Canon Eos M10 with 22mm F2
Started Feb 7, 2018 | Discussions
robyfor Regular Member • Posts: 368
I am interested in buying a mirrorless. I look for pocket portability. I am undecided between the Ricoh GR II (really small) or alternatively the Canon Eos M10 with 22mm F2. In the case of Canon I can not find the overall dimensions with this lens. Anyone who has this product can tell me the actual size of space? Thank you
Sony P200 - Fuji F30 - Samsung NX1000 with 20-50mm and 30mm f2 - NX3000 with 16-50mm - Samsung 16mm F/2.4 - Samsung NX300 - NX 18-55mm - NX50-200mm - Sony HX90
https://www.flickr.com/photos/137263652@N05/
Stop time with photography!
Roberto
Canon EOS M10 Ricoh GR II
brightcolours Forum Pro • Posts: 15,885
Re: Canon Eos M10 with 22mm F2
The EOS M10 is about the same size as the Ricoh. So, the lens on the M10 is extra space needed.
If that is your only criteria, get the Ricoh.
The Ricoh has a 28mm full frame equivalent lens. The Canon 22mm is a 35mm full frame equivalent lens. This may also be something to consider.
Canon EOS M10 + EF-M 22mm f2 vs Ricoh GR:
http://j.mp/2BJ83wq
Thank you
Roberto
crashpc Veteran Member • Posts: 7,235
I can measure that combo when I get home today.
Ricoh is definitely pocketable, while M10 with 22mm isn't really.  But it comes for price of very restricted focal lenght choices....
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Nicholas Laidler
Nicholas Laidler Regular Member • Posts: 132
You can get an idea with this comparison. That's for the older GR, the GR II is bigger in all dimensions from what I can see. To my eye it looks like they're very similar in size.
I regularly work with ionizing radiation. That probably explains a lot about the post you just read.
 Nicholas Laidler's gear list:Nicholas Laidler's gear list
Canon EOS M Canon EOS M3 Canon EOS M5 Canon EF 50mm F1.4 USM Canon EF-M 18-55mm f/3.5-5.6 IS STM +4 more
Alan Sh Senior Member • Posts: 2,758
But with the Ricoh, you are stuck with that lens. With the M3 you can expand your horizons by changing lenses.
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
OP robyfor Regular Member • Posts: 368
Thanks for the information and the reference link. I point a lot to portability. In fact, the dimensions without lenses are the same. The thickness increases by about 2 cm. for 22mm lenses. With the lent22mm eos m10 is very small but certainly not pocket. In terms of quality, what can you tell me? Thank you
Roberto
Dimensions of the camera alone are known. Now, depth of the camera with 22mm lens mounted is about 65mm (2,56in).
That´s a lot for pocketable camera. You certainly need to go under 50mm.
Le Kilt Senior Member • Posts: 2,527
Try this:
Go up to the menu, click on "Lenses", then on "Canon", and scroll down to 2012, when the lens was released
 Le Kilt's gear list:Le Kilt's gear list
Canon EF 16-35mm F2.8L II USM
Thanks for the reply. In fact the optimal size to be transportable in a pocket should be less than 40 mm. I'm sorry because the features of the eos m10 seemed really interesting .. !!
Roberto
