(Almost) complete list of native EF-M lenses
Feb 8, 2018
33
Hi, just because I've done it for myself, I share with you the list of all NATIVE EF-M lenses I found:
7 Canon lenses :
All Canon lenses are budget-friendly, and well build for this range. Outside the 22mm, all are stabilized. They are meant to be light and compact (all are under 300g.). As a direct consequence they are on the slow side.
- 11-22mm f/4-5.6 IS STM compact fo 18-35mm équiv. (a bit shorter compared to the 18-55), stabilized, great optical quality. 220g.
- 15-45MM F/3.5-6.3 IS STM smaller than the 18-55, but full plastic build. 130g.
- 18-55mm f/3.5-5.6 IS STM original kit lens for the M, full metal finish. 210g
- 55-200mm f/4.5-6.3 IS STM Optically, a good step above the 18-55 kit. Sharper and more homogenous 260g
- 18-150mm f/4.5-6.3 IS STM kit superzoom, versatile and compact for this focal length. 300g
- 22mm pancake f/2.0 STM tack sharp and very light. Weak points: visible vignette wide open (easily corrected, especially with the 24mp sensor) and no IS. 105g.
- 28mm f/3.5 Macro IS STM. First EF-M macro lens. 1:1 ratio and x1.2 with "super macro" mode. two led imbedded for additional lighting when you nearly touch your subject. Compact, 130g.
1 Tamron lens:
- Tamron 18-200mm f/3.5-6.3 Di III VC tested by Dustin Abott : the biggest size to keep a balanced camera (with M1), optically good for the category, useful all-in-one.
10 Samyang/Rokinon lenses:
full manual: focus ring, aperture ring, no electronic contacts = no exifs. Usually, good optical quality/cost ratio.
Designed for APSC mirrorless:
- 8mm f/2.8 UMC II fish-eye very compact 260g.
- 12mm f/2 NCS CS UGA fast and compact, test reports very good optical quality for the cost. Personal test: same sharpness as Canon 11-22mm. 260g.
- 21mm f/1.4 ED AS UMC CS, compact 275g.
- 35mm f/1.2 ED AS UMC CS, 420g.
- 50mm f/1.2 AS UMC CS, 375g.
- 300mm f/6.3 ED UMC CS mirror design, very compact for a 300mm, 318g.
EF-M mount but designed for APSC reflex:
- 10mm f/2.8 ED AS NCS CS, 580g
- 16mm f/2 ED AS UMC CS, 583g
EF-M mount but designed for FF reflex:
- 20mm f/1.8 ED AS UMC, 497gn
- 135mm f/2 ED UMC 210mm f/2 pour less than 600$...but no AF. 830g.
1 Handevision Ibelux lens:
Manual lens designed for APSC mirrorless.
- 40mm F/0.85 big, heavy, expensive, but a unique look on the pictures.
1 LAOWA lens:
- 9mm f/2.8 Zero-D AFAIK, the widest EF-M orthogonal lens. To be released during 2018 march.
6 7artisans lenses:
Manual "retro" lenses designed for APSC mirrorless. Compact and fast primes.
- 7.5mm f/2.8, fisheye 275g
- 12mm f/2.8, 295g
- 25mm f/1.8, 143g
- 35mm f/1.2, 150g
- 35mm f/2, 320g
- 55mm f/1.4 272g
1 Sainsonic/Kamlan Lens:
- 50mm f/1.1 250g.
6 MEIKE lenses:
Found on Amazon for less than 100$
- 25mm F/0.95 more expensive (650$), heavier 540g.
- 28mm f/2.8 pancake, 106g.
- 35mm f/1.7, 180g.
- 50mm f/2.0 190g
2 lenses, just announced. No details at this stage :
- 25mm f/2.0
- 50mm f/1.7
That's it... 33 lenses. Only 8 of them with autofocus.
Do not forget the EF/EF-S lenses that can be useful and compact enough to work well with the M bodies, with full AF capabilities:
- EF-S 24mm f/2.8 STM Pancake, 230g w/ canon adapter
- EF-S 35mm f/2.8 Macro IS STM, 295g w/ canon adapter
- EF 40mm f/2.8 STM pancake, 235g w/ canon adapter
- EF 50mm f/1.8 STM, 265g w/ canon adapter
- EF 50mm f/2.5 macro, 385g w/ canon adapter
- EF-S 60mm f/2.8 Macro USM, 440g w/ canon adapter
- EF 85mm f/1.8 USM 530g w/ canon adapter
- EF 100mm f/2.0 USM 565g w/ canon adapter
PS : I didn't list the equivalent ciné lenses (rokinon and meike)
