larsbc wrote:
gardenersassistant wrote:
I don't suppose this is particularly helpful given your main concern here. I have to say though that having blobs on the buttons has made a big difference to me. I was continually struggling to find the right button previously, wasting time both in finding the right button and also correcting it when I pressed the wrong one. Now it seems very easy, and quick to find the right one. Given how much I use the buttons and how I need to be quick with some of my subjects I am well pleased with the effect. YMMV of course.
Thank you VERY MUCH for your considered response. I might give it a try anyway. Like you, agree that the buttons are a bit too flush on the G85.
Glad it helped. One possibility comes to mind. You might try it on just one button to start with, use it for a while to see if you like the effect and then take it off to see how that goes. If it is problematic at least you will have minimised the damage.
Sugru somes in small, sealed packets, in various combinations of colours. For example I got 8 in the pack I bought - 2 yellow, 2 blue, 2 red, 1 black, 1 white. You can get all black, or all black/white. Had I realised this at the time I would probably have got black so as to make the blobs less conspicuous. The downside is that once you have opened a packet you pretty much have to throw away what you don't use, so you would need a complete packet for a single tiny blob to use for a test.
(With one packet I did try opening up the packet very slightly, pulling out a small amount and then quickly squeezing out the air and sealing the packet tightly in clingfilm. A bit later I did the same again, and it worked, although I had a lot of difficulty getting the blobs to adhere to the buttons rather than to my finger. I then tried a third time and what was still in the packet - most of it - had stiffened up too much to be usable. It apparently helps btw to keep unused Sugru cool to prolong its usable life. I keep mine in the fridge.)
Having realised that it didn't keep very well once opened I waited until I had my second G80 and then used a fresh packet of Sugru to do a whole lot of kit at the same time. With the fresh Sugru it was quite easy and quick to do, finishing off the first G80 (I had only put blobs on some of the buttons), doing the second G80, my FZ330 (removed wrongly placed blobs and put blobs on most of the buttons), a couple of extra blobs on my G5, lots of blobs on my 70D and four each on my TZ60 and two macro flash units. All told a few over 40 blobs, and this is what was still left unused.
So far so good.
You have to leave the blobs alone for 24 hours to cure. Once they have cured they seem to be pretty well stuck on (but removable if you slide a fingernail under the edge). However, two hadn't adhered properly and popped off when I touched them. So I am left wondering if I really want to use another whole packet just for two tiny blobs. Hardly the end of the world, but just be aware that you might have to have a couple of goes at it. And of course it remains to be seen whether any of them will come off in use.
