Sell me on the 35mm F2
Started Mar 30, 2018 | Discussions
Banana Peel New Member • Posts: 18
It's the first lens one should get! https://thewirecutter.com/reviews/the-first-fujifilm-lenses-you-should-buy/
The camera comes with a good 18-55 already, and I'm having a hard time imagining when I would trouble to switch that out for the 35mm. The 35 opens up a stop or so wider, but loses the OIS so that's a wash.
One could reasonably make the small and light case, but wouldn't the pancake be a better answer?
What am I missing? Why is the 35mm a must-have lens?
 Banana Peel's gear list:Banana Peel's gear list
Apple iPhone 11 Pro
chimphappyhour Senior Member • Posts: 1,087
Re: Sell me on the 35mm F2
Just search for any thread (here or on Google) on the 35mm f1.4 vs f2 and you'll have more info and opinions than you could ever stand to read.
 chimphappyhour's gear list:chimphappyhour's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
colombiano
colombiano Contributing Member • Posts: 696
5
Get the 1.4! You won't regret it.
Just Shoot Me Veteran Member • Posts: 4,110
7
If you need to be SOLD on getting the 35mm f/2 lens then you don't need it.
I have both f/2 and f/1.4. Both very good lenses. Yes I use both for different things.
 Just Shoot Me's gear list:Just Shoot Me's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
OP Banana Peel New Member • Posts: 18
Great answers, though I'm not deciding between the two 35mm lenses...
Apple iPhone 11 Pro
Yeah but if you search any thread here or elsewhere pertaining to the comparison of the two, you'll still get a ton of information. Not really any need for another thread to explain the pros and cons of this lens.
JS Burnie
JS Burnie Veteran Member • Posts: 4,280
Have a look at the reviews of the 18-55mm and the 35mm f/2 at Lenstip
https://www.lenstip.com/
I see that their tests show much better image resolution for the 35mm f/2 vs. the 18-55mm at 30mm.  I find that the 35mm f/2 is quite sharp in the centre, though less so at the edges.  I use it very frequently on my X-E style bodies.  If you like this focal length, it's a good buy and not unreasonably expensive, IMO.  BUT, the 27mm  pancake is also very nice.  AND, if you want a faster lens (aperture), the 35mm f/1.4 has many groupies.
Best of luck deciding.
 JS Burnie's gear list:JS Burnie's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 27mm F2.8 +5 more
MarcosV Veteran Member • Posts: 6,522
No way is the 35mm is a must have lens.  I much prefer the 23mm focal length over the 35mm focal length for my first main prime.
Note that the 23mm f/2 is the sort of lens that's permanently attached to the X100 series.
I personally don't like the Fujifilm pancakes enough to use one of them as my first or second prime.  You compromise to get a slimmer form factor; I don't want to give up a aperture ring, better AF, shallower DOF, etc., for a slimmer form factor.
If you have a WR camera body like the X-T or X-Pro series, the f/2 primes gets you that weather resistance that can come in handy in light rain.  The much faster AF can be a big bonus.  These lenses focus close enough that you can get some nice background blur for subject isolation, even at f/2.
 MarcosV's gear list:MarcosV's gear list
Sony RX100 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm +28 more
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Sell it to yourself
5
Everybody's got one (an opinion).
Then sit tight. See how you fare with the 18-55 in the meanwhile.
Depends on the pancake.
It's not, unless one takes everything they read literally.
I've got some nice wet photos with the 35/2, it's one of my go-to lenses - but that doesn't necessarily mean it's right for you.   What and where and how we each go about our business has a lot to do with what is a must-have.
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Vic Chapman Forum Pro • Posts: 10,694
I second the f1.4 lens which gives you 2 + stops over the zoom and a special rendering.
Why are you considering a lens without knowing which you need and why?
If you don't know what lens need - you don't need it!
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
Frodro100
Frodro100 Regular Member • Posts: 386
In regard to the bolded text, I think the answer you need to hear is "if you need to ask, then you don't need it."
As others have said, even a cursory look around the forum will give you more information than necessary to answer your question. My two sentence explanation follows: 35mm f/2 is capable of lots of types of photos, including portraits with a thin depth of field to isolate the subject. The 18-55 is going to have a max aperture in the f/3.5 range above 35mm, so it is not as capable of a portrait lens.
Personally, I prefer the 23mm f/2 for the utility of its field of view while still being compact, so I'm not going to try to sell you on a lens I don't use.
Keith Williamson Contributing Member • Posts: 528
I have the 35mm f2 lens which I bought to use on a XT-1 body that I kept when I got my XPro2. In truth, I rarely use the body nor the lens. Why would I bother taking the 18-55 lens off the camera to use the 35mm f2. As for the 56mm f1.2, that is another story.
 Keith Williamson's gear list:Keith Williamson's gear list
Canon EOS 5D Mark III Fujifilm X-Pro2 Canon EF 50mm f/1.2L USM Canon EF 17-40mm f/4.0L USM Canon EF 100mm F2.8L Macro IS USM +9 more
pseudobreccia
pseudobreccia Contributing Member • Posts: 939
If you want sales talk...go to a store.  I have the 35mm F1.4 and really like it...I would probably say the same thing about the 35mm F2 if I had one.  Don't develop the mindset that you should skip buying a prime lens if you already have a zoom that covers a certain focal length...doing so would be a mistake.
Steve A. Kleinheider
 pseudobreccia's gear list:pseudobreccia's gear list
Fujifilm X100F Fujifilm X-Pro2 Pentax K-1 II +7 more
Tua52
Tua52 Junior Member • Posts: 28
If you don't need faster than f2 then you will be happy. It's small, sharp and fast. Bokeh is pleasing too. I needed a faster lens for low light so I ordered the Samyang 35mm f1.2 . Why? Becouse I don't need AF for the images I shoot (mainly portrait) and I have a very good experience with the Samyang 21/1.4 lens. It was the same price too.
Justin9999 Contributing Member • Posts: 725
The impact of different aperture sizes is more meaningful to the artistry (DOF & starbursts) of the image moreso than the ability to collect light.
Assume you know a lot more than me and teach me at will.
 Justin9999's gear list:Justin9999's gear list
Fujifilm X-E2S Fujifilm X-H1 Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm 16-55mm F2.8R LM WR +3 more
Peter3579 Contributing Member • Posts: 759
It all depends on what you intend to shoot.
i have the 18-55, 23, 35 and 50 f2’s.
the f2 lenses focus much faster, plus those extra stops.
the 35 is my least used f2. The 23 is great as a walk around / street, the 50 ideal for taking nAtural light images of my never sit still granddaughter.
i bought the 35 (used) as I thought it might suit me better for street, but not so.
as others have said, shoot a lot with the 18-55, analyse your focal lengths and see what will suit you best, for what you intend to shoot.
 Peter3579's gear list:Peter3579's gear list
Ricoh GR IIIx Nikon Z7 Nikon Z50 Nikkor AF-S 300mm f/4E PF ED VR Nikon AP-F 70-300mm F4.5-5.6E +10 more
KalleAnka Regular Member • Posts: 180
They are very different
First, the 35/2 is more like 1.5 stops faster at the same focal length.
For living subjects that move, no OIS in the world will save you. There are no shortcuts. You need a fast lens.
35/2 is much smaller and lighter. Perfect for street shooting  etc.
35/2 is weather sealed.
35/2 has faster focusing. Really good actually.
35/2 is a perfect walk around lense for shooting people/ street/portraits etc.
The zoom is more a general purpose lens e.g. for travel.
TEAS Contributing Member • Posts: 954
.... many reviews on YouTube also     It is a great lens
 TEAS's gear list:TEAS's gear list
Fujifilm X100F Fujifilm X-T20 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro +17 more
Thanks all. I think I'll hold off on the 35mm for now. Perhaps one day when I go 18-135 rather than 18-55, a 35mm will make more sense as a companion.
"As for the 56mm f1.2, that is another story." Agreed! Even I can see good reason to exchange lenses for the 1.2. particularly for portraiture. This is a delightful lens.
Apple iPhone 11 Pro
JS Burnie
Re: They are very different
+1  Good summary.  That about sums it up for me.  Disclaimer: I don't own the 18-55mm.
