Re: Panasonic GX80 + Panasonic 100-300 for Safari
Aitoritu wrote:
I just recently came back from an amazing trip to Tanzania. Although I only own what is considered to be a basic equipment, I am more than happy with the results. I was surprised with the sharpness I got even when using the Panasonic 100-300 (works much better when the subject is closer, even at 300mm, suffering a bit on distant subjects, do not know if anyone else has the same experience). Focus was good, not perfect, but at 7 FPS I always had enough pictures to choose from (I was lucky to see two Cheetahs hunting and the result in this fast action scenario was OK). The size of the equipment is amazing, I had to share the car with other people and carrying a FF long lens would have been impossible. IBIS helps a lot when using a long lens...
I think that m43 shines for wildlife photography, when carrying huge FF lenses would be impossible or too expensive. Of course it has its downsides. I always tried to keep ISO below 800, but always had enough light available.
Panasonic GX80 + Voiigtlander 42.5
Panasonic GX 80 + Panasonic 100-300
Thank you for sharing these wonderful pictures with us.
I fail to see the point of those commenting that the results at 300mm will be terrible when your own results prove otherwise. One reason is for best photo shots of wildlife the subject needs to fill much of the frame for more accurate focusing. At a distance atmospheric conditions and haze are factors with any camera and lens and having up to effective 600mm range is very good for just about everything. While stepping aperture down improves picture IQ quality for FF for m4/3 the tele lens is already near diffraction effected so shoot near wide open for a higher shutter speed.
You make a very valid point of the relative size of tele lenses as use a big bazookas in a crowded vehicle not good for getting imprompt shots; nor practical. My one question relates to action shots as I far prefer use of an optical viewfinder K50 for fast auto focus (but then have to settle for lessor focal length to keep size compact) and seeing what I am getting with the EVF on my OM-5. Were you satisfied with the viewing thru you GX85 EVF?
Again many thanks for sharing
