How often do you replace your SD cards?
Started Mar 10, 2018 | Discussions
fotografffic Senior Member • Posts: 1,066
I've used one of my Canon cameras for years because of it's small size, portability, decent image quality and features including zoom.
I've used the same SD card in it for the past seven years. I have not had one problem with the card, never! Every now and then I format it and, after heavy use, I do a low-level format.
Am I pushing my luck? Is it time to get a new SD card? How often do you replace your SD cards? Do new ones have decent reliablity?
Thank you!
Guy Parsons
Guy Parsons Forum Pro • Posts: 31,197
Never.
8
Thank you!
The SD cards do theoretically have a finite life, they wear out with use.
To test that I put an SD card into a notebook and used it as the pre-fetch memory for Windows. It went for maybe 3 years flashing away all the time while using the notebook, it had equivalent of hundreds of years of camera use of write/read operations. still worked fine, is now in an old camera used occasionally. Still OK.
So forget about them wearing out.
Make sure that you buy from a proper source and have easy replacement if found to be faulty within the warranty period, or lifetime replacement for some brands. Do not buy from cheap eBay sources as they are most likely fakes and will not work well or will not be the stated capacity.
No need to do anything apart from an in-camera format when refreshing the card.
Do not use default Win/Mac formats, use only the proper SD Association format program from https://www.sdcard.org/downloads/formatter_4/
Regards..... Guy
Olympus PEN E-P5 Sony RX100 VI Olympus PEN E-PL5 Olympus PEN E-P3 Olympus PEN E-PL1 +2 more
OP fotografffic Senior Member • Posts: 1,066
Re: Never.
Thanks for your insights, Guy.
In my experience, I've come to realize many things are not made the way the used to be. Sometimes I wonder if a new SD card would be any more reliable than my old one.
Excellent suggestions. After reading your reply, I looked at a few SD cards. Didn't realize some have a lifetime warranty.
I never format a card, or delete or download photos, from anything but from the card itself. Thanks for jogging my memory about the SD Association's SD Memory Card Formatter! Great that it even comes with a manual.
trungtran Contributing Member • Posts: 808
Re: How often do you replace your SD cards?
I buy a new one for each camera i have. It is basically married to the camera until it dies.
Camera is pretty useless without it so i don't play musical chairs with them.
I buy a new camera at least every 2-3 years so the main camera and card is 3 years old.
Cards have a finite life but the backup bodies are not used for anything significant so no real big loss when it fails.
 trungtran's gear list:trungtran's gear list
Sony a7 II
richj20 Veteran Member • Posts: 6,904
I've had the same two cards for almost 8 years, always formatting the cards in the cameras, never intending to replace them.
A few months ago, I got a strange card read error from one card. I couldn't see any images. However, on the computer, I could see the images. I formatted the card (always in camera) and everything seemed to be OK.
A week later, the same thing happened with my second card in my other camera.
I decided to purchase new cards, and am happy that I did because they have faster write time which means quicker to review.
I do not know. Why wouldn't they?
- Richard
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-GX8 Panasonic Leica 100-400mm F4.0-6.3 ASPH Sony a7R II
Labe
MOD Labe Veteran Member • Posts: 9,149
not so much replace but add another as I need more capacity as camera files get bigger.
my first so was 512mb , then got 2g , then 4 g which I used for a long time as they matched up well the dvd / cd type storage that local shop used . Back then no pc so it was a set of prints and a disc copy .
now use 16/32g with laptop / hardrive back up and select a few for prints.
 Labe's gear list:Labe's gear list
Fujifilm FinePix IS-1 Fujifilm X-S1 Sony Alpha NEX-3 Sony a6000 Sony a5000 +4 more
Nigel S Contributing Member • Posts: 715
Thank you!
Not sure what you mean by low level format, but generally you should only ever do quick formats on flash memory, full formats wear them out for no reason.
A reasonably guide is that when recording FHD video, a typical SD card can record continuously for about 1 year before it starts to wear out, slow down and have problems.   If you are recording 24/7 then replace it after 1 year, but for a normal photo camera you never need to worry.
hotdog321
hotdog321 Forum Pro • Posts: 19,796
Rarely.
I do this stuff for a living and only replace cards when I feel the capacity or speed is limited due to the new high rez cameras--in other words, years.
Quality cards will last a very long time and I've never had a failure. In fact, I still have my original 256 MB (not GB!) CF cards from when I started shooting digital in 2001.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 16-35mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 11-24mm F4L +3 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 19,953
I'm retired, and an amateur . . .
They stay in rotation til they fail.  Professional photographers might not want this policy, but they can write the cost of new cards off their income tax in the USA.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +12 more
tcg550 Veteran Member • Posts: 8,010
I think you're pushing your luck with only one card.
I have a stack of memory cards and I have no idea when each one was purchased. I use whichever one is within reach when I need one. Sometimes I format, sometimes I don't.
I have also not low level formatted anything ever.
What's the purpose of a low level format?
Helpful information.
Because I find that, in general, some things aren't made the way they used to be. For example: appliances, my 10 month old laptop (signs keyboard is going). Don't know about SD cards since I haven't bought one in so long; just inquired.
A low-level format is to address these problems such as slowing down. The low-level format option, as far as I know, is only found on Canon camera, at least the many I've owned through the years.
I really don't record video.
Re: I'm retired, and an amateur . . .
I'm retired too. Because of mobility problems, I don't take many photos like I used to so this would work for me.
Low-level formatting
I have a couple of cards but because I have two different brand cameras, I don't switch cards between them.
According to Canon, "Do low-level formatting if the card's recording or reading speed seems slow."
https://support.usa.canon.com/kb/index?page=content&id=ART109344
According to articles I've read in the past, low-level formatting erases all recordable sectors in the SD card.
DanBichener Regular Member • Posts: 161
I’ve never replaced a memory card
 DanBichener's gear list:DanBichener's gear list
Nikon D7200 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF Sigma 150-600mm F5-6.3 | C Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +4 more
Re: Low-level formatting
How long does it take when you do a low level format?
Guy Parsons
The full format (only ever use https://www.sdcard.org/downloads/formatter_4/ ) writes all the sectors and wipes any previous away. Good idea if selling or gifting any SD cards as otherwise images can be retrieved, even after a quick format.
From the SD Association Formatter Manual...
In truth for everyday use only the quick format is needed as the card smarts should easily manage bad sectors etc. Files can be retrieved afterwards if there was a mistaken quick format.
I consider only using the long format if having card problems or I were to give the card to someone else to make sure it is wiped clean.
Regards.... Guy
Szumi Contributing Member • Posts: 801
Once when the card died.  I've replaced smaller ones for bigger ones as prices dropped.
I don't delete everything off my card when I upload to my computer.  I wait until the card may not be able to fit the next photo session.  That serves as one more backup of my photos and it forces the card to use empty areas which reduces wear.
Szumi
 Szumi's gear list:Szumi's gear list
Panasonic Lumix DMC-LX7 Canon EOS 700D Canon EOS 6D Canon EOS 7D Mark II Canon EF-S 18-135mm F3.5-5.6 IS STM +12 more
felix from the suburbs
felix from the suburbs Senior Member • Posts: 1,175
Nope.
These days, cards are so cheap that as mine fill up, I file them away as back up in case my hard drive fails.  I also back up my hard drive to a portable drive so I guess I have double protection.
 felix from the suburbs's gear list:felix from the suburbs's gear list
Sony Cyber-shot DSC-H2 Canon PowerShot SX710 Sony Alpha DSLR-A500 Sony Alpha DSLR-A550 Sony Alpha DSLR-A580 +19 more
I have a 16 GB card. Half full, it takes about 10-12 seconds as opposed to less than 5 seconds for a standard format.
