G9 first impressions
Started Mar 22, 2018 | Discussions
amipal
amipal Senior Member • Posts: 1,275
11
The G9 was always going to be my next camera after my beloved GH4. As a long-term owner of GH cameras, I've always used them for photography and rarely for video - I found the horsepower under the bonnet made them particularly good for photos.
So when Panasonic announced a photography-focused camera in a similar vein to the GH5, I was instantly attracted to the prospect.
I am in the fortunate position with work to receive an annual bonus, and when I checked my account this month and saw that it had arrived, I was instantly in the car and on my way to Park Cameras.
And returned with a big black box containing one Lumix G9 camera.
So, my thoughts...
It is noticeably bigger both in the hand and visibly than the GH4, and the GH4 always struck me as a large m43 camera. It is comfortable in the hand though, fitting the hand perfectly with all the controls within reach without moving (though I'm struggling to find the joystick - more because I haven't had to before than anything).
Speaking of the joystick, I'm loving it for the instant manual focus with my Voigtlander 17.5mm lens. Simply clicking it in zooms, allowing me to focus much more quickly and accurately with it than with the GH4.
The EVF also assists in this. I can actually manually focus with a degree of accuracy I'd never experienced before. And that's before you zoom in.
I've got the EVF set to the middle-zoom setting, due to wearing specs. If I mash my face right up to it, I can see the corners at the widest setting, but it isn't very comfortable...
Image quality is brilliant. I have noticed a magenta cast when pushing RAW files that isn't present in the same test scene shot with the GH4, but I should be able to fix this in post.
I've taken some test landscape shots in the standard 20mp resolution, and the image appears sharp throughout. Trees certainly jump out of the horizon better than they did with the AA-filtered 16mp sensor on the GH4.
I did test the 80mp pixel-shift mode with a still-life, and am highly impressed with it. Whether it's worth shooting that rather than the standard resolution, I'm not sure - I've never had to print anything over A3 borderless in size. I think the best test would be a landscape scene, so will try and find something good for that.
Read and write speeds to SD cards are swift, and I don't even have any of the UHS-II capable cards. Quick 4K clips wrote without issue to them, but I wasn't using 4K/60.
The top-plate LCD hasn't really factored into my conscious yet. I've never owned a camera with one, so have never felt like I've been missing anything by not having one.
Anyway, that's it for now. If I think of anything else, I'll add it to the comments below this.
Paul
PS. The G9 used the same batteries as the GH4. I didn't think they did, and bought an extra one, despite having two extra ones at home (and one in the GH4).
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
Panasonic Lumix DC-G9 Panasonic Lumix DMC-GH4
bigsambwfc Regular Member • Posts: 184
Re: G9 first impressions
tried the g9 at the photo show with the pl100-400lens and was very impressed with it,the lvf is excellent for spectacle wearers and is so clear, I use the mk2 Olympus at present and I am happy with it but the g9 just has the edge at present. the sony a9 was good also and will be formidable if the 400mm -2.8 lens is a good one but the price is a lot for it I will wait to see tests of this set up, I think you made a good choice with the g9.
 bigsambwfc's gear list:bigsambwfc's gear list
Olympus E-M1 II
amtberg Veteran Member • Posts: 6,217
Similar situation here, except I had a G85 in between the GH4 and G9, which I just received yesterday.  So far I'm very happy with it.  For me it's ergonomically much better than the G85.  On the smaller camera my pinky finger was a bit squeezed to get on the grip.  And I HATED the slippery, low profile buttons on the G85 (which I otherwise liked just fine).  Also, it's a huge deal to me that there's finally a minimum shutter speed setting and EV comp. in manual video mode.
EVF on the G9 is great, and I can use the full size despite being a glasses wearer.  I really like the extra function buttons on the front of the camera, which I've assigned to min. SS, and AF type.  I reassigned F1 to Playback, as I hate having that button on the upper left.
Wasn't sure I'd use the joystick, but I'm finding that I do.  Quite handy for scrolling around menus as well as moving the AF point, and the click to recenter is so much better than having to hit the Display button on other Panny cameras.
VisualFX
VisualFX Senior Member • Posts: 1,241
I'd like to know why the EVF display shakes, when half-depressing shutter to focus? What causes this? The DFD focus? I tried the GH5 and G9 both in store, and both did this. Also not too impressed with the EVF. I wish Panasonic would start using OLED for both the EVF and LCD's.
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
Helen
Helen Veteran Member • Posts: 7,606
It actually is an OLED EVF on the G9, by the way...  Maybe you meant the GX9?  Or the monitor (which is of course an LCD one on both these models).
If you mean the fast pulsation of the image on half-pressing the shutter release in C-AF, then yes, that's the CDAF-based DFD system monitoring the situation, even when it is settled on something that's in focus.  Actually, in my experience all CDAF systems do this, but the G9 does it faster than most.
Kent Ekasak
Kent Ekasak Contributing Member • Posts: 766
Congrats for your purchase.. I played around with G9, and despite its weight and size, the ergonomic and EVF are surprisingly one the best and most comfortable I have tried..
 Kent Ekasak's gear list:Kent Ekasak's gear list
Panasonic Lumix DC-GX9 Sigma fp Panasonic Lumix DC-S5
sea_dragon Contributing Member • Posts: 836
Congrats!  I also just got a G9 along with the Pana-Leica 12mm prime.  Was playing around with it tonight and while playing back some photos I took, I suddenly got an error “The lens is not attached properly”.  Camera and lens are brand new so not sure what to think of that.
Otherwise, I’m very pleased with it.
(unknown member) Forum Pro • Posts: 19,317
I agree i was out shooting with my em52 this morning and deceided to go and have a look in a large camera shop while i was in the city. Had a play with the g9 and the evf wasnt the same quality as the oly it was like it was blurry , not quite sharp and panning it stepped and completely blurred the image, my eyes went funny just tring to look into it.
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
gwaschoenmakers New Member • Posts: 18
Did you use a tripod?
What about removing the Eye cup when wearing specs? Did you try this?
I'm saving my money for a G9 too
 gwaschoenmakers's gear list:gwaschoenmakers's gear list
Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Sigma 30mm F1.4 for Micro Four Thirds
amipal
OP amipal Senior Member • Posts: 1,275
That is very odd behaviour. I've noticed nothing of the sort in my camera.
Could the blurriness have been down to the diopter setting? No idea about the other effects though!
Paul
amipal
Yep, mounted on a tripod. The process if very quick, and does it all in-camera to boot. I was pleasantly surprised by the output! Maximum shutter of 1 second though.
Haven't considered removing the eyecup...
Paul
Paul
the vf was clear and bright and you really couldnt notice the pin cushion at all you had to look really close. i focused the diopter  so the focus square was really sharp but the image behind was slightly blurry , im wondering if the lens had something to do with it
Don
FriskyMoose New Member • Posts: 8
I received my G9 with the LEICA 12-60 and 8-18 and all I can say Panasonic got it right.
Been shooting Nikon crop and FF gear for years and still love my D810 BUT the G9 is a beauty of camera. Only had time to play with it indoors and OMG is the AF fast and the speed the camera operates is simply amazing.
From the build quality to the ergonomics. The grip is deep but not too deep, the overall button layout is for my medium sized hand spot on and I can’t believe saying this but the EVF is miles better than shooting through my D810 viewfinder.
I have two Of the 300MB/s SanDisk 64GB cards in the body and the buffer clears like mad.
Now i need to find a good new bag for the set I have and need to figure out what features I assign to the fn buttons that would be best suited to my shooting style.
Its an expensive camera but I did not regret this purchase.
Anyone got any view on a camera bag? Looked at the PeakDesign sling 10L or the Tenba DNA 11.
 FriskyMoose's gear list:FriskyMoose's gear list
Sony RX100 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Panasonic Lumix DMC-LX5 Nikon D70 +9 more
amipal
I remember getting this in the past with another body, the Gh2 I think. A remount sorted it - could just have been a bit of fluff in the mount I guess!
Enjoy your new camera and lens!
Paul
amipal
Have you shot with m43 before? The AF is impressive, particularly in low light.
I still need to invest in some fast cards. Will need them for the Royal International Air Tattoo in July!
I have a small bit of buyers remorse, mostly down to not having enough time to get out and about with my camera. Will the G9 really give me better shots than my stalwart GH4? Remains to be seen.
I've been using a Thinktank Retrospective 5 for years with m43 gear. The G9 may be a bit big for it... but I really need to get out with the thing to truly work out if that's a problem.
Enjoy the G9!
Paul
Can imagine
Yes. Manfrotto has some nice bags, first one is still on sale but has no options for carrying a tripod:
1) https://www.manfrotto.nl/advanced-active-sling-1
2) https://www.manfrotto.nl/nx-camera-and-laptop-backpack-v-blue-for-dslr-csc
Regards!
amipal
A couple of negatives...
...to positives!
I felt a bit peeved that the drive dial no longer contains the exposure bracketing setting for HDRs. Which meant diving into the menu every time I wanted to use it.
In addition, I couldn't assign the zoom-focus view to one of the forward function buttons.
BUT
With a bit of playing, I've managed to set bracketing to the front lever, and pinpoint zoom focus to a front function button! Huzzah!
The latter is particularly useful for manual lenses.
Paul
amipal
Re: A couple of negatives...
Well, sort of.
Further testing shows that the pinpoint zoom focus only works when AFS/AFC are selected on the focus-lever. MF does not allow it.
So while it is useful for autofocussing Olympus and Panasonic lenses, it isn't for my manual lenses like the Voigtlander f/0.95 17.5mm.
I'll have to conduct further experiments.
Paul
