The cause - Re: 14-140mk2 misbehaviour
gardenersassistant wrote:
Adrian Harris wrote:
It is well known that the lightweight Panasonic 14-140mk2 can misbehave when using mechanical shutter, which is easily solved by avoidance.
Is this a reference to shutter shock, or other issues too? The reason I ask is that I have just arranged to get a replacement for a new 14-140 mk2 because of a strange issue with it on my G80 and I'm wondering whether this is a known about "feature" of the lens in general rather than a malfunction with this particular sample of the lens. (So I won't be surprised if it happens with the replacement.)
I first noticed it with a single shot but the easiest way to illustrate it is with successive shots captured using aperture bracketing, with one of the shots having a different geometry from the others. They were captured hand-held but I don't believe such lopsided geometric distortions can arise from camera and/or subject movement, especially when the next shot after the distorted one reverts to the previous geometry.
There are three frames in the first two animations, one before and one after the distorted frame. The first two are shown for 1 second, the third for 2 seconds. The third example is only two frames, a normal frame and then a distorted one. Since these were captured as bracketed images they were captured in quick succession at a rate of several per second.
There are another five in this album at Flickr.
Click on Original size beneath the image to see the animation.
Is this one of the misbehaviours that has been discussed previously?
Hi Nick, I finally got the chance to see the distortion animation on a PC and recognised it immediately - I think !
I have seen this effect many times and with all types of lenses when using electronic shutter (it's especially bad on Panasonic's slow readout electronic shutter).
With electronic shutter the scene is read from the image sensor line by line, so any slight sideways movement by the photographer means that each part of the image is recorded and readout at a different time and hence camera movement introduces aspect distortion of some sort. Even IBIS doesn't stop this and it is far worse with high magnification - such as when shooting macro or when using a long telephoto lens, which is why I believe that OIS is necessary to compliment IBIS on long lenses. Hence I should imagine the reason that even Olympus thought it necessary - despite their fantastic IBIS - to fit OIS on their 300mm Pro level telephoto.
Using mechanical shutter should significantly reduce this type of distortion as it scans the sensor much faster.
However if you were not using E-shutter when you shot these, then I have no idea what caused it in your particular case!
For reference: OIS = Optical Image stabilisation (fitted on lens), and IBIS + In Body Stabilisation.
