Olympus PEN e-P5 vs PEN e-PL7
Started Apr 4, 2018 | Discussions
Bridge99 New Member • Posts: 1
It was big thread in 2014 comparing those two cameras, but now other prices, new firmware updates, in doubts which one to choose, need help )
Olympus E-PL7 Olympus PEN E-P5
jwilliams Veteran Member • Posts: 6,400
7
It has a better version of Oly's IBIS.  Otherwise not much difference.  The older IBIS on the 5 and below is really bad and can ruin more shots than it saves.
Jonathan
farmer35 Contributing Member • Posts: 968
Re: 7
I'm going to have to disagree with this.  The question was P5 vs PL7.  I'm guessing you were answering PL5 vs PL7.
Every once in a while I think about upgrading my old P3.  The only advantages I can think of for the PL7 is that it is a bit smaller and has live composite if you need that.  Oh, and a selfie screen.  For my consideration the P5 has more advantages - 2 control dials +a 2-way switch vs 1 control dial for the PL7.  I think P5 has 5-axis IBIS while the PL7 has 3-axis, both do a nice job.
Bruce Regier
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Olympus PEN e-P5 vs PEN e-PL7
The E-P5 (2013 vintage) is heavier but has a better set of controls, that is, a front and rear adjust dial, plus a 1-2 lever to allow certain selectable changes. Pop-up flash in the body. Has 5 axis IBIS.  Flagship Pen of its day. Quite a solid performer. On its release it was plagued by shutter shock, but a firmware update fixed that. It uses the same battery as most of the OM-D bodies. The shutter goes to 1/8000 sec. possibly is a higher quality shutter than the E-PL models have, but that's just a guess. Some help with its menu functions on my page .
The E-PL7 (2014 vintage) is the Lite version of the Pen but still has a great number of features. It has the later image processing chip than the E-P5 and the significant difference (to some) is the availability of the interesting Live Composite mode. The flash is a small separate add-on that needs to be slipped into the hot-shoe and connects via the port under the hot-shoe. The tilt LCD also folds down under and faces forward below the body for the selfie obsessed out there. Has 3 axis IBIS which is theoretically not quite as good as the 5 axis IBIS, the 3 axis misses out on the shift function that can help with macro and close-ups. Shutter goes to 1/4000. Different battery to the E-P5 but same of course as all the other Pen Lites before and after it. Menus are maybe 90% the same as the E-P5 so the link above is also of help if lost in the menus.
Both, with due care, would deliver much the same image quality.
In Australia the supply of new E-PL7 seems to have dried up, but there are still new E-P5 available and at a cheaper price than any of the E-PL models.
Regards....... Guy
