Usefulness of pistol grip for underwater housing
Started Feb 14, 2018 | Questions
fotonboxx New Member • Posts: 1
Good day!
Trying to decide which housing will be more comfortable while snorkeling - with or without pistol grip (https://seafrogs.com.hk/collections/sony/products/seafrogs-60m-195ft-waterproof-housing-for-sony-a6xxx-series-salted-line-with-pistol-grip).
Manufacturer position this model with pistol grip specially for surfers, but what I need is good and steady hold while snorkeling.
What is your opinion on such grips?
Thanks in advance.
Barmaglot_07 Contributing Member • Posts: 633
Re: Usefulness of pistol grip for underwater housing
I think the pistol grip is more useful when you need to hold the camera out of the water. Submerged, a side handle or a full tray would be more comfortable. Note that Meikon has mentioned that they're working on a tray handle-mounted trigger for this housing.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
kelpdiver Veteran Member • Posts: 5,564
outside from shooting inverted, this grip is mostly detrimental.  The primary mantra for UW  photography is 'shoot up' and this grip forces the opposite.   Also feels like it would be awkward to use as a snorkeler - either one arm is all the way into center, or the camera will be at edge of your body line - both are unbalanced.
Aquadrone
Aquadrone Forum Member • Posts: 85
fotonboxx wrote:
Good day!
Thanks in advance.
Common sense:
Pistol grip is used only in surfing photography and only there.
For diving there are handles and underwater trays.
Under no circumstances you should take pistol grip underwater!
Pistol grip is tested, but at depth of 20M.
Conclusion:
Not recommended for diving.
 Aquadrone's gear list:Aquadrone's gear list
Sony RX100 III Sony RX100 IV Olympus TG-5 Sony RX100 VI Sony RX100 VA +15 more
Why would a gip have a depth rating?
It's not just a plastic handle - there is a two-stage electronic trigger and a cable that penetrates the housing and plugs into the camera's USB port, see here:
https://www.instagram.com/p/BffEpkynx0u/
ah, thanks.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
That seems risky, and/or weird.  Does the handle mount to a hole in the bottom of the housing, or is there some way of running that wire through a grommet?   Does sound risky for depth.
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
I don't have the housing (yet - planning to order it when I get home next week, without the pistol grip option), but looking at photos, there is an opening in the bottom of the housing, which is normally covered by a screw-in plug:
https://cdn.shopify.com/s/files/1/0897/7576/products/04.jpg?v=1517548377
The four threaded holes around it are used to mount the pistol grip. The grip is meant to be used for surf photography on the surface, and it's likely not very resistant to pressure, hence the warning by Aquadrone not to take it below 20 meters.
Miguel_A81 Junior Member • Posts: 44
Aquadrone wrote:
fotonboxx wrote:
Good day!
Thanks in advance.
Common sense:
Conclusion:
Hello! I'm late to this party and I'm also a complete newbie to underwater photography.
What about an Aquatech housing for example, that only has a handle on one side and no option to add another on the other side. Is one handle still better than a pistol grip underwater?
 Miguel_A81's gear list:Miguel_A81's gear list
Sony a6500 Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Sony FE 70-200 F4 Sigma 30mm F1.4 (E/EF-M mounts) Rokinon 12mm F2.0 NCS CS
Aquatech housings are made for surf photography, not diving - they're rated to a depth of only 10 meters. The pistol grip is useful for holding the camera up above the water, and the side handle is for extra stability while waves are tossing you around - neither of these things apply to dive photography. Conversely, when you're diving, you often need to get your rig down to the bottom to shoot small critters, or just to obtain an upward-looking perspective, and that's where a pistol grip sticking out of the bottom of your housing will get in the way. You are also likely to carry big lights or strobes, which you rarely need above water, and you need to distance them from the lens to reduce backscatter - tray handles provide attachment points for strobe arms and they help you stabilize the large and bulky rig.
Wow! I thought I had read all about the housings but how wrong I was. I didn't notice that aquatech housing are only rated for a depth of only 10m. Thanks for the heads up!
I think i'll go with ikelite instead.
