Canon 35mm f1.4 L ii vs Canon 24-70 f2.8 L ii vs Canon 16-35mm f4 L Comparison - Just for fun
Started Jan 26, 2018 | Discussions
Andy1970 Forum Member • Posts: 60
I know this isn't a scientific test, but I thought it might be interesting to compare three of my lenses at their common focal length of 35mm and their widest common aperture of F4. Just a bit of fun - Can anyone guess which lens took which photo?
The lenses were attached to a Canon 5D MkiV - the light changed very slightly during the time it took to do the test (or the light transmisson of the lenses are slightly different) I took them all at what the camera deemed to be the correct exposure using evaluative metering. For one of the lenses the shutter speed was 1/320th, for the other two 1/250th. All three shots were at F4 ISO100
The camera was mounted on a tripod. Focusing was done manually using live view at 10x magnification. I focused on the small black light sticking out of the grass in the very centre of the shot. This light was approx 15m away from the camera, which according to my DOF calculator should put everything from 6m to infinity in focus.
IS was switched off on the 16-35mm lens. A remote release cable was used.
Quite a contrasty image - my front garden taken around 1pm today. No blown highlights or clipped shadows though.
Just to make it a little more difficult, I've applied lens corrections in lightroom, so the photos can't be identified by known distortion characteristics of each lens. No other adjustments have been applied to the RAW images.
No prizes for the correct answer I'm afraid! have fun!
Photo A
A
Photo B
B
Photo C
C
 Andy1970's gear list:Andy1970's gear list
Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +9 more
villager New Member • Posts: 4
Re: Canon 35mm f1.4 L ii vs Canon 24-70 f2.8 L ii vs Canon 16-35mm f4 L Comparison - Just for fun
A: 24-70
B: 35 L
C: 16-35
 villager's gear list:villager's gear list
Sony RX100 III
Tazz93
Tazz93 Veteran Member • Posts: 3,484
Me too
villager wrote:
A: 24-70
B: 35 L
C: 16-35
But, I have to say I'm a little torn between A and B, they might be reversed. I think the corners give the 16-35 away being wide open.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
OP Andy1970 Forum Member • Posts: 60
Re: Me too
Tazz93 wrote:
villager wrote:
A: 24-70
B: 35 L
C: 16-35
I’ll hold off giving the answer for a while to see if anyone else wants to play
jffielde Regular Member • Posts: 414
Re: Me too
My preference is B, A, C, so I would say the prime is B, the 24-70 is A, and the 16-35 is C.
Doug_PS
Doug_PS Contributing Member • Posts: 812
My guess (and you can PM me my prize;-)
A) 24-70
B) 35L ii
C) 16-35 f4
 Doug_PS's gear list:Doug_PS's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS M6 Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM +9 more
J A C S
J A C S Forum Pro • Posts: 20,544
A 16-35
B 35
C 24-70
Fog Maker Senior Member • Posts: 2,733
A 35
B 16-35
C 24-70
 Fog Maker's gear list:Fog Maker's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 24-70mm f/2.8L USM Canon EF 100mm F2.8L Macro IS USM
Ken60 Veteran Member • Posts: 3,187
I have looked at all 3 and enlarged............... To me A is rather poor in the corners compared to the others , so being the least expensive one might say 16 - 35, but if it is all I can say is " it sucks to have a bad copy".
The bright frame (B) with more sharpness all over should be the 35mm f1.4
For the money the last (C) should be the 24-70 2.8 that is reputed so good for a  zoom , but looks more like my 16-35.
So I am torn ! DXO might say 24 -70 , 35, 16 -35 on test results but I am prepared for a shock result  and say
A 24 - 70
B 35
C 16 - 35
Gear ... what I need to get the job done , after all you don't see mechanics listing their brand of spanner as a qualification .
TyphoonTW
TyphoonTW Senior Member • Posts: 1,484
My guess:
a - 24-70
b - 35
c - 16-35
C is the image that to my eyes looks less sharp and lacking a bit of contrast. I'm surprised they were all shot at f4 though, the foreground in B is really mushy, while in A and C it's still sort of in focus.
This is where I write stuff: http://randomibis.wordpress.com/
This is where I upload stuff: http://www.flickr.com/photos/107755637@N06/
 TyphoonTW's gear list:TyphoonTW's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +2 more
Sittatunga Veteran Member • Posts: 5,413
A has to be the 16-35mm unless you've been extremely sneaky and cropped it by 0.3%.
Judging by the purple fringing of the twigs above the satellite dish I would say that B is the 24-70mm and C is the 35mm prime.
They're all wonderful lenses though.
Armando J. Rodriguez, Jr. Senior Member • Posts: 1,169
Ok, I will play. Based on the colors (not only sharpness), I will say:
A- 35
B- 24-70
C- 16-35
Do let us know!!
Armando
'Heavens declare the glory of God,' and I hope my pictures will too.
www.pbase.com/arodri3
 Armando J. Rodriguez, Jr.'s gear list:Armando J. Rodriguez, Jr.'s gear list
Canon EOS-1D X Canon 6D Mark II Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +4 more
J A C S
BTW, B and C are focused very differently.
ffabrici Senior Member • Posts: 1,353
Let's look at some facts to help guiding us:
Full frame extreme corner sharpness (MTF50 (lpmm) at 35mm f/4.0 from Lenstip.com:
16-35L IS: 28 lpmm
24-70L II: 31 lpmm (calculated as average of 24mm and 45mm measures)
35L II: 36 lpmm
Chromatic and spherical aberration:
16-35L IS: 0.04%
24-70L II: 0.14% (calculated as average of 24mm and 45mm measures)
35L II: 0.04%
If the 3 lenses were all focused at exactly the same distance and they all have a theoretical flat focal plane, we would see the following characteristics:
35L II: Sharpest extreme corner with relatively low CA
16-35L IS: Unsharpest corner with relatively low CA
24-70 L II: Less sharp corner than 35L with relatively highest CA
Based on my humble evaluation of the 3 pictures I would suggest the following:
A: 16-35L IS
B: 35L II
C: 24-70L II
bestzoom Regular Member • Posts: 181
My guess:
16-35 f4L
35 f1.4 ii
24-70 f2.8
Cheers
 bestzoom's gear list:bestzoom's gear list
Canon EOS R5 Canon EOS R5 C Canon EF 20mm f/2.8 USM Canon EF 85mm F1.8 USM Sigma 35mm F1.4 DG HSM Art +8 more
C’mon give us the answer now,
before the thread gets old
Ok, time to post the answer! It was
A - 24-70 f2.8ii
B - 35 1.4Lii
C - 16-35 F4
I think most of you got it, or you were very close. Seems most agreed that the 35L was the best image. I'm glad about that, as I've only just bought it! My new baby
I did slightly cheat on the 24-70 image, in that I was a bit clumsy in framing the shot and guessing the 35mm point. EXIF showed 33mm and it was a bit wide, so I trimmed off a little.
I found it interesting to compare the lenses in this way, it was actually closer than I thought. They are all very good lenses.
Thanks for playing everyone!
TyphoonTW
I demand a reward!!
TyphoonTW wrote:
I demand a reward!!
Ok here it is.............
”WELL DONE”!!!
J A C S
They are vignetting corrected, right? The UWA vignettes a lot, even well stopped.
