:Space the final frontier's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Sigma 70mm F2.8 EX DG Macro +14 more
Michael Perfect
Indeed, I am just comparing the Laowa with a lens I already have, the Lumix I wouldn't want to get the Laowa if there is no way to exploit the real 15mm angle of view on my M43 camera and would get a similar angle of view
Michael Perfect
Right, but I would still be getting a pretty similar angle of view on the Laowa 15mm wide angle than on my Lumix 14-45 kit lens, which isn't even a specific wide angle lens, right ?
Michael Perfect
Are you talking about something like this ?
Yes they would be similar. They don't specifically call it a wide angle because it's both a wide angle to short telephoto. That's why they call it vario, it's variable.
Michael Perfect
Thanks for the clarification. Much appreciated 👍
No. That's an adapter to mount Canon EF lenses on m4/3's cameras. What he was referring to was extension tubes, which when placed between the camera and lens, will allow you to focus closer than the minimum focus distance of the lens you attach it to. It's just extends the lens farther from the cameras sensor and they have no elements inside, just a hollow tube. But you can only focus at close distances when attached. You have to remove it for normal shooting.
Michael Perfect
Yeah ok I see. Yeah with tubes you still wouldn't be able to use that lens as a full wide angle 15mm lens then I can see how it would be useful for its use as macro lens though... Hmm... I'm not convinced about the tubes ! Have you seen the Metabones adapter link I sent (I picked the Canon version because I would be getting the Laowa with Canon EF mount) ? Why didn't that seem like a good solution to you ?
