Rainforest Lens Advice
Started Apr 2, 2018 | Questions
AV8RYTZ New Member • Posts: 6
I am taking a family trip to Malaysian Borneo in October/November and wanted to take the opportunity to finally get some new lenses. I am using the Olympus OMD E-M 5 II, and of my current lenses, only intend to keep my Panasonic Leica 25mm F1.4.
While there we are visiting the Mulu National Park and Kinabatangan River, with many other stops. I wanted to focus mostly on photographing the rainforest wildlife as well as the landscapes of the caves of Mulu and probably Mount KjnKinab as well. This is also a family trip with a 3 and 6 year old as well, so some good family portraits are important too.
I have a budget of around $2500-3000CAD ($2k-3kUSD). I've narrowed down the lenses I'm interested in to these sets:
1. Olympus 40-150mm F2.8 PRO and 1.4x teleconverter purchase, rent Panasonic Leica 8-18mm F2.8-4.0
2. Olympus 12-40mm F2.8 PRO & Panasonic 100-300mm F4.0-5.6 II Power OIS purchase
3. Olympus 12-100mm F4.0 & Panasonic 100-300mm F4.0-5.6 II Power OIS purchase
I'm reluctant to buy the 40-150mm because long-term I want to use these lenses at home and on other trips, and I find this lens quite large compared to what I'm used to. I also feel the 12-40mm may not give me enough range for a regular walk around lens. On the other hand, being in the rainforest I'm worried the 12-100 will not be a fast enough lens for my needs.
Any thoughts or other suggestions would be appreciated thanks!
 AV8RYTZ's gear list:AV8RYTZ's gear list
Olympus E-M1 III Panasonic Leica Summilux DG 25mm F1.4 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +1 more
Albert Valentino Veteran Member • Posts: 9,762
Re: Rainforest Lens Advice
Get the 12-100 and never take it off the camera. No worries about humidity getting inside with lens changes, or carrying extra glass, and with a family along you can enjoy both their company and photogrpahy. It can get dark in the jungle so dual stabilization will compensate nicely
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
100-300mm II. It's weather sealed. Not too big, heavy or expensive. Add the Rösch Feinmechanik tripod collar for balance and flexibility.
http://roesch-feinmechanik.de/29701.html
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Lu1Wang
Lu1Wang Senior Member • Posts: 2,286
You probably want to avoid lens change in that kind of environment with 100% humidity. I would suggest:
- getting an used E-M1 and slap Pany 100-300ii on it for wildlife
- buying 12-100 Pro and slap onto the E-M5ii for landscape/portrait works. Low light won't be a problem in front of the mighty dual IS. I've used this combo in many darker areas and can easily get sharp shots at 100mm with ss 1/30.
No need to bring a third lens, since I would never suggest taking those lenses off the body during the trip.
this way you will have FL 12-300 ready to shoot all at all time without risking changing lens.
 Lu1Wang's gear list:Lu1Wang's gear list
Olympus E-M5 II Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +9 more
alan scott Regular Member • Posts: 493
I second this - I had a similar trip around China, didn't like the idea of changing lenses in wet conditions. I used this lens and never changed it - it handled the wet and humid conditions in southern china without a problem.
Yes it is a bit slow (f4) but you will find the combination of this lens and the EM5 (II) makes for amazing stabilization so it really shouldn't be a problem. Oh and by the way it is excellent optically as well.
Also we had a second camera (EP5) with the 15mm on it - smaller with flash for the evening.
Alan Scott
"Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth" - Marcus Aurelius
 alan scott's gear list:alan scott's gear list
Panasonic Lumix DMC-GM5 Olympus E-M1 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 +17 more
kelvn Regular Member • Posts: 121
Hello,
i think i may be in a good position to answer. I actually just traveled Borneo in Feb whilst backpacking through asia this year. I unfortunately missed out on Mulu National Park but i spent 3 days on the Kinabatangan River.
I  decided to leave my fullframe 5d3 at home and go with the em10ii + 14-42ez + 40-150 (plastic kit lens) + 9-18 + 17/1.8 - quite a step down from my ff and l lenses but overall, im extremely happy with my lens selections
On the Kinabatagan River i was mainly using the 40-150 with questionable success. During post i still had to crop and shoot at 1600iso - predictably during morning and late afternoon river cruises i had problems with noise.  I would 100% no question about it get the 40-150 2.8 with the 1.4x tc. From what ive heard the lens is ridiculously sharp and the 2 stops of extra light compared to my plastic wouldve done wonders for both low light and also for birds (hornbills and kingfishers are magnificent).
I considered mulu national park but didnt have the time, if you do the caves itd probably be advantageous to have a fast wide angle but for the pinnacles im sure that 12mm (24mm equiv) would be enough.
May i also suggest spending a day at kinabatangan national park, there are a few good trails there and if there is one thing to do, you must go to Sepilok. There is an orangutan rehabilitation centre there and also a sun bear rescue centre.
The 12-40 would be useful, but if for specifically wild life 40-150 hands down. Im not sure what other lenses you have besides the mentioned 25 but if you have some light kit lenses bring them along.
 kelvn's gear list:kelvn's gear list
Canon EOS 5D Mark III Olympus OM-D E-M10 II Canon EF 24-105mm F4L IS II USM Olympus 12-100mm F4.0
This pic was one i took on the Kinabatangan river, a wild orangutan and baby up in the trees. Shot at 150mm and then cropped. Not the best shot in the world, but just a good reminder of an incredible moment.
150mm and cropped
14-42ez kit lens
at the sepilok rehabilitation centre
G1Houston Veteran Member • Posts: 3,188
The forest interior is dark, and it will rain
5
If you don't want to end up looking like a photographer for Nat Geo, you may need to prioritize what pictures you want to take. Basically you need fast lens, f1.8 or faster, because the interior of the forest is very dark. After this, you need the reach to capture the monkey and birds who live in the top of the canopy. However monkey is curious and they could get very close to you, so a zoom (100-400) may be better than a prime (300/4), but you need to sacrifice speed. Also you will be going in the raining season so you need to protect your gears against water ...
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Panasonic Lumix DC-GX9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Nikon 85mm F1.8G +6 more
Just keep in mind that IS does not reduce motion blur
... and you need high shutter speed to freeze action (or just movement) ...
yslee1 Contributing Member • Posts: 640
You're right to worry; depending on where you go in the rainforest a f/5.6 lens can be quite terrible under the dense canopy. Sometimes I've had to boost ISO to 1600 or 3200.
Since it's a holiday and not a dedicated photo trip you might want to adjust your expectations accordingly.
jeffharris
Re: Just keep in mind that IS does not reduce motion blur
A few shots from a few years ago in Costa Rica, Punta Cahuita on the Caribbean Coast.
GX7 w/ 100-300mm I & Rösch Feinmechanik tripod collar with an UltraPod II braced against my chest. No cropping!
Coastal rainforest and definitely pretty dark.
Howler Monkey?
Eyebrow Viper. GX7 & adapted Nikon 105mm f2.8 AI-S macro lens
White-faced Monkey
mcabato Senior Member • Posts: 2,169
lens choice acc. to your suggestion no.1
there is never the problem of changing lenses, bu the problem of lack of light in the jungle.
so, take the fastest lenses you can get, including your leica lens plus the 2.8/40-150.
depending on the season, you will face rain one a day for one hour. so, be prepared to get wet allover when marching.
enjoy your trip!
BR gusti
 mcabato's gear list:mcabato's gear list
Olympus E-3 Olympus E-330 Olympus E-5 Olympus OM-D E-M5 Olympus E-M1 +15 more
Sranang Boi Senior Member • Posts: 2,860
As someone who was actually born in a rain forest (the Amazon) the advice I would give you is to think about water getting into the lens via the extendable zoom tube. If it does, then you'll soon have condensation inside the lens on your hand. This can easily happen if your lens gets soaked in a rain downpour. The Pansonic 35-100mm f2.8 and the 45-175mm are the only two Lumix lenses I can think of that don't have this problem for you to worry about. The Olympus range of weather sealed lenses are on the other hand far more superior in that respect.
As for light levels: it all depends on the time of the day. Come 6:00PM you stand zero chance of seeing further than a few feet ahead of you, let alone take a picture. But at 12:00PM the light level is actually far better than the naked eye makes it out to be. Consider taking a long range flash with you. I have used my Panasonic flash to take pictures of non-flying objects sitting on branches etc at quite some distance (50 to 100mm with the FL-580L). The zoom head on the flash helped. Light levels in the undergrowth are low enough for it to be possible to use flash synch speeds of 1/250s or less.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
LarsPolarBear
LarsPolarBear Contributing Member • Posts: 585
5
I have been to Malaysian Borneo many times over the past 15 years and have been to all the location you mentioned, except Mulu Caves (btw, it just lost it status as world largest cave last week to a cave in Vietnam).
However, as always, advise depends a lot on personal preferences. For me light travel is of great importance, therefore I take a very small gear pack (Pen E-PL7 & 14-42 EZ & Oly 75-300 II), but for optimal picture quality this is not the best selection. So, I will keep my comments rather general and let you decide what is important to you.
Your travel is in the dry season, so therefore, "haze" (the smoke from burning down virgin rainforest) might be of more concern than rain (I suggest to bring some face masks). However, it will still rain heavily, but not that often. If you don't climb Mt. Kinabalu, don't bring rain jackets, since you will sweat to death (GoreTex does not work due to the little difference between body temperature and environmental temperature), bring umbrella instead.
The E-M5 II is a nice camera and with weather seal a good choice. However, as mentioned by others, even if you shoot with a 300mm (600mm @35mm), you will crop a lot. So, If you plan to get a new body anyways, think of getting one with 20MP (e.g. Pana GX9). The 25mm f1.4 sounds nice due to it being fast. However, it depends a lot on how much gear you want to schlep around... for me it would be too limiting, but then again, it's up to preferences.
Sounds like a VERY nice trip and I envy you!!!
It seems you will be spending your time in Saba (northern state of Malaysian Borneo). Other places to visit there (might be already on your itinerary) are:
- Danum Valley (virgin rainforest)
- Turtle Island (watch sea turtles laying their eggs at night)
- Sepilok Orang Utan sanctuary (watch one of the most amazing animals on this plant close up)
- drive up to Kudat from Kota Kinabalu (most northern point of Borneo)
- go scuba diving around Pulau Sipadan (see large schools of barracudas, sharks, sea turtles and fantastic corals).
etc. etc. (if you want some more ideas let me know...)
Mt. Kinabalu (about 4100m):
If you want to climb it, you need to book a permit and it takes two days to go up and down. To just visit "base camp" and have a look, best to get there in the morning, since the peak covers up at around 10am.
As mentioned by others, the rainforest is a rather dark place, therefore the faster the lens the better. However, with some practice (get your new gear as soon as possible and start practicing ), you can manage with slower lenses, but might loose some image quality.  For wildlife a long lens is crucial, in my opinion min. 600mm eq., better longer if you shoot a 16MP body (e.g. the ridiculously expensive Pana 100-400mm).
The Oly 40-150mm appears to be too short for me (incl. the 1.4x teleconverter) and it is heavy, it would not be my choice. The Pana 8-18mm sounds good for the caves, but might be too much for the rest of the trip (I have no experience with this lens or anything similar, so it is just a guess).
Sounds good to me, except I think the Oly 12-40mm is quite heavy, but again, that comes down to preference. Both weather sealed and covering all important focal lengths.   However, the Pana 100-300mm is rather slow, so be prepared to crank up the ISOs.  For best picture quality, I think, there is no better option than the Oly 300mm f4 (best with 1.4 teleconverter), but that monster is very expensive and heavy...
Not sure about the Oly 12-100mm, if you want some more reach than the Oly 12-40mm, I would rather consider the Pana 12-60mm f2.8-4.0, since you loose only little focal length, but gain important light sensitivity on the short end (good for street photograph at night).
as said, perhaps the Pana 12-60mm f2.8-4.0 as a compromise?  Not much smaller than 12-40mm though...    I still like the 14-42 EZ as a walk around lens, even though it is VERY limited it is a ability - whish Oly would do an update...
Changing lenses in the rainforest:
Some other members of the forum have suggested that it is a "no go" to change lenses in the rainforest and that you need a second body.  I would not agree with that.  Most people here in the region shoot with only one body and change lenses all the time (or have you heard Robin Wong taking always several bodies on his shoots - nope!).  If it really pours, you will look for shelter anyways and so will the animals.  I would not bother bringing a second body due to humidity or rain, if you don't want to miss a shot due to lens change that is a different story...
Hope this helps a little...
Enjoy your tip!!!!
Lars
Here just some shots from Borneo (mostly taken around Kuching in the south), I have shared these before, so ignore if already seen...
wild Orang Utan at sanctuary
Spider in difficult light conditions
Proboscis Monkey
Baby Long Tail Macaque
Green Viper - better have a long lens
C Sean Veteran Member • Posts: 3,423
I went to Costa Rica in 2014 and back then I found it difficult shooting inside the rainforest. I have become a better photographer since then but make no mistake it is a challenging situation. You will require lenses that are both fast, weather sealed and got some reach to it.
I only speaking about Costa Rica rainforest and each rainforest maybe different. At a Costa Rica point of view, there's a lot of wildlife in the rainforest but the majority of them are up in the trees and you won't get to see them. The best M43 lens for this are 35-100mm 2.8, 40-150mm 2.8 and maybe the 200mm 2.8. The question you need to ask yourself is how often will you use these lenses after you return home?
The most important thing to consider is weather sealing and a water proof bag for your gear.
OP AV8RYTZ New Member • Posts: 6
Thanks to all for the tips. I ended up going a different route than I was intending and got some good used lenses from eBay, and so was able to get the 12-40mm F2.8 and 40-150mm F2.8 along with the MC-14 teleconverter. Ultimately that was what I wanted but couldn't budget for it until I decided to try the used market.
Hopefully in a few months time I'll have some good photos to post.
Dan P Regular Member • Posts: 127
Great choices on the lenses.
I would also recommend a decent tripod - they make a world of difference in the rainforest.
Dan
With that combo you should be able to do most anything - both these lenses are great for closeups and the 40-150 with the TC gets really close. Have fun 😃
jeffharris
That depends on trail conditions, assuming one is hiking.
On different trips to Costa Rica, Colombia, the Caribbean and of course hiking in Northern US forests, wrestling with a tripod or even a monopod is a major distraction. Longer? Shorter? Long short. Long short. Long short. Is there enough room for the legs? Etc. etc. Maddening!
On a trip to the Caribbean rainforest of Costa Rica, I got tired of struggling and put the monopod away and thought to use my UltraPod II against my shoulders and chest, thinking of the intriguing monopod shoulder brace I’d seen online.
It worked GREAT! With a solid stance, I was able to take long shots with GX7 and 100-300mm that weren’t too blurry. 😉 it was definitely helped by the GX7’s tilty EVF, especially shooting UP!
It’s also MUCH easier to hike with the UltraPod mounted and rarely have to fuss with the thing. It was easy to rest on branches, trees, rocks or the ground for longer exposures, too.
I’ve seen beefier chest-pods online, mainly for DSLRs.
larsbc Forum Pro • Posts: 18,282
I completely agree with you. Humidity gets into the camera, no matter what. If people are concerned with the camera or lens fogging up, they need to be more concerned about temperature changes.
http://nickgarbutt.com/rainforest-photography/
https://www.the-digital-picture.com/Photography-Tips/cameras-humidity-condensation.aspx
https://www.photo.net/discuss/threads/unsealed-bodies-in-tropical-humidity.351054/
