OP
EEvan
Regular Member
Re: SDQH - Kalpanika X3F Extract purple image issues with DNG in LR & Other Software
Hi Roland,
I didn't expect to see a response from one of the creators directly! Your tool is pretty awesome and really makes sigma's cameras much more versatile, so thanks for the work you guys did on it.
Let me try to answer your questions
1. I am not sure what you are trying to do.
I am trying to convert the x3f files to DNGs to be used in LR or darktable (or other) for editing.
2. Do the DNG file that the camera produce work fine?
They appear to render correctly. I made new versions of everything with the same settings for reference. It's a Color checker so we should all know what the colors should more or less be. I realize my original images left some ambiguity.
SDQH - OOC DNG - In Light room - F16 1/125th in direct sunlight (Little underexposed it seems)
3. Do the OOC JPEG work fine?
They appear to work fine
OOC JPEG as viewed in LR - F16 1/125th
4. Is the first, very dark and grayish image, OK?
No, it should be really colorful. It was how Dark table rendered it. But this is how LR renders it with no profile and the embedded
x3f Extract DNG (Default settings) - In LR with Embedded Profile - f16 1/125th
Now with unconverted selected:
x3f Extract DNG (Default settings) - In LR with Unconverted profile selected - f16 1/125th
Extra reference: This is the same x3f opened in SPP:
X3f RAW file in SPP (Same file used with x3f extract) - f 16 1/125th
If you think I am not doing something wrong with the tool and want me to post this as a summary on the GitHub I will go ahead and do it. I was just making sure there wasn't something I missed in using the tool with the SDQH.
