Do you prefer using low, mid, or high apertures for focus stacking?
Started Mar 14, 2018 | Polls
MacM545 Contributing Member • Posts: 780
Today I'm trying to figure out what is preferred, a quick aperture (such as f/1.4), a mid aperture (such as f/8) or a slow aperture (such as f/22) for focus stacking. Theoretically, using quick aperture will reduce time but also increase the number of photos necessary and might take up more space. Generally mid apertures provide good sharpness, and I suppose quick apertures could be helpful in some kind of situation even when lighting is adequate, while slow aperture stacks don't require the stacking process to work as slow. My best guess is that a mid or slow aperture is best, and I could also be wrong. Perhaps instead there's a better answer that I could add?
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
POLL
Quick apertures
7.7% 1  vote
Mid apertures
84.6% 11  votes
Slow apertures
7.7% 1  vote
  Show results
csintexas
csintexas Senior Member • Posts: 1,184
Re: Do you prefer using low, mid, or high apertures for focus stacking?
I have not done much stacking but I guess I always have set my f/stop as high as possible up to f18 (I do mostly live subjects outdoors) and no more than ISO200 but try to stay at 100
I can't think of a reason there would be for a wide aperture other than inadequate light and ideally that would be fixed by adding more light.
I guess if one where shooting a static subject in the studio with a very precise focus rack system shooting at the ideal aperture for any given lens may be desirable.
 csintexas's gear list:csintexas's gear list
Sony a6400 Sony FE 90mm F2.8 macro Sony E 18-135mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS +3 more
hedleyw
hedleyw Contributing Member • Posts: 539
There is no advantage I can think of using a small aperture when stacking, you will be losing sharpness due to diffraction. Stay with the sweet spot for your lens, probably around f5.6.
Hedley
 hedleyw's gear list:hedleyw's gear list
Olympus Tough TG-4 Ricoh GR IIIx Olympus PEN-F Canon EOS R5 Canon EOS R3 +27 more
mawyatt2002
mawyatt2002 Contributing Member • Posts: 502
Your effective aperture (EA) is the magnification +1 times the lens aperture, so as said above diffraction can begin to degrade the IQ. Like most things it becomes tradeoff between DoF and Diffraction. I do lots of extreme stacking (sometimes ~600), mostly with microscope objectives for high magnifications, and the EA tends to hang around 18~20. These lenses don't have selectable apertures, so you get the EA the lenses was designed around.
Best,
~Mike~
stevendillonphoto Senior Member • Posts: 1,259
While I don't care as much about diffraction as others do, I think the best answer has already been given - use whatever the sweet spot for your lens is.
Steven Dillon - Capturing Nature's Art - http://www.stevendillonphoto.com
Bill Janes Senior Member • Posts: 2,042
Best,
As Mike notes, it is important to keep the EA in mind if you are doing close up and macro. At m = 1 you loose 2 f/stops so f/11 becomes f/22, well into the diffraction limited range. Nikon chipped lenses give the effective aperture and Canon and most others give the nominal f/stop.
In close up and macro, it is often desirable to have the background out of focus, and a large aperture (smaller f/number) will help blur the background as will a longer focal length lens. In macro, the depth of field at a given magnification is independent of focal length, but the background will be magnified more and have a less apparent depth of field with a longer lens.
IMHO, an intermediate aperture is optimal in most situations. Open up for smoother backgrounds at the cost of more shots, and close down for fewer shots in the stack.
Bill Janes
Peter Wu of San Diego New Member • Posts: 4
Best answer was given so I won't repeat, but only add my very first stacked photo, taken last night.
Camera: Nikon D750
Lens: 20+ year old Sigma 90mm f/2.8 Macro on bellows
Settings: f/8, in a home made light box with one SB-800 speedlight, M mode, 1/64 power, wirelessly triggered by the built-in commander of D750.
20 shots were taken. Focus was manually adjusted by moving the camera plane forward, starting from the nose in focus. I ended up using only every other shot from the images, after inspecting the results, feeling that using 20 images was redundant.
Below image was cropped to near 100% to show the detailed eyes. Only one speedlight was used on the left. A second speedlight is on its way from Amazon.
 Peter Wu of San Diego's gear list:Peter Wu of San Diego's gear list
Nikon AF-S Nikkor 24-120mm F4G ED VR Rokinon 14mm F2.8 IF ED MC Nikon AP-F 70-300mm F4.5-5.6E +5 more
(unknown member) Forum Pro • Posts: 19,317
you can get excellent results from one strobe you just need to use mirrors and double diffuse the subject from the light source to give a nice consistent result.
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
beginner_macro
beginner_macro New Member • Posts: 13
I prefer using F/8 for FSing because there won't be any diffraction. But that's only for still subjects; for more jumpy subjects I use F/11 so that if they jump/fly away I have photos with a larger DOF.
With sharper lenses like the Canon 100mm F2.8L, you can go all the way up to F/18 without obvious diffraction. So, for FSing, I'm trying to get the best DOF without introducing diffraction - for me that means F/8 to F/11.
-CalB
 beginner_macro's gear list:beginner_macro's gear list
Canon EOS 60D
Your analysis is incorrect. Diffraction takes place at all apertures and limits resolution. The diffraction limits are shown below for green light.
These figures are for optical resolution. System resolution includes sensor resolution and the system resolution in terms of MTF is the product of these resolutions. The system resolutions for the 100 f/2.8 L at various apertures on a 24 MP full frame camera have been determined by Optical Limits.com and are shown below.
Maximum resolution in center of the frame is at f/4. Prior to this aperture, resolution is limited by lens aberrations. Beyond f/4 resolution is limited by diffraction and resolution is considerably lower at f/16. Sharpening, preferably by a deconvolution method, can restore some resolution but the image will not have the brilliance obtained with the optimum aperture.
Bill Janes
beginner_macro
Very interesting, thank you for the correction.
-CalB
Canon EOS 60D
