G9 and Panasonic 100-300 II at the zoo
Started Feb 9, 2018 | Discussions
RobertBetchel
RobertBetchel Regular Member • Posts: 212
7
Just some images taken on a cloudy day at the San Antonio Zoo as I evaluate the 100-300mm lens. All images processed to taste in Lightroom. I am trying to decide if I am happy with the quality of the 100-300, or if I should bite the bullet and go for the 100-400.  Since my long telephoto needs are strictly for personal shots, I am leaning towards just keeping the 100-300.
 RobertBetchel's gear list:RobertBetchel's gear list
Fujifilm X-H2S Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 23mm F1.4 R LM WR Tamron 17–70mm F2.8 Di III-A VC RXD Fujifilm XF 30mm F2.8 R LM WR +1 more
Panasonic 100-300mm F4-5.6 II Panasonic Lumix DC-G9
thebigA Regular Member • Posts: 132
Re: G9 and Panasonic 100-300 II at the zoo
Not a lot wrong with these.
Luke Forrest Senior Member • Posts: 1,072
They look pretty good to me. However, I'd check the white balance as some of them appear to have a purple cast to them.
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
They look pretty good. The 100-400mm is quite a step up in weight but it's the only option if you must have more reach.  I did upgrade to the 100-400mm and do not regret it.  However, after an hour or so a monopod for support becomes very desirable.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
David Yule Regular Member • Posts: 318
As someone considering buying that lens, what are your doubts about it?
I borrowed one for a brief test on my E-M1 II and thought centre image quality was good, even wide open. However one corner was soft. I also had bad CA in the soft corner, although my testing was limited and that could have been a co-incidence.
David
jalywol
jalywol Forum Pro • Posts: 12,301
Overall pretty nice shots, but you have a pronounced magenta cast to almost all of them. Were you using AWB? I'd try a custom WB next time if you were.
These are very comparable to what I used to get out of my 100-300mm (first version).  (You can do quite a bit of careful sharpening in PP and they will look really great, by the way.)
I have the 100-400mm now, and love it, but the 100-300mm is no slouch if you are willing to do a little bit of work on the files in PP.  For more casual use, I'd say to stick with the 100-300mm, as it is smaller and can give you very good results if you use care in shooting technique and in processing the images.  The 100-400mm is wonderful, but it is bigger, and it requires good technique to get the most out of, especially at the long end.  The 100-300mm is easier to carry, and a lot cheaper, and may just fill the bill, especially if you don't need to shoot past 300mm or use it for close up shots (minimum focus distance in the 100-400mm is closer than the 100-300mm so I can also use it as an ersatz macro if I want to, where the 100-300mm just couldn't quite get close enough for that).
Enjoy it.  If you find you need more, the 100-400mm is always out there, but you may find the 100-300mm more than meets your needs.
-J
Stejo
Stejo Senior Member • Posts: 1,461
The 100-300 II is excellent really and good enough for most uses. Consider going for the 100-400 only if you know you'll be needing the 300-400 range often.
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Samyang 85mm F1.4 Aspherical IF Samyang 7.5mm F3.5 Fisheye Sigma 18-35mm F1.8 DC HSM Art +7 more
briantii Senior Member • Posts: 1,657
How do you like the combo coming from the D750?
 briantii's gear list:briantii's gear list
Nikon 1 J1 Nikon D3200 Nikon D750
maltmoose Veteran Member • Posts: 3,051
-J
I was thinking the same, nice shots but the colors are just not as pleasing as i would have expected. Maybe some artificial lighting or iffy awb or maybe processing?
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Can you share a few examples of the 100-300 II between 200-300mm? Access to full-res pics would be nice because 3.1 Mp doesn't quite cut it to judge lens sharpness.
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
Stejo
Don't have anything handy to showcase sharpness I'm afraid. I've deleted my test shots long ago and most images I have now are too high ISO to be of any use. Rest assured, the test shots were highly successful. Stopped down to f/7.1 it's sharp enough to shave with up until the last 10% of the focal range.
Plenty of images around in previous threads though if you wanna see some samples. Just do a search.
