Windows File Explorer Doesn't Display Date Taken for .mpo Files
Started Mar 9, 2018 | Questions
GinAZ Forum Member • Posts: 54
I would like to know if there is an alternative to File Explorer that will display the Date Taken field for .mpo files the same as it is displayed for .jpg files.
My Fuji W3 takes both a .jpg and .mpo files. File Explorer displays the Date Taken for the .jpg file but the Date Taken for the .mpo file is blank. When using an EXIF viewer that processes .mpo files (EXIFTool by Phil Harvey), all of the date information is included in the EXIF data and dates/times are identical to the .jpg file.
If you are aware of a File Explorer alternative (or fix to File Explorer), I would be very happy to know about it.
Thanks, Gary
threed123
threed123 Senior Member • Posts: 1,490
Re: Windows File Explorer Doesn't Display Date Taken for .mpo Files
I'm not having the same problem. My taken dates show just fine for MPO files. In file explorer, bring up your MPO files folder. Then click the View Tab, then Details. You should see Name, Date, Type and Size at a minimum. If not, right click just right of the header-name row where the Name, Date, Type, etc. should be, and you should see additional columns you can select. Only the Date column gives you taken date I've discovered for MPOs. The other date columns don't seem to work correctly such as Date Created, Date Modified, Date Taken. That said, if you copy the files to one disc, then to another, sometimes you lose the Exif in the process. Another way to lose or change the exif, if you download to a photo album/storage program to browse the files first. That can lose the taken date as well. Check the settings of your downloader if you use one. I've found the best way is to simply download directly from the SD card to the computer file directory first using an SD reader, not using a downloader.
OP GinAZ Forum Member • Posts: 54
Thanks for your reply. It prompted me to look in more detail.
In File Explorer for a JPG/MPO pair on the original SD card, the times displayed were the same for both files: 3/3/2018 5:45 am. The dates displayed were:
Date, Date Modified, Date Created, Date Last Saved, and for the JPG file, Date Taken.
I believe each of the above dates, except Date Taken, are the file's date/time rather than EXIF dates/times.
However, I was two time zones away from home and the true time should have been 7:45 AM. I processed both files through the EXIF Date Changer program to add two hours to the time. Those files now display in File Explorer:
Date                          Date Modified        Date Created        Date Taken
JPG    3/3/2018 7:45 AM  3/9/2018 9:21 AM 3/9/2018 9:15 AM 3/3/2018 7:45 AM
MPO 3/9/2018 9:15 AM  3/9/2018 9:21 AM 3/9/2018 9:15 AM Blank
Both the JPG and MPO files EXIF data have 3/3/2018 7:45 AM in the fields:
Modify Date, Date/Time Original, and Create Date.
It appears the source for the Date displayed by File Explorer must be different for the two files. Looking at the file Properties in File Explorer, the MPO file is type img with only a few fields displayed. The properties for the JPG file do not have an entry labeled type. It does have an Item Type which is JPEG  8BIM header (Mac) and displays much of the EXIF data.
In the EXIF data, the MIME type for both files is image/jpeg.
Maybe the entire problem is that for a MPO file, File Explorer is not looking for EXIF data at all.
Would it be possible to modify the file properties for the MPO files so they are recognized as JPG files?
Wow! Changing the file extension from .mpo to .mpo.jpg and all the EXIF data displays.
threed123
Interesting find. I only see one date for an .mpo as well. I will keep this in mind if I every need to see all the dates.
