Please advice on Error 01/clean camera and lens contacts
Started Mar 26, 2018 | Discussions
Badrmino
Badrmino Forum Member • Posts: 92
Hi there
I am asking this question on behalf of my friend who has the Canon  700d camera and bought a used tamron200-500mm . The lens showed Error 01/clean the contacts,  so we did that with a soft cloth (it appears clean to start with) . Received the same massage
I have a Sony a6000 and tried with Viltrox adapter  and it worked. Slow and temperamental  but this is the what I get with other lenses using this adapter anyway. So it does not seem there is a huge internal issue
And yes the Canon camera works fine with other lenses
Any ideas will be appreciated
Thanks in advance
Badr
 Badrmino's gear list:Badrmino's gear list
Sony a6000 Sony a99 II
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i) Sony a6000
Blue II
Blue II Veteran Member • Posts: 3,898
Re: Please advice on Error 01/clean camera and lens contacts
Maybe check with Tamron to see if there's a firmware update needed.
Steve
 Blue II's gear list:Blue II's gear list
Canon EOS-1D X Mark II Canon EOS RP
brightcolours Forum Pro • Posts: 15,885
User5049779158 wrote:
Hi there
There is an issue with the communication. Can successfully close down the aperture on the Sony combination? Can you successfully shoot on the Canon with the lens aperture wide open?
Or does the Canon complain right away when you mount the lens? Or just when pressing the shutter to take an image?
Thanks in advance
Badr
Acalthu Regular Member • Posts: 109
are any of the pogo pins on the 700D damaged, or sunken in compared to the others?
 Acalthu's gear list:Acalthu's gear list
Canon EOS Rebel SL2 Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
Badrmino
OP Badrmino Forum Member • Posts: 92
Thanks I might give them a try.
Badrmino
Hi there
Thanks in advance
Badr
Yes I can close the aperture on Sony and it is working, The Canon complain right away like you said.
Thank you
Badrmino
No they all look good and other Canon lenses are working perfectly.
