Lets make: Fuji Eterna simulation
Started Feb 16, 2018 | Discussions
ateriksen
ateriksen Forum Member • Posts: 63
Hello guys!
My first post here, be nice
I want to get the Fuji Eterna simulation for CaptureOne and LR, but I don't think anyone made a preset yet. Someone want to make it or colaborte with me? I want to do this because I have X-Pro2 and no Eterna simulation :-/
All we/I need is some JPG (simulated Eterna, nulled)+RAW file of different things and some shots of Macbeth colorchecker cards. I can easily make .ICC profile for CaptureOne then.
I saw some portraits from Jonas Rask on FujiLove (FB) and I love how the colors and tone play along. I want to make this for X-Pro2 and X-T2 first, then maybe more cameras down the road.
Anyone?
Best regards,
Aleksander
 ateriksen's gear list:ateriksen's gear list
Fujifilm X-E1 Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-Pro2 Sony a7 III +12 more
Adobe Photoshop Lightroom 5 Fujifilm X-Pro2 Fujifilm X-T2 Phase One Capture One Pro
lavodnas
lavodnas New Member • Posts: 24
Re: Lets make: Fuji Eterna simulation
According to report on fujirumors, Lightroom already has Eterna simulation as well as raw support for X-H1. Im not able to confirm right now.
www.motoiq.com
 lavodnas's gear list:lavodnas's gear list
Sony a6500 Fujifilm X-T20
Rich Jacobson Contributing Member • Posts: 533
That brings to mind a question I have had for some time.   Why does Lightroom offer Fuji film sims only for those cameras that have the same simulations?  Why not have Acros available for the X-T10 for example?    And in this case, Eterna for all Fuji cameras?
Sjak
Sjak Veteran Member • Posts: 7,622
Probably due a licensing agreement between Adobe and Fuji.
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR III Ricoh GR IIIx Pentax K100D Pentax K10D +3 more
ateriksen
OP ateriksen Forum Member • Posts: 63
Thats not exactly same as giving same simulations to X-T2 and X-Pro2, etc But ok, I'll investigate. Thanks!
Aleksander
ateriksen
I think that is standard by Adobe because they make calibrated profiles to a certain sensor, and result would not be the same on a X-T1 or on a Nikon. You need a basic correction first and then a "look preset" to get the same looks as Eterna in X-E3/X-H1 as with other standard presets you can DL.
ateriksen
I made a Eterna preset for CaptureOne. It is not 100% identical to Lightroom, but it is damn close in my opinion. I used a colorchecker and LAB values to tweak the result.
No need to make preset for Lightroom because it already have built in Eterna profile for X-H1. You only need to change EXIF from X-T2 or X-Pro2 to X-H1 in EXIF tool.
So I hacked my own Fuji X-Pro2 RAW file with a EXIF editor and made it a X-H1 RAF file, link below to EXIF tool. Then I made a JPG from LR's built-in Eterna simulation for X-H1 and imported that JPG + original X-Pro2 RAF file to CaptureOne. Inside CaptureOne I made a look-a-like ICC and preset for Fuji X-Pro2 Eterna simulation. I did not manage to get luminosity and levels inside of ICC so I made a full preset with some tweaks. I exclude the whitebalance setting for obvious reasons, you probably shoot under other conditions than my Macbeth colorchecker
Feel free to make a better preset if you like. All files in folder can be used at own will, as long it will stay free for community.
Included in my GDrive:
https://drive.google.com/open?id=1SjDOAvuWg5PQ4n3gYYZu_gNkpkw7O9f4
* CaptureOne Preset
Import this to CaptureOne, or copy:
Win (C:\Users\****\AppData\Local\CaptureOne\Styles50)
* DSCF2931-X-H1.dng
Original RAF X-Pro2 >> X-H1 + added Eterna simulation and convert to DNG
* DSCF2931-X-H1.RAF
* DSCF2931.RAF
Original RAF X-Pro2
JPG out of LR with Eterna simulation.
Difference between LR Eternia JPG and my CaptureOne Eterna Preset
EXIF tool. Remember to download EXIFTOOL GUI to make your life easier.
http://owl.phy.queensu.ca/~phil/exiftool/
Good luck!
Best regards,
Aleksander
ateriksen
** UPDATE **
Added 20180219005101.eip .. That is CaptureOne packaged file with all adjustments you can tweak yourself. Check "Advanced color tool" and tweak transitions if you feel some of them are bad. Remember to not add "whitebalance" when you make a new preset from file, you will most likely shoot under different conditions than my colorchecker.
Aleksander
