Lens
Started Mar 19, 2018 | Discussions
rtnrtnrtn7 New Member • Posts: 16
Lens
i just brought omd em5 mark ii. Now i need a lens. I want a small/pancake lens. I shot potrait, nature, landscape. I use for travel too. I confused between Panasonic 20mm f1.7 II, Olympus 17mm f2.8, Olympus 25mm f2.8, Olympus 14-42mm f3.5-5.6, Panasonic 14mm f2.5, and Panasonic 12-32mm f3.5-5.6.
what will “you” choose between all that lens?
or maybe you know other good lenses?
Thank You.
Olympus OM-D E-M5 Panasonic Lumix G 14mm F2.5 II ASPH
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
Re: Lens
5
If you want pancake, and only one lens, then definitely the 12-32. However, everyone is different and so you will get a bunch of different answers and neither of them may be worth much to you. Just depends a lot on your shooting style and subject matter.
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
Lu1Wang
Lu1Wang Senior Member • Posts: 2,287
Re: Lens
Portrait and landscape requires different FL. If you want both FL in one pancake, then you have to go with Pany 12-32 or Oly 14-42. Both got slow f stops, which you will have to give up a lot of DOF control.
As for primes, you can't go wrong with 20mm f1.7 most general use, add an 45mm f1.8 and you will be set for portrait.
 Lu1Wang's gear list:Lu1Wang's gear list
Olympus E-M5 II Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +9 more
rashid7
rashid7 Veteran Member • Posts: 7,011
Re: Lens
+1
Remember, (admitting there is often copy-to-copy variation) Panasonic kit lenses are sharper than Olympus equivalents.  And 17f2.8 has an awful reputation.
Keep it fun!
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Re: Lens
Thank You.
If I were to choose only one lens, it would always be a zoom.  I don't like the restriction of a single focal length.  My first m43 lens was the Olympus 12-40mm 2.8.  I own several zooms and seldom use my fixed-focal-length lenses.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
