Olympus E-PL6 time lapse option greyed out
Started Feb 2, 2018 | Questions
Vinod S New Member • Posts: 11
I would be most grateful if anybody can tell me why the 'time lapse settings' option in my E-PL6 is greyed out. It occurs in Shooting Menu 2. There is absolutely no reference to this issue in the User Manual. Any help would be highly appreciated. Thanks.
 Vinod S's gear list:Vinod S's gear list
Nikon D7000 Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +2 more
Olympus PEN E-PL6
junk1 Senior Member • Posts: 1,788
Re: Olympus E-PL6 time lapse option greyed out
Maybe you have the flash on, or the exposure time is set too long...some setting that is not allowed is selected apparently.  I have a Panasonic, and the manual lists when each mode is available; etc.    Experiment.
OP Vinod S New Member • Posts: 11
Thanks for that tip Junk1. Will investigate.
JaKing
JaKing Veteran Member • Posts: 6,300
SCENE modes will also disable lots of things. Put the MODE dial into A or S mode. See if that works.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
Thanks JaKing. I never use the Scene mode so the chances of the knob being in that position is rare. I have tried in PASM positions, but it still stays greyed out.
JaKing
There will be some setting you have changed that's causing your problem.
If all else fails, do a hard reset of the camera (back to factory defaults).
gotoole Contributing Member • Posts: 524
Page 65 of the manual lists a number of things which will interfere with time-lapse. Have you checked if any are relevant. Ie . cable attached etc
Napahto New Member • Posts: 1
I think you have not set date and time on your camera. In the Setup menu last one.
paul613
paul613 Senior Member • Posts: 1,894
You might find this answered on the wiki page Olympus Camera Settings--Menu Lockouts and Quirks.
(better late than never)
Paul S. in Maryland
 paul613's gear list:paul613's gear list
Olympus PEN E-P5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Sigma 30mm F2.8 DN | A Rokinon 8mm F3.5 Aspherical Fisheye (HD) +10 more
