Prime Lens Path for X-T20
Started Jan 25, 2018 | Questions
kiwi-in-aus New Member • Posts: 4
Moving over from Canon to Fujifilm next week (just have the last of my Canon lenses to sell first), and am purchasing an X-T20 as it seems to be a good all rounder as my first foray into a mirrorless system.
Prefer my primes, so am thinking to just by a Body only (and skip the 18-55mm) and start off with a 35mm F2, but what I do for my next lens has me reading over 40 different articles/forums.
I'm also very tempted to go down the route of the WRF2, 1. Because they are lightweight 2. They are not too expensive (could get two F2s for the price of the 56mm) & 3. Because the 23, 35 & 50 come in silver (who am I to deny that they look gorgeous).
I am thinking
1. 35mm F2
2. 50mm F2
3. 23mm F2
4. 90mm F2
But a part of me thinks that the 35mm - 16mm - 90mm is probably the more logical choice, but it just doesn't excite me as much.
OR
I stick with the 18-55mm and just get the 56mm.
I know the 18-55mm is a great lens BUT I have also read so many people found it great in the first couple months then after a prime or two, it has sat in their bag collecting dust. I would rather start off with a prime and add to my collection, BUT am I being foolish here and passing up a great piece of kit?
I know we are all different as far as what we prefer, but for the expenditure would you rather the 4 Primes or for convenience the Zoom + the 56mm Prime?
 kiwi-in-aus's gear list:kiwi-in-aus's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR
Jason Elander Regular Member • Posts: 164
Re: Prime Lens Path for X-T20
I got the kit with the 18-55 as well as the 35 f/2. One big reason I got the 18-55 is that I thought it would be good to have a stablized lens for certain situations and for video.
 Jason Elander's gear list:Jason Elander's gear list
Panasonic Lumix DMC-LX7
kallenph New Member • Posts: 9
Hello there,
Hmm, I guess that would really depend on your shooting style. If you had a range-finder kind of fuji, I'd recommend you dive straight into the primes. But the X-T20 is quite handy with a zoom, and honestly I admire the 18-50 kit lens, it starts at f2.8 and its optically quality has been raved about a lot for a kit lens. Also, to buy it as a stand alone lens is rather expensive, so I think it has good value if you buy it as part of a kit. I'd recommend you to buy it now or you might regret it later, if a zoom is your thing.
The f2 primes are amazing! I've used several of them, they autofocus really fast compared to the older fuji primes. If you aren't doing serious portraiture, I'd rather get two or more f2 primes than the 56mm (which is gorgeous), i like the idea of a few more focal lengths, the extra option seem to excite me more.
Keith Allan
kallenph.tumblr.com
 kallenph's gear list:kallenph's gear list
Fujifilm X-T2 Sony Alpha NEX-6 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F2 R WR +1 more
Gilbert D Regular Member • Posts: 243
My 18-55mm is not getting used much after I got the 35mm f1.4. It is a good lens. But if I’m doing it again, I would skip the 18-55mm. If you are a prime shooter, then I think going directly to primes makes sense.
 Gilbert D's gear list:Gilbert D's gear list
Nikon D90 Fujifilm X-T20 Fujifilm X-T3 Nikon Z6 Nikon AF-S DX Nikkor 35mm F1.8G +8 more
lexvo Regular Member • Posts: 465
I like shooting primes, but the 18-55 is so versatile that I won’t part from it. As a matter of fact, the 18-55 is still one of my most used lenses because it is sharp, has OIS, is not too big and has a nice focal range.
 lexvo's gear list:lexvo's gear list
Canon EOS-1D Fujifilm X-T2 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +3 more
rokphish
rokphish Contributing Member • Posts: 501
Me too.
 rokphish's gear list:rokphish's gear list
Ricoh GR Digital IV Ricoh GR II Fujifilm X30 Fujifilm FinePix X100 Fujifilm X-Pro1 +2 more
jrscls Veteran Member • Posts: 6,436
I have all primes as well. Your plan looks good, but I would add the 16 in there as well. I would start with the 35 f/2 R WR, and then pick up the other f/2 lenses if you like that one. Next add the 16 and 90 and you have all WR lenses.
 jrscls's gear list:jrscls's gear list
Sony a1 Sony FE 200-600 F5.6-6.3 70-200mm F2.8 GM II Sony 1.4x Teleconverter (2016) Sony FE 24-70mm F2.8 GM II +2 more
io_bg
io_bg Senior Member • Posts: 1,548
I've the X-T10 which is identical size and weight-wise to the X-T20. I have three primes for it (sammy 12, 27 and 60) and they handle great on the body. Anything larger (above 200 grams in weight) is a bit heavy on such a small body.
I think the 23 and 50 f/2 would be a nice pair as they're well spaced out, the 35mm is too close to both of them. And maybe add the 90 if you need more reach.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Samyang 12mm F2.0 NCS CS Fujifilm XF 60mm F2.4 R Macro Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II +4 more
pseudobreccia
pseudobreccia Contributing Member • Posts: 939
16mm F1.4
35mm F1.4
55-200mm
If you have the money...
80mm macro or
90mm F2
Steve A. Kleinheider
 pseudobreccia's gear list:pseudobreccia's gear list
Fujifilm X100F Fujifilm X-Pro2 Pentax K-1 II +7 more
Sjak
Sjak Veteran Member • Posts: 7,318
You're not forced to buy these 4 lenses at once
Get one lens, from there on decide what further wishes you have.  23 or 35 are usually pretty allround focal lengths to start with; my pick would be the 35 because it is more compact. Add the 90 and you already have a very versatile kit, or the 18 2.0 if you prefer something wider and cheaper (a new 18 can be had for around 300 euro)
 Sjak's gear list:Sjak's gear list
Ricoh GR IIIx Leica M Monochrom (Typ 246) Pentax K100D Leica M-Monochrom Pentax K10D +1 more
Andreasfe Regular Member • Posts: 229
Buy the kit with 18-55mm and add 23mm f2 or 35mm f2.
That makes for a very solid and compact kit.
You can still sell the 18-55mm, and in fact that will give you a cheaper X-T20-body, than if you bought it as body only.
What lens path you choose for primes is very personal. I like the combination 23mm + 50/56mm, someone like the 16/18mm + 35mm (+ 90mm). Someone like to have access to every focal lengths with fantastic primes.
I have had a lot off lenses over the years, but now I have ended up with 2 primes and 2 zooms that basically cover all my needs.
 Andreasfe's gear list:Andreasfe's gear list
Fujifilm X100V Sony ZV-1 Fujifilm X-T5 Sigma 18-50mm F2.8 DC DN Fujifilm XF 18mm F1.4 R LM WR +1 more
a_c_skinner Forum Pro • Posts: 13,047
In UK the X-T20 is sold as a kit with the 16-50 zoom for only another £100  over the body only price.  That is a huge bargain, even if you only use it sparingly.  The 55-230 zoom is a similar bargain.  The 18-55 is only £300 as part of a kit and is a good lens.
It is frankly foolish to NOT buy the kit with the 16-50 at least, it is such a bargain, in UK at least.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 80mm F2.8 Macro +7 more
BarnET Veteran Member • Posts: 3,581
That is you trying to sell the prime option to yourself instead of being honest about the actual cost.
The X-T20 + 18-55mm = 1199
the 56mm F1.2 = 999 with the bundle 2198,-
the 90mm F2 = 949,- with the bundle 2148,-
total
The body only is 899,-
The 23mm F2 is 449,-
The 35mm F2 is 399,-
The 50mm F2 is 432,-
The 90mm is 949,-
Total 3128,- compared to 2148,- While still not having a decent wide-end option the 23mm being as wide as you can go
Your comparing a set 50% more expensive and ask which to choose. given the same expenditure............... That's being dishonest against yourself trying to defend your already pre determined choice to go with the primes.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR8.TRC1.A0.H0.Xfujinon+18-55.TRS0&_nkw=fujinon+18-55&_sacat=0
The money invested in the 18-55mm is never lost. You can sell close to the bundle price even if you decide you'd want to shoot primes.
To answer your question. it's a rare occasion that it's not the answer but the question that is dumb.
 BarnET's gear list:BarnET's gear list
Panasonic Lumix DMC-GX7 Fujifilm XF 18-55mm F2.8-4 R LM OIS
paulo menge Regular Member • Posts: 324
don't forget de 14mm f2.8
it's a fantastic lens!!
 paulo menge's gear list:paulo menge's gear list
Fujifilm X-T4 Fujifilm XF 23mm F2 R WR Fujifilm XF 14mm F2.8 R Samyang Reflex 300mm F6.3 Samyang 85mm F1.4 Aspherical IF +7 more
StuartBell Senior Member • Posts: 2,039
Absolutely; 16mm would be too narrow to be my widest lens.
Also, 23/35/50 does seem too tightly grouped to me.
I find the 18-55 invaluable when you want photos and simply can't "zoom with your feet".
Current kit in sig; I sold the 90/2 when I realised how little I was using it, partly because size and weight meant I wasn't using it much at all.
Stuart
 StuartBell's gear list:StuartBell's gear list
Fujifilm X30 Fujifilm X-E3 Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm +4 more
jotjotzzz Regular Member • Posts: 121
Do people actually use this focal range: 55-200mm? I would not buy a lens until you really, really need one and stick with primes or the standard kit range.
Having owned a Nikon, I owned a lens with this exact focal range. I got it around 2001 and have only used it twice, and have since gotten rid of it. It's a long a bulky lens, probably great for that Savannah Africa trip, and most likely will not be used for other trips because of its weight. I guess it's also good for taking photos of Little Johnny on the field. But I don't have kids.
 jotjotzzz's gear list:jotjotzzz's gear list
Fujifilm X100T Nikon D5500 Nikon D750 Sigma 17-50mm F2.8 EX DC OS HSM Nikon AF Nikkor 50mm f/1.8D +4 more
My move from Nikon to Fuji has replaced the 70-200 f4 with the 50-200 zoom. I used the former a lot for landscape, both single frames and stitched panos and expect to use the 50-200 similarly. So, yes people do. This https://flic.kr/p/DNyf92 is a stitch of a lot of images from the 50-200 (yes, I know at 55mm)
Andrew Skinner
Wow, very nice shot! I did not think about the panoramic capabilities. Thanks!
Xmacguy Forum Member • Posts: 97
Perfect for whale watching, on a boat, typically 300-500 feet away. Fills the frame with sharp images. But it’s what I bought it for, and I do that quite a bit.
 Xmacguy's gear list:Xmacguy's gear list
Fujifilm X-T5 Nikon Z7 II Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Nikon Z 24-70mm F4 +6 more
chimphappyhour Senior Member • Posts: 1,087
I actually either end up using wide or long more often than anything in the middle. Which is why I went ahead and got the 18-55 as a kit. I figured I might as well pick it up cheap and have it for the times I do shoot in the middle. Otherwise, I'll sink my money into the ends of the spectrum.
 chimphappyhour's gear list:chimphappyhour's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F1.4 R +4 more
