Replacing My G12: G7X MkII, G1X Mk II or ?
Started Feb 19, 2018 | Discussions
ianxponent Junior Member • Posts: 27
My G12 has served me well for over seven years and is actually still going strong but with an upcoming trip to Europe in May, I'm wondering if it may be time for a newer camera with larger sensor, newer DIGIC version and features like wifi, etc.
Background: I don't have or want a DSLR or really feel the need of a changeable lens system. Been there, done that with film cameras many years ago. An advanced point and shoot is great for my needs. I have a decent smartphone (Galaxy S8+) but still prefer an actual dedicated camera for taking quality photos. Since my second digital P&S, an A620, I've also appreciated an articulating screen so that feature is a must-have for me. While I prefer the full articulation of my G12, tiltable is fine as long as it can tilt up for selfies and low down shots and also tilt down for shots over the crowd's heads. The zoom of the G12 is OK but I've always wished its wide angle was 24 mm equivalent instead of 28 mm. I'm also thinking a larger sensor with faster lens would help in low light levels which may come into play in our upcoming trip e.g. we have an evening sunset tour planned for Stonehenge
So with all that in mind, the two cameras I mentioned look attractive especially as both are priced very low as refurbs on the Canon store website: $510 for the G7X Mk II and $430 for the G1X Mk II. I've heard that Canon's refurbs are quite decent. I have handled the G7X Mk II but am wondering if it's a bit small for me. It does have a nice solid feel but the back controls seemed more crowded than those on my G12. I have yet to handle the G1X Mk II but it's clearly quite a bit bulkier and heavier than my G12.
I'm not wedded to Canon but am used to their menu structure and appreciate the physical controls I have with my G12. I've also had excellent service from my A620, G12 and a tiny Elph 130IS I also own. The latter has wifi which would also appear to be a must have these days especially with the upcoming trip and desire to backup files and share some using social media. I'm hoping to avoid taking a laptop so would transfer files to my Galaxy S8+ for upload to the internet/cloud.
Anyway, these are some of my thoughts and would appreciate any insight others might have that would help me in this decision.
Ian
Canon G1 X II Canon G7 X II Canon PowerShot G12
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
Re: Replacing My G12: G7X MkII, G1X Mk II or ?
Another Canon to consider is the G5X.  I own a copy and I love that camera.
It fulfills all the requirements you mentioned, plus it has an awesome built-in EVF and a hot-shoe.
G1XII is also really cool with its dual control rings around the lens,  but I chose the G5X over the G1XII because of the EVF.
Hope this helps,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
In pursuit of photographic excellence.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
yaxexa Forum Member • Posts: 50
1. I would choose the G7XII over the G1XII.
2. If you need an EVF and a fully articulated screen then there is the G5X. With the G5X just keep in mind the very slow burst speeds when shooting RAW files.
NWT Contributing Member • Posts: 744
If size is not overall impressive to you, G7XII’s advantages over G1XII are the newer processor and higher resolution.  G1XII’s advantages are larger sensor, longer zoom, better built, capacity to add an external EVF and flash, capability to add a filter, and cheaper.  Coming from S120, G1XII is heavy and bulky, but coming from 6D, it’s light and compact.
ETAV8R New Member • Posts: 5
Went from a G15 to a refurbed G5X. So far I'm very pleased with it.
(unknown member) Senior Member • Posts: 2,265
The large advantage of the G1X II is that you have a better chance of subject separation with the G1X II. So more capacity for photography as opposed to deep field snapshots. You will likely not get a wide 12.5mm f2 to mid telephoto lens going up to 62.5mm f3.9 as compact as this and at the price anywhere else ever again. In ILC you are probably edging in to pro designated or priced stuff nowadays.
Plus despite the age of the sensor high ISO colour stands up much better than the 1" sensor so you have a big sensor advantage that if you drift in to high ISO to keep shutter speed up it is not such a problem. Look at Imaging Resource and DPR cross comparisons.
Not such an easy camera to use but a bit more scope. I would think the G5X is a better replacement for the G12 unless the OP is sure an EVF is not necessary or RAW speeds are not an issue.
Agree with your points of the subject separation and colour.
OP ianxponent Junior Member • Posts: 27
Thanks for the reply and the suggestion to consider the G5X as well. It's now on my list!
GeraldW Veteran Member • Posts: 8,872
Ian,
I have the G7X II.  I bought it to replace both a G15 and an S90.  In the past I've had other G series starting with the G5 and working my way up the series.
As a replacement for the G12, I'd recommend the G7X Mk II.  If I'm out and about, I carry mine in a looser fitting pants pocket (no jeans) or even a shirt pocket.  I use mine with a neck cord (I make my own) and often carry the G7X II in a shirt pocket with the cord around my neck.  Helps to fish it out of the pocket.
The G12 covers 28-140 mm, as does the G15.  But the G7X II with it's 20 MP sensor has more than enough resolution, so I stored the 1.6x Digital Multiplier in the C position on the mode dial, so I can quickly change to 8 MP and 38-160 mm, still at f/1.8-2.8.  Image quality is indistinguishable from 20 MP on a borderless 8.5" x 11" print.
The G1X MK II is a nice camera; but you can't use the flash and EVF together.  Only one hot shoe, so it's one or the other.
The 1" sensor has noticeably shallower Depth of Field than the G12, especially since it has a faster lens.  That was one of the arguments for the G1X II; but on travel, I usually want more DoF, not less.
For what it's worth, the G7X Mk II measures higher resolution than my Canon 70D on my resolution chart.  And shows less noise at ISO 1600.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
CMCM Veteran Member • Posts: 5,995
If you are not shooting RAW files, is the burst speed better on the G5X?
 CMCM's gear list:CMCM's gear list
Fujifilm X30 Nikon D500 Canon G7 X II Nikon Coolpix P950 Nikon D700 +17 more
Thank you both for the comments. First, regarding bulk, my G12 weighs over 400 g; that's heavier than the G5X (and obviously the G7X Mk II) even though the G12 and G5X have similar physical dimensions. Clearly, the G1X Mk II adds significantly more weight as well as a significant increase in depth due to the size of the lens. My G12 is not very pocketable but I usually use a wrist strap when it's not in its belt-attached pouch. I would expect to do the same with either the G5X or the G1X Mk II. I think of it as being "palmable." The smaller G7X Mk II actually looks to be pocketable.
Subject separation is of interest to me. Lately, I've been taking more people shots particularly portraits than I used to so having a camera that excels at that would be a real advantage.
I have handled the G5X and have to say I like the articulating screen as it's very similar to the one on my G12. The tilting screens on the G7X Mk II and the G1X Mk II feel somewhat more limiting but I can't honestly anticipate from my experience there's a shot I couldn't make with a tilting screen that I could make with one which articulates like the G5X. The biggest advantage of the articulating over the tilting screen IMHO is the protection you can achieve with the screen face turned into the camera body when not in use. I have the dent in the back of my G12 to attest to that although I have no way of knowing what the damage to the screen would have been had it been facing out at the time of the fall. I notice that the G5X has switched the location of the mode and exposure comp dials vs my G12. No biggie. From what I can see the G1X Mk II has a less convenient exposure comp adjustment or at least different from what I'm used to. But the G1X Mk II like my G12 appears to have two custom mode settings on the mode dial compared to only one on the G5X and G7X Mk II.
Regarding viewfinders, I've rarely used the simple optical viewfinder on my G12 but the electronic viewfinder on the G5X is light years ahead! My problem is that my glasses don't seem to permit me to get my eye close enough to see the entire view (including settings) at once- I have to move slightly this way and that to see the various details. Is this normal or is it the high degree of correction my eyes require or that the glass lenses are progressive? Would the add-on viewfinder for the G1X Mk II be any different?
Again, thanks for any insight!
Ian
5.9fps continuous-shooting speed with focus fixed at the start of the burst, and 4.4fps with autofocus between frames.
yonny10 Forum Member • Posts: 91
I agree. It's the G1Xii's strongest point for me.
 yonny10's gear list:yonny10's gear list
Canon EOS RP Canon EF 70-200mm F4L IS USM Sigma 50mm F1.4 DG HSM | A Canon RF 24-105mm F4.0-7.1 IS STM
G1XII is definitely much heavier than G5X, but the size is only slightly larger if you don't use the external viewfinder.
I have not tried G5X's viewfinder, so don't have the viewing experience, but personally I like the flexibility of an external one, particularly the tilted viewing function of the first version, even though I don't use it often.
G1XII does not have a dedicated exposure compensation dial, but you can set the first front ring dial for that function and the second one to change the aperture in Av mode or shutter speed in Tv mode, I found them really easy to use.
it is a pity they dropped the exposure offset dial. I tend not to use the click dial on the lens as mine is rather clunky and has a different feel in different directions and can miss clicks. Many reviewers picked this up. I am spoilt by the Olympus Stylus 1S whose switchable click/smooth lens dial is impeccable in use.
The weakness of the G1X series is that rather than tweaking the model they have tended to scrap the lot both the good and the bad and start again from scratch so it lacks a degree of mature refinement. The mark designation seems to be stretching the meaning of the word as much as macro was in the Mk 1.
I have the tilt EVF and it is very flexible in use. If you want a very stable platform you can have the camera low with your upper arms against the body and look down.
Just an update. Thanks to folks who provided some good insight, I added the G5X to my list of G12 replacements. After handling it, I felt the G7X Mk II was just a wee bit on the small side for me and with its significantly higher refurb price just wasn't compelling enough for my needs compared to the G5X and the G1X Mk II. I went back and forth on those two. The G5X had lighter weight, the EVF, and fully articulating screen. OTOH, the G1X Mk II had a slightly longer zoom, an excellent lens and sensor combo with great potential for shooting shallow depth of field shots that I know I would use frequently. After handling the G5X and using its EVF, I was disappointed in how I had to fussily shift my eye to see all the info presented. This may be related to a condition I have in my eyes that results in a slightly distorted view of the world when my vision is corrected to 20:20. In any event, that made the EVF of limited use to me and so swung the scale to the G1X Mk II. So, that's what I've ordered and it should be here next week in time to acquaint myself with it before a long weekend trip to San Francisco in two weeks. My partner will now have the G12 to himself which he will certainly appreciate as an option to the camera in his Galaxy S8+!
ghce Regular Member • Posts: 415
Here is a slightly off the wall suggestion that worked for me, I also have the G12 and its a really great camera. I wanted another compact camera with the same versatility as the G12, the G1X didn't do it for me and I don't use it too much great as it is but just not too versatile.
What I in the end got was a GF6 which coupled with the PZ14-45 lens is a small and pocketable (but not your back pocket) M4/3 sensor with a really useful zoom range and huge versatility even if you never change the lens (and I never have). Unfortunately you loose the evf or optical viewfinder but lets face it the G12 viewfinder was only a nod at the concept and not useful in any circumstances. If you wanted to go more compact the GM5 would do it and it has an evf though it doesn't emulate the concept of a compact as perfectly as the GF6 14-45 PZ configuration does.
I have a bunch of different compacts from all brands but I really love the GF6 as my every day compact.
 ghce's gear list:ghce's gear list
Sony Cyber-shot DSC-T3 Panasonic Lumix DMC-ZS3 Canon PowerShot G12 Canon PowerShot G1 X Canon PowerShot G16 +30 more
Hope it works out OK. Always difficult to advise on what to get so good luck. I think all in all the G1X II is a useful bit of kit. The reviewers seemed to struggle classifying it and criticised its size without adjusting to what it did. A camera like the Olympus Stylus 1 the last of the 1/1.7 inchers that you get while you can because its like will not appear again.
It will be interesting to hear how you get on with it.
John McCormack
John McCormack Veteran Member • Posts: 7,101
Decision Yet? Re: Replacing My G12: G7X MkII, G1X Mk II or ?
Sorry if I missed it, but did you make a decision about replacing the G12. I'm looking at replacing my G15 (now sold) and have pretty much decided on the G5 X myself. I don't see any update coming before Photokina in September. Thanks.
geepondy Senior Member • Posts: 2,303
Re: Decision Yet? Re: Replacing My G12: G7X MkII, G1X Mk II or ?
I replaced my G15 with a G7X because the G5X wasn't available at the time but do miss the ability to use an external flash. The The G5X EVF (I use one at work) is of course much nicer then the poor G15 OVF but that is less of a concern for me personally. Had the G5X been available at the time I upgraded, that would have been the natural progression for me. The G5X (along with G7X I and G3X) is not a particularly quick camera but if you compare to the G15, it's not bad. It actually focuses quicker but has sluggish shot to shot times. The non-existent raw burst mode was also not a factor for me.
Having said that, after now owning the G7X II which is light years faster, it would be hard for me to go back to the G7X/G5X. Also, one thing the G15 does excel at over the newer GX offerings is the macro and close up focusing. For that reason alone, I did not sell it and for work use where I sometimes do close up photography of PCB boards, I actually prefer it over the available G5X.
 geepondy's gear list:geepondy's gear list
Canon PowerShot S100 Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot G7 X Canon G7 X II
