The truth about SS & sharp images
Started Feb 18, 2018 | Discussions
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Almost all cameras experience some form of SS under certain circumstances.
I was first made aware of it when I came across a Nikon shooter draped bodily over a long lens mounted on a tripod so sturdy that I could not have lifted it. Of course I asked him why he was shooting like that and he said he was trying to reduce mirror slap when activating the shutter.
I bought a Sony A77 with a fixed translucent mirror and always used the electronic first curtain, yet I have from it some of the worst examples of SS that I have ever seen!
My Panasonic gx7 would produce SS easily with mk1 14-140 (ruined masses of shots). And the flash sync was a lowly 1/160.
Next was my dream camera the GX8. With a seriously fast shutter and a flash sync of 1/250 fabulous and just what I needed.
Like all cameras and tools nothing is ever perfect and it does have some caveats. However I quickly learned how to get the best out of it, which included finding out which lenses performed best with it to ensure I didn't lose any images through SS. .... And guess what, surprisingly when I am forced to use the mechanical shutter due to flickering LED lighting, I can guarantee that 100% of the time when using my Olympus lenses I never get any SS with it at all !
It is well known that the lightweight Panasonic 14-140mk2 can misbehave when using mechanical shutter, which is easily solved by avoidance.
So Whose lenses should we use for performance and sharp shots...
Interestingly I have repeatedly found that for really sharp action images the Olympus 40-150 f2.8 pro lens performs so much better on the GX8 than it does on the Olympus em1-mk2 !
Conversely - and this is getting weird - the Panasonic 100-400 performs better and produces sharper images on the  Olympus em1-mk2 than it does on the Panasonic GX8 or Gx7 !
How do I know all this, unfortunately I found out the expensive way by spending the kids inheritance and my pension
A final note: sadly although many suggest Panasonic 'upgraded' the 'faulty' GX8 shutter, for my photography it was a huge downgrade. We lost the fast shutter speed and also the fast flash sync speed, yet strangely so many seem thrilled about that ?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
Re: The truth about SS & sharp images
it seems fairly obvious that some cameras and camera/lens combinations suffer more than others
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
Keit ll Veteran Member • Posts: 5,172
5
It seems that some still think it legitimate to campaign for the GX8 When apparently Pansonic have recognised its faults. It may be Ok to sooth the feelings of those who bought one but we really shouldn't go on trying to persuade prospective buyers that SS is not a real issue.
Panasonic recognised the problem & corrected it in later models.
The fact that some other cameras also have similar issues is a bit of a red herring...
RobbieBear Senior Member • Posts: 2,356
And miss out on the one lens solution preferred by many users.
 RobbieBear's gear list:RobbieBear's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus E-M1 II Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
SteveY80 Senior Member • Posts: 2,087
That's weird. I've never seen anything resembling SS when using my A57 or A77ii, and I don't think I've seen any SS related complaints on Sony forums or in reviews of the cameras.
I had serious issues with shutter shock when using Panasonic's 100-300mm on my GX7. Switching to electronic shutter, or putting it on my GM1 for the same shot, made a big difference to sharpness at the same shutter speed.
That's actually the first time I'd encountered the issue, despite having used DSLRs previously - probably because of the lighter construction of both the GX7 and the 100-300.
I'm not sure what you mean about its flash sync though. The GX7's 1/8000s mechanical shutter is capable of 1/320s when using the pop-up flash (including when using it to trigger an external flash), or 1/250s with an external flash on the hotshoe. It actually slightly betters the GX8 and still has a definite advantage over the new GX9.
I think we're definitely in the minority here, but I'd have preferred the GX9 to keep the old shutter too, shutter shock issues and all.
Most of the lenses I use don't suffer from it and electronic shutter is usually an acceptable solution when SS does become an issue. Losing out on 1/8000s and faster flash sync isn't the end of the world, but for me it's more of a limitation than shutter shock.
That said, I don't blame people for being annoyed when they bought a new GX7/8 and a useful looking zoom from the same company, only to get blurred images from the combination. Not everyone reads camera forums to find out about issues that they need to work around. I don't think the dismissive attitude and accusations of user error I saw in response to SS complaints on this forum were very helpful either.
 SteveY80's gear list:SteveY80's gear list
Nikon 1 J1 Fujifilm X-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II +1 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
There are so blind as those that choose not to see.
This post is not about the GX8 although it is included. It is about good workmen learning to use their tools properly to get the best images possible.
If buying a camera with certain specifications suits your needs then go for it, but there is no free lunch.
Regarding the GX8, Panasonic has certainly tried to appease those who griped that they were unable to use the gx8 to good effect, by introducing the auto shutter workaround and that suited many.
But moving on, for my own use what was lost in launching their newer slower shutter design I feel was a step that took away more than it gave.
Personally I would have loved Panasonic to have  addressed far more serious camera issues, such as their slow e-shutter readout which causes skew, and also the fact that you can't shoot for longer than 1 second with e-shutter.
These are I believe, issues that affect all their cameras.
Fortunately I also shoot with an Olympus which has a very fast e-shutter. But that camera also has some faults, however I just work around them.
Thebigbird
Thebigbird Regular Member • Posts: 126
What's SS?
 Thebigbird's gear list:Thebigbird's gear list
Canon EOS 450D Nikon D700 Nikon D7200 Nikon D500 Canon EF 50mm F1.8 II +9 more
What's SS?
Shutter Shock
Adrian Harris
Although it wasn't a regular issue, unfortunately I had a few important shoots really messed up due to SS using my A77. Fortunately out of the many shots I took I did manage in both cases to salvage one from each location that were just OK for use. (I nearly cried at the time).
They were both very low light dusk/night shoots and accordingly very slow shutter speed.
I think I probably still have a couple, as I often keep a problem shot for reference. The issue certainly wasn't slight, it was more like double vision!
I didn't have the 100-300, but using the Olympus 75-300 mk2 on the gx7 was pretty much faultless.
I don't have a lot of faith in Panasonics early OIS implementation, ... Which of course wasn't needed with the Gx series cameras.
My mistake, you are correct, the fast sync on the gx7 was in fact one of the deciding factors for me purchasing it. My older G1 only had 1/160.
gardenersassistant Veteran Member • Posts: 9,656
14-140mk2 misbehaviour
Is this a reference to shutter shock, or other issues too? The reason I ask is that I have just arranged to get a replacement for a new 14-140 mk2 because of a strange issue with it on my G80 and I'm wondering whether this is a known about "feature" of the lens in general rather than a malfunction with this particular sample of the lens. (So I won't be surprised if it happens with the replacement.)
I first noticed it with a single shot but the easiest way to illustrate it is with successive shots captured using aperture bracketing, with one of the shots having a different geometry from the others. They were captured hand-held but I don't believe such lopsided geometric distortions can arise from camera and/or subject movement, especially when the next shot after the distorted one reverts to the previous geometry.
There are three frames in the first two animations, one before and one after the distorted frame. The first two are shown for 1 second, the third for 2 seconds. The third example is only two frames, a normal frame and then a distorted one. Since these were captured as bracketed images they were captured in quick succession at a rate of several per second.
There are another five in this album at Flickr.
Click on Original size beneath the image to see the animation.
Is this one of the misbehaviours that has been discussed previously?
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Shock or shake?
Are you sure that you are seeing camera induced shock and not user induced shake at those speeds?
Regards..... Guy
Guy Parsons
Image distortion.
I saw exactly the same kind of distortion with a Casio pocket camera doing a burst at 5fps of a slowly moving train. Camera in fixed position. no user slewing or panning involved. Occasional frames slightly misshapen like your rose example.
Also have seen it in videos displayed in TV shows, usually I suspect sourced from things like GoPro cameras.
It must be a feature of CMOS sensors as I've never seen any of that weirdness from my earlier cameras' CCD sensors.
Regards..... Guy
ahaslett
ahaslett Forum Pro • Posts: 12,662
Re: Image distortion.
Regards..... Guy
CCD readout times are faster than CMOS, so you get less distortion with movement and electronic shutter.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Guy Parsons
Regards..... Guy
Andrew
Yes, I know that and have proven that with comparing videos of high speeds trains passing with both CCD and CMOS sensors. No distortion with CCD (with my Panasonic LX3) and heaps of distortion with CMOS (as in E-P5).
The cases I've experienced and have seen in videos are that the camera is in a fixed position and yet still some skewed frames.
All I can put it down to is spurious OIS/IBIS/Digital corrections happening during a frame for no obvious reason.
Regards..... Guy
Regards..... Guy
Andrew
That is the situation for my examples.
Which suggests to me that if I see the same thing in the replacement lens I should just accept it. All the same, it's a bit concerning that it happened so often. I found 8 clear examples and some maybe's in around 60, 6-image brackets. That's more than 1 in 10 of the brackets having a distorted frame.
Regards..... Guy
Guy Parsons
Have you tried with stabilisation both on then off?
Seems like another experiment for me as well, maybe get around to it one day.
Regards........ Guy
I wondered about that, but unfortunately stabilisation is essential for the way I work with botanical subjects which leaves me around the boundary of the shutter speed/ISO envelope as far as losing shots from camera movement blur goes.
Regards........ Guy
Adrian Harris
Re: 14-140mk2 misbehaviour
Hi Nick, I am only viewing your flowers via a phone and can't see any issues with your images.
I personally think that the Panasonic 14-140 is a wonderful lens and use it extensively on my gx8, gx7 and em1-mk2 without any problems whatsoever. However it is not a lens that would be on my camera when in situations that may require the use of mechanical shutter, as these for me are normally either very long telephoto or very fast aperture situations. So I would be using different lenses.
One irritating issue that I and friends do get with Panasonic lenses is their stabilisation, which unlike IBIS, always seems to take a brief moment to settle after jerky movement by the photographer. Some are far worse than others, and for me the worst was the early Panasonic 45-200, which could produce all sorts of weird optical effects if you didn't wait before pressing the shutter.
Adrian Harris
Re: Shock or shake?
Regards..... Guy
Hi Guy, they were remote triggered and on a tripod, oh and stabilisation was switched off.
I realise that user induced shake is far more common than many may realise - and I learned the hard way.
When on a beach at night I try and prevent people walking within 20feet of my tripod.
And once when in a field at night with a 400mm lens I had a 150 shot panorama ruined by a car driving past on a nearby road, possibly around 60 feet away ... Now that I didn't expect!
So it is possible that something else was going on that I was unaware of as I was in a rail yard, and although I took great care to place the tripod on a concrete slab it doesn't necessarily mean that it was 100% safe.
Interesting. Presumably you are seeing the animations, not single images?
Assuming you are seeing the animations, can I probe a little please. Are you not seeing any geometric differences from one frame to another? Or are you seeing differences but don't see them as being problematic?
So you don't think using a mechanical shutter is a good idea with this lens? Even though the new shutter in the G80 appears to have solved the shutter shock issues with the power zoom lenses (like the 45-175 that I have) that are a bit notorious for being susceptible to shutter shock, and seem to solve it even without using EFC, and the more so when using EFC, which I do?
I have an early Panasonic 45-200 but it isn't a lens I have used since getting the 45-175 some time ago. I've not noticed that problem, and these (to my eye at least) problematic image capture were not preceded by jerky movements, being embedded in aperture bracket capture sets. I also saw the problem with single captures which were not part of aperture bracket capture sets. In that case the camera was rather stable as my hands were resting on a windowsill as I took multiple single shots.
Incidentally, the G80 has IBIS, so I was using dual IS for these shots.
