Reason why there is not a compact 1.4 prime in the 14-20mm range.
Started Mar 9, 2018 | Discussions
Vince P
Vince P Senior Member • Posts: 2,894
Micro 4/3rds is not my main kit but it is getting some use.
Part of that is having access to a compact outfit is important to me. One gap for my use is a fastish medium wide prime preferably with IS.
I have the panasonic 14 F2.5 and the 20 1.7 in this range but I would like an option for a faster prime for some purposes.
The Sigma 16mm 1.4 and Olympus 1.2 are just too big to keep an advantage. Closest are the leica 25mm and 12mm but just a little too long or too wide and the 12mm is on the upper end of the size I would be happpy with. Budget is unlikely to be the issue.
This is the 28-35/40mm zone which is well catered for in full frame.
Is anyone aware if there is a technical or other reason why there is not one?
Instagram @vinnypimages
 Vince P's gear list:Vince P's gear list
Sony RX100 VII Nikon D850 Panasonic GH5S Nikon Z7 II Nikon Z9 +81 more
Panasonic Lumix G 14mm F2.5 II ASPH
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Re: Reason why there is not a compact 1.4 prime in the 14-20mm range.
8
You've discounted those that are available as 'too big'.
Perhaps that's why there are few of them (and fast wide angle lenses tend to be pricey as well as large).
Dutch
forestmoonstudio.co.uk
Photography is about light, not light-proof boxes.
Lu1Wang
Lu1Wang Senior Member • Posts: 2,287
Mitakon 25mm f0.95 is pretty small for what it is, but pretty heavy due to being full metal construction. It's also a full manual lens
 Lu1Wang's gear list:Lu1Wang's gear list
Olympus E-M5 II Olympus E-M1 III Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital 17mm F1.8 Venus Laowa 7.5mm F2 MFT +9 more
Vince P
OP Vince P Senior Member • Posts: 2,894
The only 1.4 that I know of is the Sigma which suffers from their disease of being much larger than it needs to be. The Pan/leica 42.5 1.2 is more compact.
Pan/Leica have the equivalent of 24, 50 and 85. In a classic prime kit this would be an obvious gap with 35mm being the classic street focal length. I accept they will be pricey and larger than a 1.8 but the 1.4s, I mentioned, either side are reasonably compact.
Vince P
Thanks for the suggestion 50mm is a bit long for my use, the weight would be an issue and I would prefer AF if poss.
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
5
Pan/Leica have the equivalent of 24, 50 and 85. In a classic prime kit this would be an obvious gap with 35mm being the classic street focal length. I accept they will be pricey and larger than a 1.8 but the 1.4s, I mentioned, either side are reasonable compact.
Is the 15 1.7 or 17 1.8 that much slower than 1.4?
For a full body shot it amounts to 2.5 inch more dof in front and behind ie 5 inch more, for a closer shot, say head and shoulders it will amount to about 0,5inch in front and behind ie 1 inch more.!
mg_k Veteran Member • Posts: 3,221
May I ask what purpose is that?
Is it the light gathering, DOF, or both?
Say if there's a 20 1.4, that's barely like half a stop from f1.7 which in real life the difference is negligible.
So why fixated on a 1.4?
Diminishing return.
 mg_k's gear list:mg_k's gear list
Ricoh GR Canon EOS R Canon RF 24-105mm F4L IS USM
8
+1
Agreed.
OP sounds like you're trying to force m43 to match your other system and expect it to be cheaper, smaller and lighter all at the same time.
It simply doesn't work that way.
f1.7/1.8 is plenty fast and good enough to most whilst keeping the overall size small and light, and imo that's the true strength of m43.
Vince P
Its not really the DOF for my use it's the shutter speed. 2/3rds of a stop is often useful in low light. M43 is obviously more sensitive in those circumstances.
Vince P
+1
Agreed.
I never said cheaper, I expect to pay for a less mainstream, technically complex design.
I would like it to be smaller & lighter. The existing 1.4 Panasonic primes at other focal lengths (Even the 85 1.2) are accepatble in size so my question is still is there a reason for the gap.
I have 1.7 it's occasionally not enough for me. Since there are a number of 1.4 and 1.2 primes the answer no one needs better than 1.7 is a little strange.
Advent1sam
Is it video related, you have a gh5 on your list? Is the 12 1.4 too wide and the 25 1.4 too long? I have wondered why there wasn't a 15 1.4 before to be honest but then I think 1.4/1.7 that's half a stop, iso 800 or 1250, seriously don't see that as an issue.
Vince P
It might get an outing for video, I have adapted lenses which I usually use. The primary use would be low light handheld stills with a GX85. Events interiors performances and occasional street
rsmithgi Senior Member • Posts: 2,939
I think the simple answer is that Olympus and Panasonic have both decided that F1.4 is not a significant enough change from F1.7/1.8 and that to be a worthwhile step up, F1.2 was required. They are unlikely to produce a full suite of 17mm/25mm/45mm primes at F1.8, F1.4, and F1.2,
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus 40-150mm F2.8 Pro +5 more
nzmacro Forum Pro • Posts: 18,757
Market is probably the issue
I would have thought it was fairly obvious really. The market for it is probably too small. Everything that needs to be covered fairly well is already there. If you and a few others want that lens and the majority can already find what they want in that range, then the market must be too small.
It's a bit like me wanting a 500 F/4 and asking why they don't make one for m4/3, fairly obvious and if they did, it would be more expensive than lets say ..... a Canon 500 F/4. Smaller market, larger cost. Same with what you want and I would say, Panasonic and Olympus just can't see the market for it.
Eventually you might get what you want, but only if the market dictates they need one. It doesn't matter what you are willing to pay for it, if they can only sell a few dozen a year, there's no money in it.
All the best.
Danny.
Worry about the image that comes out of the box rather than the box itself
Birds and BIF's ..... https://www.flickr.com/photos/124733969@N06/sets/
The need for speed ..... https://www.flickr.com/photos/130646821@N03/albums
 nzmacro's gear list:nzmacro's gear list
Sony a7R IV Olympus E-M1 II Olympus E-M1 Sony Alpha NEX-7 Sony FE 200-600 F5.6-6.3 +5 more
Carol T Senior Member • Posts: 1,321
I would love this too!
So, I guess they might sell at least two copies, lol.
Seriously, I have wanted Olympus or Panasonic one to make a 17-18/1.4 forever. I gritted my teeth and bought the 17/1.8 long ago, but am not very fond of it. And, the 15/1.7 is wider than I want, and the 20/whatever does not work well on Olympus cameras, it seems.
So, I would like at least a better option at 17-18/1.8ish, but prefer something a little faster. To answer the '1.4 is unnecessary' comments above, to me a 1.4 should give most of the benefits of a 1.2 with fewer of the shortcomings, and gives some room to stop down. A few m4/3 lenses are as sharp wide open as stopped down a bit, but most are like most lenses in general, better when stopped down some. The wider aperture gives more room to do that.
As for why there isn't one, like others I would say it is return on investment. For Olympus, the same reason they haven't made another slowish 12: They are making too much money with the outrageous 12/2 as the only option (which I also have, and consider one of the worst lens purchases I ever made...no, actually, THE worst). Panasonic has the 15 and 20 lenses, which work well for Panasonic bodies, so they probably wouldn't gain anything by making a 17-18.
Oh, and while I am wishing, I wish Panasonic would update the 25/1.4, or Olympus would make one. But that isn't likely to happen, either.
Sergey Borachev Veteran Member • Posts: 5,338
This is the price you pay for a system that has advantages in the longer FLs, when lenses will be smaller and reach further, due to the 2x drop factor. In the UWA to Wide lenses however, the advantages vanishes or even become disadvantages. Especially in FL wider than 12mm, it seems it is impossible to make lenses that are compact and still fast and high quality. A quality lens about 21mm in FF is common and reasonably compact, but it seems Panasonic and Olympus both gave up. Voigtlander, which normally produces very high quality lenses and do so by ignoring size and weight concerns, and not bothering with auto focussing, attempted to make such a lens for M43, but their 10.5mm was a failure according to Lenstip tests. So, it may be more realistic to hope for a f/2 lens in this FL range, or for a f/2.8 one if it has to be compact and high quality.
It is easier to justify for a bigger size and higher price if it's a zoom, which is why I think O&P only make UWA zooms.
UWA pictures need to be blown up very big, 30 inches or over, for the viewer to see the picture in its original perspective and be able to feel the awesome width. M43 simply does not have enough resolution for really big quality enlargements. This is another dis-incentive for makers to bother with fast UWA lenses or tilt-shift lenses. They won't be able to sell many of the super expensive lenses as people can get higher quality end results easier and cheaper using FF if they need very fast and wide, and enlargement quality.
Re: I would love this too!
For the longest time, M43 didn't have a quality 35mm EFL AF lens, arguably the single most important lens for any system. Then came the 15mm, but it is a bit wide and so pricy for the not exactly special IQ or build, and then we have the 17mm f/1.2 that is so big and even pricier. Very nice but clumpsy for a standard prime. I would be happy to just have a 17mm f/1.8 if it is small and high quality, something that can be used comfortable and confidently for street, travel and carrying anywhere. Maybe Sigma will have pity on us?
amtberg Veteran Member • Posts: 6,217
Voigtlander 17.5mm/f0.95
Granted it's manual focus and heavy, but it's a sweet lens if you can live with those limitations.
IKR!
And yet we have like a dozen 25s...
Re: Voigtlander 17.5mm/f0.95
Manual focus and heavy, AND expensive, does not communicate at all with the camera (manual focus can be ok, but I want my EXIF data). Plus has some optical properties I don't like.
