EOS 80D or EOS 800D - Opinions appreciated
Started Mar 15, 2018 | Questions
Garyjl New Member • Posts: 10
Hi, I’m a little confused and hope others on this forum can give me their opinion. I currently have a Canon EOS 650D and I was looking a adding a Canon 70-200mm f/2.8 USM lens to it. Which I think would be a good portrait lens as well as great lens for taking wedding and event photos. I have lots of nieces and nephews who always seem to ask me to take the wedding photos.
After ready comments on various forums I’m starting to wonder if my 650D is a good enough camera to get they most out of the lens so thought I might upgrade, but to what? I like the EOS 80D and according to Canon’s website here in Australia the EOS 80D is suited for the enthusiast rather than being an entry level camera. The other camera I am looking at is the EOS 800D which is very similar in specifications to the 80D but is cheaper.
So my question is two fold, is my 650D capable of getting the most out of the 70-200 lens? If not than I need to upgrade and the question is, is the 80D a much better camera when compared to the 800D?
The more I read the more confused I become.
Opinions greatly appreciated.
Kind Regards
Gary
Canon EOS 80D Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i) Canon EOS Rebel T7i / EOS 800D / Kiss X9i
M19 Regular Member • Posts: 335
Re: EOS 80D or EOS 800D - Opinions appreciated
Kind Regards
Gary
The 650D is an APS-C camera so it can only use half of area of the 70-200mm which is a full frame lens. If you really want to get the 70-200mm f/2.8 better upgrade the camera to full full frame as well.
Pairing the 70-200mm f2.8 to a full frame would give you the most background blur which is normally wanted in portraits. Depending on your budget, you can get a 6D, 6D mark II, 5D mark III or 5D mark IV (listed from cheapest to most expensive). A 6D is close to price to an 80D, while a 6D mark IV practically gives you an 80D with a full frame sensor.
If you want to stick to APS-C cameras like the 80D and 800D, you can look instead at Sigma's 50-100mm 1.8 which would give you the same depth of field control as the 70-200mm except that you'll have a lesser useable range of 80-160mm, and you'll loose the image stabilization.
crashpc Veteran Member • Posts: 7,240
For weddings, I suggest you have at least two bodies, and they are reliable and tough enough. So at least two 80D as a minimum.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
davev8
davev8 Veteran Member • Posts: 4,837
Kind Regards
Gary
800D and the 80D have the same sensor so the IQ will be the same  and this 24MP sensor is a very good step up from your 650 and not just the MP ...has much more Dynamic Range ..but that will only help if you shoot raw or want to recover botched exposures or lift shadows    the 80D AF will be a step up from the 800 ..but if you had no problems with AF and your 650 then the much improved AF in the 800 will be fine..there is also the 77D  which is a 800D with a top LCD and 1 or2 other bit and bobs ...wither the 77d is an option will depend what price it is in your country...if its priced close to the 800 it may be a good buy if close to the 80D or in the middle  then no
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
Political correctness....somebody being offended on someone else's behalf....who that someone doesn't give a damn in the first place ....David Appleton
quoting irrefutable facts may get you branded a racist ..even if no race is involved .......David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
OP Garyjl New Member • Posts: 10
Thank you for your reply. I have some more thinking to do. To workout exactly what I want. Cheers....
Thank  you for your reply......
R2D2 Forum Pro • Posts: 26,551
There is a killer deal on a ($374) refurb SL2 from Canon right now...
SL2 St Patrick's Day Sale
Use these two bodies for now, and save every single penny for the (eventual) move to Full Frame.
R2
