A7R II strange error
Started Apr 2, 2018 | Discussions
sp1te
sp1te Forum Member • Posts: 63
shooting the other night at an event and I got this error has anyone seen anything like this. Taking the battery out worked but putting the camera in the off position did nothing.
 sp1te's gear list:sp1te's gear list
Sony a7R II Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 35mm F2.8 Zeiss Batis 25mm F2
Sony a7 Sony a7R Sony a7R II
C47 Contributing Member • Posts: 759
Re: A7R II strange error
Has this happened before? Maybe you accidentally activated a test mode by a button combination.
 C47's gear list:C47's gear list
Sony a7C Sony a7 IV Sony FE 85mm F1.8 Sony FE 24-105mm F4 Sony FE 35mm F1.8 +5 more
sp1te
OP sp1te Forum Member • Posts: 63
Yea that’s the only thing I could think if it’s jist kinda scary when your on a shoot and you see red
Beaverhelmet Senior Member • Posts: 2,296
Prepararation? Had this been posted on april 1, I would not have been surprised. Never seen anything like it on my A7RII though.
tommiejeep
tommiejeep Veteran Member • Posts: 7,359
Very interesting and scary.  Would you please send to Sony and see if you can find out what it is.  If I saw that I would start by doing a Re-set and then give up if that did not work.
Many thanks,
Anticipate the Light and wing it when you get it wrong but always have fun
Tom
http://images.nikonians.org/galleries/showgallery.php/cat/500/ppuser/165169
101Colors
101Colors Regular Member • Posts: 436
You're not the first to see this.
Look here
This looks like a low level machine code test that somehow the camera has somehow decided to run for diagnostics.
Edit: on further reading, another user also had this issue and the 'solution' was a replacement main board.
 101Colors's gear list:101Colors's gear list
Nikon Z7 Nikon Z 24-70mm F4
Look here
This looks like a low level machine code test that somehow the camera has been decided to run for diagnostics.
Good find! And with the same wonky spelling of "Preparation".
